Re: SHOCKS............
[Re: Thumperdart]
#2425937
12/30/17 05:21 PM
12/30/17 05:21 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
Dom Measure the distance you are needing and just start shopping around. You can usually find deals on used shocks, especially coil overs. Remove the springs and you have a good single or DA shock..
[Re: Dragula]
#2426102
12/30/17 11:16 PM
12/30/17 11:16 PM
Thumperdart
State of confusion
All good and will keep looking or buy new.............
[Re: Thumperdart]
#2426133
12/31/17 12:37 AM
12/31/17 12:37 AM
Posts: 4,457 Washington
madscientist
Washington
I now have Vikings on all four corners and I'm glad I spent the money.
[Re: madscientist]
#2426144
12/31/17 01:11 AM
12/31/17 01:11 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Dom.. try the Viking but get the heavy valving installed.. you can always ease that off if they are too stiff and I think the price is decent and you know they will just go up in price so dont wait too long
[Re: madscientist]
#2426159
12/31/17 01:51 AM
12/31/17 01:51 AM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
I now have Vikings on all four corners and I'm glad I spent the money. Same here.
[Re: WHITEDART]
#2426185
12/31/17 03:08 AM
12/31/17 03:08 AM
Thumperdart
State of confusion
I have D.A Vikings.. for the rear Do you have a part # for the ft. and rears cos I looked and cant seem to find any and are they the Crusaders............
[Re: Thumperdart]
#2426192
12/31/17 03:22 AM
12/31/17 03:22 AM
MR_P_BODY
I've heard great things about the Viking stuff and have checked em out and the vid my friend posted on FB shows it killing the tire which I assume means that I need more extension control? Not good at this chassis stuff........... Yeah you need better control of the axle housing.. the shock you have now is real close to being maxed out if you have it set right.. at least all the ones I've seen are(that are set right or close)
[Re: MR_P_BODY]
#2426196
12/31/17 03:29 AM
12/31/17 03:29 AM
Thumperdart
State of confusion
I've heard great things about the Viking stuff and have checked em out and the vid my friend posted on FB shows it killing the tire which I assume means that I need more extension control? Not good at this chassis stuff........... Yeah you need better control of the axle housing.. the shock you have now is real close to being maxed out if you have it set right.. at least all the ones I've seen are(that are set right or close) Rancho 5-ways on # 4 and had I known they need to be tighter, I would of went to # 5.......Then new CNC profiled main body BLP set me up w/has created more torque cos I was hooking w/the 1050 that was on it before and not now...........
[Re: Thumperdart]
#2426197
12/31/17 03:32 AM
12/31/17 03:32 AM
madscientist
Washington
I have D.A Vikings.. for the rear Do you have a part # for the ft. and rears cos I looked and cant seem to find any and are they the Crusaders............ Fronts are B202 Rears are B217
[Re: Thumperdart]
#2426199
12/31/17 03:40 AM
12/31/17 03:40 AM
MR_P_BODY
I've heard great things about the Viking stuff and have checked em out and the vid my friend posted on FB shows it killing the tire which I assume means that I need more extension control? Not good at this chassis stuff........... Yeah you need better control of the axle housing.. the shock you have now is real close to being maxed out if you have it set right.. at least all the ones I've seen are(that are set right or close) Rancho 5-ways on # 4 and had I known they need to be tighter, I would of went to # 5.......Then new CNC profiled main body BLP set me up w/has created more torque cos I was hook ing w/the 1050 that was on it before and not now........... A lot of times all it takes is just a little bit to put you over.. you MIGHT get away with the #5 setting.. but that puts you at the MAX you have and most times it isnt enough to get a good handle on it.. thats why guys spend the money and get a fair bit better shock.. that way they arent on the edge of control
[Re: Thumperdart]
#2426274
12/31/17 01:06 PM
12/31/17 01:06 PM
Al_Alguire
Las Vegas
IMO as Ive said many times buy the BEST shock you can AFFORD. It is rarely money not well spent.
[Re: Thumperdart]
#2426300
12/31/17 02:01 PM
12/31/17 02:01 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I have D.A Vikings.. for the rear Do you have a part # for the ft. and rears cos I looked and cant seem to find any and are they the Crusaders............ .. you're not actually looking for a part number for the rear.. your shocks have been relocated. So you're looking for a certain length
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: Thumperdart]
#2426331
12/31/17 02:46 PM
12/31/17 02:46 PM
MR_P_BODY
Thankxxx for the shock #'s and the same rear Rancho shocks are fine straight up and down w/about 2 1/4 compression and the rest extension so a similar length should work. Was on YB checking out the Caltrac thread and guys are in the 8's on Ranchos............. We will say that there are 50 guys that have issues with the Ranchos and you have one that works.. will yo believe 50 or the one.. also maybe that shock was built tighter than the 50.. dont take everything you hear on the net as fact
