Re: Offset grind 3.75 crank limit
[Re: PorkyPig]
#2428313
01/03/18 03:04 PM
01/03/18 03:04 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I've thrown away enough cracked stock BB Mopar cranks that came out of bracket cars to have reached the point where I now only use them in pretty basic street or street/strip stuff.
No way would I bother having one offset ground for more stroke when I can get a 4340 piece for under $800.
But that's just me.
[Re: PorkyPig]
#2428355
01/03/18 04:07 PM
01/03/18 04:07 PM
Posts: 3,076 Michigan
A727Tflite
Interesting - you mention big block cranks cracking - how do the Chevy cranks do, do they crack too or not? Ford?
Just you're observation please.
[Re: PorkyPig]
#2428531
01/03/18 10:18 PM
01/03/18 10:18 PM
Porter67
[Re: PorkyPig]
#2428836
01/04/18 01:00 PM
01/04/18 01:00 PM
Posts: 4,206 New York
polyspheric
New York
Can't follow the text, they refer to "adding 1/2" to the stroke", using the stock rods (no offset), and 505" with 4.00" is just under 4.500" bore - not something you would do.
Boffin Emeritus
[Re: polyspheric]
#2428854
01/04/18 01:20 PM
01/04/18 01:20 PM
Posts: 403 Romulus, MI
GTS340
Romulus, MI
Can't follow the text, they refer to "adding 1/2" to the stroke", using the stock rods (no offset), and 505" with 4.00" is just under 4.500" bore - not something you would do. They welded the journals to get to 4.250 stroke with the stock rods
[Re: PorkyPig]
#2430364
01/07/18 03:48 AM
01/07/18 03:48 AM
Posts: 43,193 Bend,OR USA
Cab_Burge
If your motor makes 1.2 HP per C.I. how much HP does it gain 451x1.2=541.2 HP compared to 1.2x470=564HP. Of course if it makes more or less HP per C.I. the results will vary accordingly I'm not sure about how much the torque gain and PEAK RPM for both torque and RPM are affected by stroke changes I do know that on my last pump gas street and strip car increasing the stroke .050 (went from 4.25 to 4.300)helped it by .2 ET and 2.5 MPH
[Re: PorkyPig]
#2430377
01/07/18 04:25 AM
01/07/18 04:25 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
How much difference would 19 cubic inches really make going from 451 to 470? My 3.75 crank is a new offshore 4340 that measures OK. But if I only go to 3.91 I don't know that it would be worth the money for new rods and pistons with only that much offset grind. If you have all the parts for the 451, rods pistons, etc stay with that. The 451 is a great motor combo.
