Page 1 of 4 1 2 3 4
New Trick Flow heads for Ford FE #2425632
12/30/17 03:35 AM
12/30/17 03:35 AM
AndyF Offline OP
AndyF  Offline OP
Probably a few FE fans on here so I'll post a few pictures. This is a 482 inch FE that I'm building with a buddy for his Galaxie. Original '67 427 side oiler block with a SCAT rotating assembly and the brand new heads from Trick Flow. We got one of the first sets of heads and have them bolted to the short block. Just waiting for some custom intake gaskets from Cometic and the engine will be ready to fire up.
DSC_1819 (Large).JPGDSC_1831 (Large).JPGDSC_1792 (Large).JPGDSC_1797 (Large).JPG
Re: New Trick Flow heads for Ford FE [Re: AndyF] #2425635
12/30/17 03:42 AM
12/30/17 03:42 AM
AndyF Offline OP
AndyF  Offline OP
The interesting thing about FE engines is that there are a ton of different intake manifolds available. And the FE intake is super complex compared to the Mopar big block which makes it weird.
Basically the aftermarket has decided to tool up a bunch of really complex low volume intakes for the FE engine while they refuse to build simple intakes for the BB Mopar. Guess they just love the FE for some reason.........
We're using a tunnel wedge intake which is kind of a cool intake but there is nothing like that available for a BB Mopar engine. The tunnel wedge will be topped off with dual throttle bodies from FAST. The ignition is also from FAST and will all be controlled by the EFI system.
Re: New Trick Flow heads for Ford FE [Re: AndyF] #2425648
12/30/17 04:12 AM
12/30/17 04:12 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
FE fan here! Looks like a very cool build.
Did you flow those heads?
Re: New Trick Flow heads for Ford FE [Re: cudadoug] #2425656
12/30/17 04:33 AM
12/30/17 04:33 AM
Granbury TX
Prochargedmopar Offline
Granbury TX
Engine rebuilder 390 FE from last weekend.
Once I get a couple other projects done I plan to add a turbo.
Gotta practice tuning this Sniper NA first though.
"Old" member Registered: Sep 2001
Lost my credentials, I'm Back!! LOL
71 Ply Satellite Procharged
73 Dodge Dart Swinger
73 Ford F-100 390/Sniper efi/back to carb
01 Town and Country Limited
08 Dodge 2500 6.7 5" Deleted
02 Mercedes C230K
19 Camry
Re: New Trick Flow heads for Ford FE [Re: AndyF] #2425702
12/30/17 11:30 AM
12/30/17 11:30 AM
jersey
Spaceman Spiff Offline
jersey
Have a buddy that's a big FE guy.
he's got a '70 mustang FE powered, 4 speed, street car. goes 10.20's. on the back window he's got a big sticker that says " Fear begins with F.E."
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: New Trick Flow heads for Ford FE [Re: AndyF] #2425718
12/30/17 12:06 PM
12/30/17 12:06 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
That is a neat build, especially with the dual EFI throttle bodies. What are you expecting it to make for HP? Is it incredibly expensive to put roller cams in FE's?
Re: New Trick Flow heads for Ford FE [Re: Spaceman Spiff] #2425721
12/30/17 12:11 PM
12/30/17 12:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Glad to see you went EFI on it
wave
Re: New Trick Flow heads for Ford FE [Re: MR_P_BODY] #2425728
12/30/17 12:29 PM
12/30/17 12:29 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I agree, the intake manifold selection is staggering for these. What do you think it will make for hp/tq? That Galaxie is a BIG car.
Re: New Trick Flow heads for Ford FE [Re: AndyF] #2425759
12/30/17 01:19 PM
12/30/17 01:19 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Do you foresee any problems with the slightly longer, taller runners on the rear cylinders like that? What's the deal with the center ridge in the floor of the intake port in the cylinder head?
[image][/image]
Re: New Trick Flow heads for Ford FE [Re: Blusmbl] #2425765
12/30/17 01:30 PM
12/30/17 01:30 PM
AndyF Offline OP
AndyF  Offline OP
I don't think it will make a ton of power, maybe 625 hp and 600 ft-lbs or something in that neighborhood. The cam is a Comp XR292R solid roller so it is decent size but not huge. Should have a bit of a lumpy idle but hopefully is driveable in the Galaxie.
I don't think it is anymore expensive to put a roller in a FE than a Mopar. Just buy the cam and the roller lifters. The Trick Flow heads only come with hyd roller springs for some reason. Trick Flow makes these heads with hyd roller springs and Ti retainers which seems like a silly combination. So we changed springs and kept the Ti retainers.
Factory FE rocker arms are 1.76 ratio so you get a lot of valve lift from fairly modest lobes.
Re: New Trick Flow heads for Ford FE [Re: MR_P_BODY] #2425768
12/30/17 01:32 PM
12/30/17 01:32 PM
AndyF Offline OP
AndyF  Offline OP
wave
I'm switching everything I own to EFI and most of my future projects will be EFI.
Re: New Trick Flow heads for Ford FE [Re: AndyF] #2425772
12/30/17 01:41 PM
12/30/17 01:41 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I've been thinking the same thing about the bb intakes lately. More head choices than ever and seems like less intake choices.
Re: New Trick Flow heads for Ford FE [Re: AndyF] #2425845
12/30/17 03:08 PM
12/30/17 03:08 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Sweet!
Now lets wait and see if Trickflow makes some heads for a Y-Block aswell.:)
As for intakemanifolds, for bb mopars, Edelbrock makes dualplane dual quads manifolds for RB motors and offenhauser makes singleplane dualquad manifolds for the B series and probably for the RB aswell but cant remeber for sure. OFFY is actualy real cool and has a bunch of oddball stuff in their catalog,check them out you might be surprised of what is available,and considering what i see on their instagram from to time it would not surprise me if they could do some oddball stuff that is not in the catalog aswell.
Totaly offtopic,i wish the smallblock mopar had some exhaustmanifolds as nice as those...
Re: New Trick Flow heads for Ford FE [Re: 1Fast340] #2425877
12/30/17 03:58 PM
12/30/17 03:58 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
First thing I thought of when I looked at the photo was that the intake is a copy of the Stage V Hemi piece. Of course my money is on the Hemi.
Sheldon
Re: New Trick Flow heads for Ford FE [Re: sgcuda] #2425895
12/30/17 04:11 PM
12/30/17 04:11 PM
jersey
jersey
i think that ridge is for pushrod tube clearance. Pushrods go through the intake on FE engines.
Re: New Trick Flow heads for Ford FE [Re: RUNCHARGER] #2425901
12/30/17 04:18 PM
12/30/17 04:18 PM
AndyF Offline OP
AndyF  Offline OP
Probably the other way around. The FE tunnel wedge intake was available over the counter from Ford back in the 60's. I don't think the Stage V dual carb single plane showed up until 40 years later.
Re: New Trick Flow heads for Ford FE [Re: Spaceman Spiff] #2425972
12/30/17 06:14 PM
12/30/17 06:14 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
That intake in the picture is NOT a tunnel wedge. My buddy has a set of those and the ports are as big as baseballs with a tube right thru the middle of them on the intake side. The heads are also very large with no tube restrictions. He said they do not really run that well because of the airflow restrictions from the big pushrod tubes.
This is still a very nice looking set up.
Old Geezer Racing
Re: New Trick Flow heads for Ford FE [Re: AndyF] #2425975
12/30/17 06:18 PM
12/30/17 06:18 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Tunnel port intake
tunnel port intake w tube thru port.jpgtunnel port intake w tube bottom view.jpg
Old Geezer Racing
Re: New Trick Flow heads for Ford FE [Re: AndyF] #2425980
12/30/17 06:25 PM
12/30/17 06:25 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I grew up working on FE Fords, I still do some BBF engines.Ford FE series engines, are literally among some of the biggest movers right now for some of the manufatures parts...its scary how many are being built right now. Cheap, easy to find, and decent bang for the buck.460 BBF is same, easy to make great power and torque, and parts ARE available.
RIP Monte Smith
Re: New Trick Flow heads for Ford FE [Re: SCATPACK 1] #2425992
12/30/17 07:13 PM
12/30/17 07:13 PM
AndyF Offline OP
AndyF  Offline OP
The intake we're using is a tunnel wedge. The intake you are talking about is a tunnel port.
Page 1 of 4 1 2 3 4
