Re: HELP it's 4 degrees out and my Driver window is stuck down
[Re: Whitey Nocar]
#2426989
01/01/18 11:38 AM
01/01/18 11:38 AM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
Only thing I would know to start with is get it inside and see what happens.
space heater blowing on door?
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: Whitey Nocar]
#2426991
01/01/18 11:48 AM
01/01/18 11:48 AM
RapidRobert
I would think there is continuity (fuse OK) cuz it clicks but I know that a starter relay can click with an open. I am WAG ing that each window does not have a seperate fuse so the others do work so I think it is being powered. What Flash said I would just get it inside somewhere.
[Re: Whitey Nocar]
#2426996
01/01/18 12:01 PM
01/01/18 12:01 PM
6bblFLASH
N.E. Ohio
Was thinking,,,,"possibly" pour some alcohol/de-icer like we use on air-lines-trucks. but odds are it won`t get to where its stuck.
I had an issue like this with a sunroof 30 years ago. Found a indoor self/car wash stall. closed the door and waited............
[Re: Whitey Nocar]
#2427164
01/01/18 03:51 PM
01/01/18 03:51 PM
Posts: 43,200 Bend,OR USA
Cab_Burge
Put it in heated garage or shop for awhile before trying to use it any more If that is not possible start it up and cover that window really well with several layers of good insulation, blankets, large moving pads or something else that is good, and let it run for as long as it takes to unthaw that window with the heater on full blast
