Best source/ material to seal hood to carb pan? #2425962
12/30/17 06:01 PM
12/30/17 06:01 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Who has a good foam to do this? Should I do fireproof?
I already have he lower metal "pan" fabbed that fits the carb.
'63 Dodge 330
11.19 @ 121 mph
Re: Best source/ material to seal hood to carb pan? [Re: GY3] #2425974
12/30/17 06:16 PM
12/30/17 06:16 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
I just used the Moroso stuff. There might be something cheaper out there. Keep in mind, 60 inches doesn't go that far. I'm using a 14 inch air cleaner on my pan. I used all the foam in the kit and circled my air cleaner with only a few inches between the foam and the element.
Re: Best source/ material to seal hood to carb pan? [Re: GY3] #2425977
12/30/17 06:19 PM
12/30/17 06:19 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
When my Son worked at a scrap yard he bought some old road signs that were laying around.
Untitled by John Cadamore, on Flickr
Then I went to my local plumbing (hardware store) and bought 2 inch foam to seal it.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Best source/ material to seal hood to carb pan? [Re: GY3] #2425979
12/30/17 06:20 PM
12/30/17 06:20 PM
PA.
"Little"John
"Little"John
PA.
My local store had 1/2 inch to 2 inch foam in stock.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Best source/ material to seal hood to carb pan? [Re: GY3] #2425990
12/30/17 07:03 PM
12/30/17 07:03 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Lowe's or HD in the HVAC aisle, homie.
Re: Best source/ material to seal hood to carb pan? [Re: pittsburghracer] #2425998
12/30/17 07:21 PM
12/30/17 07:21 PM
A727Tflite Offline
A727Tflite  Offline
Would you expect a performance difference between a yield sign and a speed limit sign?
boogie
Re: Best source/ material to seal hood to carb pan? [Re: A727Tflite] #2426019
12/30/17 08:21 PM
12/30/17 08:21 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I used the Moroso replacement foam. Years ago I called on it and was informed it is fire retardant. I never did test the theory because, as mentioned above, the kit only has enough to to a 14" air cleaner. My car has had the same foam for almost 20 years with no complaints.
Re: Best source/ material to seal hood to carb pan? [Re: pittsburghracer] #2426064
12/30/17 10:08 PM
12/30/17 10:08 PM
Is that close cell or open cell foam? Which one is the best to use?
Re: Best source/ material to seal hood to carb pan? [Re: Cab_Burge] #2426087
12/30/17 10:48 PM
12/30/17 10:48 PM
PA.
"Little"John
"Little"John
PA.
I used the black stuff to match the car when I have the hood off.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Best source/ material to seal hood to carb pan? [Re: GY3] #2426145
12/31/17 01:11 AM
12/31/17 01:11 AM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
I used 2x2” air conditioner foam from Home Depot applied to the air pan with spray adhesive. So far it’s held up good and was worth a tenth in the quarter mile.
Re: Best source/ material to seal hood to carb pan? [Re: humpty] #2426154
12/31/17 01:47 AM
12/31/17 01:47 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I'll be adding a tray and foam and doing it
much like Humpty did but its gonna be on my
Rampage
EDIT
Mine is a cowl set up so I need a pretty big tray
to cover the whole cowl.. I think I will attach
the tray right to the cowl to make it easy
wave
Re: Best source/ material to seal hood to carb pan? [Re: GY3] #2426166
12/31/17 02:15 AM
12/31/17 02:15 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
How about a P shaped seal that you could rivet or glue on?
http://www.brownaircraft.com/product-p/t-6400.htm
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Best source/ material to seal hood to carb pan? [Re: GY3] #2426174
12/31/17 02:29 AM
12/31/17 02:29 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yeah, I use a rubber bulb seal like that, with a pinchweld grip end, but I have a lip and not much of a gap to seal; just sealing an air-cleaner base to a round hole of the same size in my hood.
