external fuel pumps? #2424455
12/27/17 04:10 PM
12/27/17 04:10 PM
New Brunswick, Canada
TrxR Offline OP
TrxR  Offline OP
Was wondering if you could tell me if there are any common efi cars or trucks that run an external fuel pump that i could get from a junk yard. Im looking for one to make a cheap fuel transfer pump.
Re: external fuel pumps? [Re: TrxR] #2424470
12/27/17 04:23 PM
12/27/17 04:23 PM
All the early, pre 2003? dodge Ram truck diesel engines have a small external mounted Carter electric boost pump mounted low on the driver side rear engine block by the bell housing mating surface scope I bought a small electric fuel pump for my transfer pump, I don't remember the brand or price, sorry blush
Re: external fuel pumps? [Re: TrxR] #2424674
12/27/17 11:14 PM
12/27/17 11:14 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Advance Auto sells small pumps, behind the counter normally on the visibile shelves, for $60. Not sure what brand but it's basically what you're describing.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: external fuel pumps? [Re: TrxR] #2425250
12/29/17 05:05 AM
12/29/17 05:05 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
There are $20 low pressure 12v pumps on Amazon...I do not believe any EFI cars have external pumps, $20 would be worth me not getting on the ground at a junkyard, however.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: external fuel pumps? [Re: TrxR] #2425426
12/29/17 05:18 PM
12/29/17 05:18 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Just me but I'd get a transfer hose from a hardware store.
It's a simple hose (3/4"?) with a hand operated bulb to get it started.
Should do the trick a whole lot quicker than hooking up an electrical pump.
If for some reason it needs to be an electric motor, I would just get a cheap aftermarket 12 volt pump and hoses at the parts store and there you go.
I have mechanical Aptitude.
I can screw up anything.
Re: external fuel pumps? [Re: TrxR] #2425513
12/29/17 08:09 PM
12/29/17 08:09 PM
TrxR Offline OP
TrxR  Offline OP
Thanks . Ill check the local parts store.
Re: external fuel pumps? [Re: TrxR] #2425544
12/29/17 09:50 PM
12/29/17 09:50 PM
MN
58pwrwgn Offline
58pwrwgn  Offline
MN
Late 80's early 90's f150's and ford vans had an external high pressure pump. Research on rock auto, as I'm not sure if all did.
Re: external fuel pumps? [Re: 58pwrwgn] #2425610
12/30/17 02:12 AM
12/30/17 02:12 AM
Mid Michigan
Mr. Smurf Offline
Mr. Smurf  Offline
Mid Michigan
I use a old Carter a friend had laying around.....check with your friends.
Ed
Re: external fuel pumps? [Re: TrxR] #2425709
12/30/17 11:41 AM
12/30/17 11:41 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If you ebay search 12v fuel pump you will find some cheapies on there for 10 bucks shipped. I use one as a fuel transfer pump. I used to run it on my carbed jeep as the only fuel pump after the stock mechanical pump died. It ran great for years until I switched to efi and a high pressure in-tank pump.
