Re: '84 Chrysler 5th Avenue conversion from computer to ecu
[Re: dfixer]
#2428085
01/03/18 12:46 AM
01/03/18 12:46 AM
RapidRobert
Welcome aboard. pull the yellow wire off of the starter relay to disable the starter & have a helper hold the key to "start" & see if the coil positive primary terminal/blue/yellow ECU terminal are hot (& near batt voltage) then have him release the key to "run" & see if they are still hot. seperate/reconnect the ECU pentastar connector/dist pickup zigzag connector & firewall bulkhead. Ohm the dist pickup for ohm amount/continuity. the coil positive primary should have more voltage than the coil negative primary terminal. How did you wire it up? this'll get us started. EDIT with a bit more thinking, you might be wired right ex the coil is backwards & it was OK when warmer but not when it got real cold OR the ECU mighta failed (it wouldn't be orange in color would it!). Ohm the ballast too but for that potential that would be a "run" side issue with maybe a hint of starting on the "crank" side till you let off the key & it goes back to the run "ballast" side.
[Re: RapidRobert]
#2428506
01/03/18 09:37 PM
01/03/18 09:37 PM
Posts: 24 Texas
dfixer
Texas
To the best of my ability and understanding, here are the answers to the questions Rapid Robert asked me to check on: 1. With the pentastar connected key in start, on positive post I read 7.56 2. With the pentastar connected key in start, on negative post I read 3.65 3. With the pentastar disconnected key in start, on positive post I read 11.35 4. With the pentastar disconnected key in start, on negative post I read 11.35 5. With the pentastar connected key in run, on positive post I read 7.46 6. With the pentastar connected key in run, on negative post I read 3.92 7. With the pentastar disconnected key in run, on positive post I read 11.39 8. With the pentastar disconnected key in run, on negative post I read 11.39 9. The dist. pickup does have continuity and reads 250 ohms 10. Yes the ECU is "Halloween pumpkin" orange 11. The ballast resistor reads 1.3 ohms Just as reference, the battery voltage reads 12.10 Something I didn't mention yesterday is that I put in new plugs and wires the month before I did the conversion and I put in a new ignition coil at the same time as I did the conversion. Thanks again
[Re: dfixer]
#2428539
01/03/18 10:35 PM
01/03/18 10:35 PM
RapidRobert
Check the reluctor gap (takes 5 seconds) . seperate the dist pickup zigzag connector & drag the male (bare) tip of the body harness half of that connector across the intake surface (ground) as you hold the end of the large coil to dist coil wire 1/4" from the intake (ground) with key "on" & key to "crank" with starter relay unplugged (yellow "ign" wire) see if the coil wire sparks. I dont think it will as I think the box has died but it is an easy check. Take all the wires off of the coil negative primary terminal (might just be one) & with a jumper wire with alligator clips on each end, connect one end to the coil neg terminal and tap tap the other alligator clip end to the intake & see if it makes the coil wire spark (in run & in crank, same deal there). I'm assuming the blue/yellow (ECU main feed) is hot also (I mighta missed that). It sounds like the infamous orange box has died. though I dont suggest shotgunning parts for diagnosing, I think I would get a cheap parts house 4 pin replacement & if it turns out that that ain't it, with the newer orange boxes' rep I would highly suggest a spare 4 pin ECU in the glove box.
[Re: RapidRobert]
#2428646
01/04/18 01:10 AM
01/04/18 01:10 AM
Posts: 24 Texas
dfixer
Texas
It sure seems to me that it is pointing to a defective ECU. However, once again night has overtaken me and we are headed back down into the 20's, so I will get the answers to your questions tomorrow. Following the instructions that came with the conversion kit, I did check the reluctor gap when I took the new distributor out of the box. It was no where near where it was suppose to be and with a brass feeler gauge I set it to .008 of an inch, as instructed. Of course it could have moved, so I will check it again tomorrow. Following my Chrysler service manual, I did try to get a spark out of the coil wire by momentary taps with a test lead on the negative post to ground with the coil wire 1/4 inch from ground, but it didn't call for me to remove the black/yellow wire from the negative post (the only wire on the negative post) and it only had me try it with the switch in the run position; nor did it have me try it with the zigzag connector. In every instance, with and without the harness connected, I never got a spark. Just to be sure, I will try everything you ask tomorrow. My question now is about the, as you said, ". . .infamous orange box." I am guessing the use of "infamous" in this instance is not a good thing. I know about carrying a spare part in the glove box. I also drive a '67 Corvair and never leave home without a spare belt and clutch cable. But I also know, with my luck, I will have just cut my hand off on the table saw and need to rush myself to the ER when the 5th Ave. will give me another no start. So are there better, more reliable boxes? I don't have to tear this conversion apart to send it in just to have them send me another orange box? Thanks
[Re: dfixer]
#2428793
01/04/18 12:15 PM
01/04/18 12:15 PM
RapidRobert
Actually if you pull the pentastar connector off of the ECU yes you dont have to take off the black/yellow wire from the coil neg primary post, just pull the coil wire out of the dist cap terminal & make/break jumping the coil neg primary terminal to ground with a jumper & see if the coil wire held 1/4 from ground makes sparks & I would do it in run and in crank. if it sparks then that tells you all is good ex for either the ECU, the dist, their respective wiring. then plug everything back in & drag the pickup body half male metal tip across the intake metal surface & same deal, see if the coil wire sparks in run and in crank & in fact I would do that first & if it sparks then the dist pickup is the issue but with you showing continuity on it I don't think it is the pickup but it is an easy first test (& yes this ain't a "factory" procedure) but it is safe/effective. The newer orange boxes do have a higher failure rate than the old ones did but we are the fixit dept so we (mostly) do get bad news here & it did run so it is wired right so K.I.S.S. (keep it simple sam) does point to the ECU as the culprit. & make sure the ECU is grounded well.
[Re: RapidRobert]
#2429181
01/04/18 09:35 PM
01/04/18 09:35 PM
Posts: 24 Texas
dfixer
Texas
You gave me a list of things to try last night in you post at 7:35 PM, and of course, as I said, I would try them today in the daylight. This morning at 9:15 AM, you gave me pretty much the same list but letting me know with the pentastar connector off I did not have to pull the negative lead off the coil. I made a copy of those things to try and went down to the car. With the pentastar connector already off I tried the first set of questions. With the jumper on the coil negative post and first key in run then start position I got no spark from the coil wire dist connector at 1/4 inch from ground. Hooked everything up, pulled the zigzag connector apart, key in run then start and there was my spark at the coil wire end and your post said,". . .if it sparks then the dist pickup is the issue but with you showing continuity on it I don't think it is the pickup. . ." I thought WOW! I was so sure everything was pointing to the ECU. But then I thought back to the opening sentence on your post from last night, "Check the reluctor gap (takes 5 seconds)." For me, crawling back there takes more than 5 seconds, but sure enough, the gap was just about as bad as when I took the dist out of the box. I set it back to .008, put the cap on, plugged everything back together and it is running great again! I know when I tightened that screw the first time I did so till it felt like I might cam out the head and I did the same thing today. As I said earlier, I have a Corvair, actually two, so I have had lots of time under a dist cap and don't recall having a plate move out like that. Maybe I just didn't get it tight enough; it may happen again. But it is running once again (I did charge the battery up) and I sure appreciate everyone's help. I do have one small question. It looks like the pentastar connector and its mating jack are designed to have a screw down through the center to keep them from separating. I know there wasn't one in the hardware package in the kit, just wondered if it is suppose to have one. Thanks again
[Re: dfixer]
#2429185
01/04/18 09:53 PM
01/04/18 09:53 PM
RapidRobert
"Check the reluctor gap (takes 5 seconds)." For me, crawling back there takes more than 5 seconds. On the screw down thru the center I know there wasn't one in the hardware package in the kit, just wondered if it is suppose to have one. Thanks again When you get up in your 60's you will be able to slide in & out of there like a ninja in 5 seconds (or less). That screw is a preventative piece but I cannot say I have ever seen one come off of there. it is a weird thread count (iirc) but I'm sure your hardware store could fix you up. EDIT The coil would have to have sparked with you making/breaking jumping the neg primary post to ground. definitely check the plate lockdown screw cuz if it loosened once likely it will do it again cuz you tightened it up good both times. You might have to tap a new hole or possibly jam a slightly larger screw in there till it gets secure.
[Re: RapidRobert]
#2429343
01/05/18 05:59 AM
01/05/18 05:59 AM
Posts: 24 Texas
dfixer
Texas
"When you get up in your 60's. . ." Are you kidding me? I am so far past those years, I can't remember whether they were fun or not. I am still puzzled by not getting a spark when using that negative post troubleshooting. I had run that test so many times with the same result, I was almost happy to see it spark when using the zigzag connector method. As much as I wanted it to spark, tried to get it to spark and all those times not once did I see a spark; but the first time with the zigzag, there it was. It just concerns me that somehow I might still have something not quite right. I am equally worried about that screw holding the pickup coil in adjustment. Both times I feel like I tightened it down as far as I could go without making the head of the screw look like one of those security screws used on urinal petitions in guys' restrooms. Like you, I am thinking I may have to change that screw out for something more substantial. But for now I will concentrate on getting it all put back together, re-dressing all the wires, order a spare ECU for the glovebox but most of all, enjoy driving my 5th Avenue that has been given a new lease on life(that I hope will last longer than a month this time). Again, thanks all of you for your help, especially your patience Rapid Robert. . .couldn't have done it without you.
[Re: dfixer]
#2429678
01/05/18 11:22 PM
01/05/18 11:22 PM
RapidRobert
MoparX thank you for the kind words. dfixer, Here I thought I was talking with a YOUNG man!. If it runs it is wired OK (in this case). For future (diagnosing) reference, (1) with all (can be just one like yours) wires off of the coil neg primary terminal terminal (2) key (A) on or (B) key to crank (3) tap tap the jumper wire you use, to ground (4) the coil wire end 1/4" from ground will/must spark if the coil is good & it is being fed (& it is in this case). the pickup zigzag connector you can get by with just dragging it across the intake surface to make/break contact. IIRC the screw is an 8-32, 3/16 long & if you have to redo the threads I would remove the center clip the pull the reluctor up & off the shaft WHILE pressing down on the shaft so the shaft/slotted plate does not come up off of the pins, then you can undo everything & seperate the 2 plates to drill/tap the hole in the upper plate (if needed).
[Re: dfixer]
#2430233
01/06/18 11:16 PM
01/06/18 11:16 PM
RapidRobert
I promise, first when the time comes, lets see if it sparking at the plug wires when someone cranks it.
[Re: dfixer]
#2430614
01/07/18 05:44 PM
01/07/18 05:44 PM
Posts: 24 Texas
dfixer
Texas
There is no spark at plug wire #1. Pulled the wire off that spark plug, put in one of the old ones I just replaced (which really wasn't that worn), pushed it against the intake and my assistant cranked the engine. I moved the plug some on the intake to be sure it was making good contact but still no spark. Just for info, I looked back over my maintenance records for this year and in addition to this conversion kit, I have changed the plugs, plug wires, cap and rotor (which were replaced with the cap and rotor in the kit), windshield wiper bushings, alternator, fuel pump, fuel filter, of course oil and filter, air filter, belts and hoses, carburetor repair kit, exhaust & emission control duct hose and fresh air intake hose. I retired in November of 2016, and wanted to get it ready to go the rest of the way with me (my sister and brother-in-law bought it new in '84 - I bought it from them in mid 1995). What would you like for me to try next?
[Re: dfixer]
#2430651
01/07/18 06:59 PM
01/07/18 06:59 PM
RapidRobert
Lets go thru our std tests. disable the starter. drag the zigzag dist pickup connector on the intake & see if the coil wire sparks in run and in crank. if it does not spark then we'll jump the coil neg primary terminal to ground (tap tap tap) & see if the coil wire sparks in run & in crank (& it will clarify that test for us cuz with it running it had to have sparked). If dragging the zigzag connector does NOT spark the coil wire then we'll attack the dist. this'll get us started.
[Re: dfixer]
#2430842
01/08/18 12:20 AM
01/08/18 12:20 AM
RapidRobert
with the black/yellow lead off of the coil neg pri terminal & jumping the threaded coil terminal to ground (tap tap tap) with a jumper you get no coil wire spark in run/crank? (& it sparks on the "break"). Not sure what is going on there/what we are missing BUT if it (coil wire) sparks when you drag the zigzag connector across the intake then the problem is STILL in the dist.
[Re: dfixer]
#2430906
01/08/18 03:40 AM
01/08/18 03:40 AM
Posts: 24 Texas
dfixer
Texas
OK, this started because one day the car would crank but not start. I figure the computer has gone bad so I install the conversion kit. It runs great for a month then back to crank but no start. Looks like the pickup coil screw didn't do its job, so I reset the gap, it runs fine for 8 miles and then the next day back to crank but no start. So if dragging the zigzag connector across the intake causes the coil wire to spark, I presume that spark is coming from the ignition coil which means it is OK even if it will not spark when I ground the negative post on the coil itself.
Let me see if I have this right. The reluctor breaks the magnetic field inducing a voltage in the pickup coil, sending that pulse through the zigzag connector on pins 4 & 5 of the pentastar connector in the ECU, that in turn fires off a signal to the ignition coil, that induces a small voltage in a small winding to be a large voltage in the larger winding going into the coil wire to the top of the dist. cap and out the rotor to the spark plug and ignites the fuel. So in the simplest terms it is a three part system, distributor, ECU and ignition coil and when we ground the zigzag connector and it sparks we have taken the place of the distributor proving that the other two thirds of the system are working (even if I can't get the coil test to spark). Is that correct?
So if it is the dist., what is it in the dist.? The reluctor turns on the shaft and that is all it can do, the pickup coil or its wiring could be bad, the cap and/or rotor could be bad. Am I right with that list? What is the next approach? Do I change the cap, the rotor, the pickup coil? My old dist. had two pickup coils. Do I sub it using just the two conductor zigzag connector?
Though I have replaced the coil and replaced the computer with the conversion kit and I am still having the same problem I started with, am I overlooking something that didn't get replaced that could cause it not to crank? But why did it work so well for a month. . .and 8 miles?
[Re: dfixer]
#2431017
01/08/18 01:13 PM
01/08/18 01:13 PM
RapidRobert
the reluctor tooth induces a slight AC voltage in the pickup coil & that "triggers" the ECU to unground the black/yellow wire from the coil neg pri terminal. the coil works opposite of other devices, it is being fed voltage & it sparks when the current is stopped & the magnetic field in that primary circuit collapses & induces a current in the secondary circuit (the large center post/wire). when you do the coil test you dont keep the coil neg primary terminal grounded like it sounded like you were saying (if I interpreted it right) but you tap tap the alligator clip to ground & it sparks when you lift it up off the intake (ungrounding it). OK, if dragging the pickup nub makes it spark in run and in crank with the ECU plugged in/everything else hooked up normal then all that is left is from the zigzag connector back to/including the pickup (electrically) & the gap (mechanically). You have provided excellent details but I feel I am inadvertently missing something. lets try this: repeat the zigzag dragging test BUT have a helper cranking the ign & see if the coil wire sparks.
[Re: dfixer]
#2431298
01/08/18 10:12 PM
01/08/18 10:12 PM
RapidRobert
lets do this: turn the crank CW with a 1&1/4" socket/breaker bar till the rotor tip is centered under the nearest dist cap plug wire terminal bulge. coil wire plugged in. pull the plug wire that the rotor tip is under & either put a spark plug in it & ground the plug or put a piece of metal up in the end of the plug wire boot & hold the metal end 1/4" from a ground with one hand & drag the pickup nub across the intake with your other hand & see if it sparks/or the plug gap sparks if you use a plug. try it with the key in "run" and pull the yellow wire off of the starter relay to disable the starter & have her hold the key to start as you again drag the zigzag tip across the intake & see what we get. If the "dragging" of the zigzag conector is makeing it spark then it has to be in the dist: pickup/zigzag connector a bit loose (the 2 female terminals in it)/rotor/wires/plugs cuz the pickup is what triggers the ECU & the dist distributes the fire to the 8 plug wires/plugs.
[Re: dfixer]
#2431830
01/09/18 09:25 PM
01/09/18 09:25 PM
RapidRobert
lets keep the same stuff on there cuz it is functioning OK (bottom line is spark at the plugs & it is doing that). Tho we gotta figure out why it ain't sparking when it is turned over with the key cuz the brown wire (crank) circuit is getting powered when she turns the key to crank (cuz the dragging is makeing it spark) (with the starter disabled) but it will not spark while cranking & the only difference that I can see so far is that the dist is in effect doing the "dragging" & the zigzag is plugged back in & it ain't doing its job for some reason. So with everything plugged back in & her cranking it there is no spark at the plug(s)? it keeps point to the dist & if that 2 magnet dist has 2 "regular" zigzag connectors we may have to install that dist & use whichever pickup gives us the best phaseing. FIRST lets do this: repeat your last test with (2) changes: plug the starter relay yellow wire back in & have her crank it while you drag the (unhooked) pickup nub (same as before) across the intake & see if the coil wire and any plug wire is sparking. EDIT see if the coil wire sparks then plug it in the dist & see if the plug wires spark.
[Re: dfixer]
#2432559
01/11/18 12:21 AM
01/11/18 12:21 AM
RapidRobert
everything is pointing to the dist. this other 2 zigzag dist, maybe it is time we try it (not permanent but just to pin it down). Does this dist have 2 zigzag plug ins/2 pickups/no vac or mech adv? with the 1&1/4 socket get the nearest tooth dead even with the magnet, then install the other dist in the same position (tooth dead even with magnet/rotor under same plug wire terminal). I'm assuming the rotor phaseing is near the same with either zigzag being used (been a long time since I seen one of those) but confirm by lining up the tooth with a magnet & see if the rotor is under or near under a cap terminal bulge (centered). See if it will fire up. You wont have advance so shut it down pretty much right away as it will get hot above idle but if it starts that's all we need to know for now.
[Re: dfixer]
#2433703
01/13/18 01:03 AM
01/13/18 01:03 AM
RapidRobert
Actually I should not have suggested it, I forgot that it ain't like th old (2) zigzag dists that had 2 regular pickups slightly offset from 180 away from each other. To the best of my knowledge it is dist related, dragging will zap the plugs but the dist hooked up will not. Howabout we call Jegs & see what they are willing to do to help us resolve this. did we ohm the pickup? & with the scale on low AC volts on the zigzag if you spin the dist by hand will it give a reading?
[Re: RapidRobert]
#2434204
01/14/18 12:51 AM
01/14/18 12:51 AM
Posts: 24 Texas
dfixer
Texas
Well I may have messed up my opportunity on any returns. I was going to pull the dist. to spin it to check to see if I would read any AC voltage. As many times as I have put dist caps on I have never had this happen, but when I pulled the cap I discovered the spring contact on the rotor was bent badly to one side. It was so bad, even though I tried to get it straight, it left an obvious crimp mark. But I did think maybe that was the problem, got it as straight as I could, put it back together but got the same results. I took it apart and it was bent again. I just knew that must be the problem so I put in the rotor from my most recent cap, rotor, plugs and wire change out. Still no change and when I pulled the cap that spring was bent a little too and then examining the inside of the cap it had obvious cuts in the copper ring around the carbon button at the center of the cap. I am sure, once Jegs got the return they would say it didn't work because I had damaged the cap and rotor. I am beginning to feel my boat rocking in the creek and the light is getting so dim I am not sure I can find the paddle.
When I got your post last night I looked back over my notes and we had checked the pickup coil and it measured 250 ohms. I apologize, in my frustration I didn't pull the dist to check the AC voltage output of the pickup. I will try to get that done tomorrow. I guess I could just have my helper crank the engine while I measure for AC at the zigzag connector, rather than pull the dist.
[Re: dfixer]
#2434340
01/14/18 12:07 PM
01/14/18 12:07 PM
RapidRobert
is it possible that if we tossed in a new cap/rotor that we would be good? installing the cap straight down keeps the rotor tang from catching/bending but sometimes that is hard to do with the wires installed expecially if the lengths are slightly shorter than the normal amt & in that situation I pull the wires/install the cap/reinstall the wires. What would a dist cost at your parts house & what about one at a yard?.
[Re: scratchnfotraction]
#2436401
01/17/18 04:39 PM
01/17/18 04:39 PM
Posts: 24 Texas
dfixer
Texas
Sounds interesting but I have a couple of questions. You said,". . . ask for a 67 - 72 points dist about 28$ at AZ." I don't know about your Auto Zone, but at mine they only know what to ask by what their computer tells them to ask, like what's the make, model, engine, etc. If I ask for a 67-72 points distributor I will get the deer in the headlights look and I have to admit, I am not any better. My other question is you said,". . .swapped my 85 truck over to points and waiting on my conversion kit to come in." What's in the conversion kit, where does it come from, or you still talking points conversion? What I have on order is a Cardon - this Jegs sure doesn't seem to be working. Thanks for your offer. That conversion sounds like it would at least give me another option. Sure do want to get my '84 back on the road.
[Re: dfixer]
#2438560
01/21/18 07:43 PM
01/21/18 07:43 PM
RapidRobert
the symptoms sure definitely point to the dist (not triggering the ECU) but I wonder if it IS the ECU (what 5th ave said).
[Re: dfixer]
#2438622
01/21/18 08:56 PM
01/21/18 08:56 PM
Posts: 1,637 Florida
GMP440
This may have been addressed in an earlier post; have you checked the voltage going to the distributer? What is the voltage coming from ignition 1 and 2?
#2439414
01/23/18 05:02 AM
01/23/18 05:02 AM
Posts: 24 Texas
dfixer
Texas
I am back on the road again! I got out the old Sun gun and set the timing. Then I had to manufacture something to get to the half inch hold-down bolt for the dist. That vacuum module hanging off the side, that wasn't there under the old system, does make it a lot more difficult; I really had to fight it last time, this time I was determined to make it a little easier.
There was also that other problem I mentioned yesterday; the ECU connector wouldn't go on. The connector pins would only go on about 1/16th of the way into the cavities. I tried putting it on and off so many times the first 1/16th of the cavities were so shiny they almost looked chromed. I tried pulling it down with the screw, but I could tell it was about to strip out. I decide I needed to ream out the cavities (it was just the top three holding the connector off), but when that didn't seem to be making any headway, I put more light on the subject. It was then that I discovered that in the manufacturing process, some of the flashing had not been removed in the grove between the outside wall and the main body of the plug. It was Dremal time. A zip bit cleaned out the flashing from the grove and the connector went right on. I examined the orange ECU next to the new Standard Blue Streak chrome ECU and discovered the wall surrounding the connector pins was thicker on the chrome ECU than on the orange ECU, thereby not causing a problem when the harness was used with the orange ECU. Just wanted to mention that in case someone else runs into that China created issue.
I think it may be idling a bit fast. I'll drive it around a bit some and adjust it if need be after a little break-in period. Hopefully I won't be back here in a month saying, "Guess what?"
Again I really want to thank everyone for all their help and I hope that all of these post, about my problem, may someday help someone else get their vehicle back on the road again.
[Re: 5thAve]
#2440333
01/25/18 12:34 AM
01/25/18 12:34 AM
RapidRobert
easiest I found to get in there is a short 1/2" box end wrench or a 1/4" drive mini ratchet with a 1/2" socket on it.
