Leaf spring identification #2425075
12/28/17 09:48 PM
12/28/17 09:48 PM
Wisconsin
71duster414 Offline OP
Wisconsin
Can someone please tell me if there is a chart to figure out what car a leafspring stack came out of?
hoffmanhhr@gmail.com
Re: Leaf spring identification [Re: 71duster414] #2425312
12/29/17 12:56 PM
12/29/17 12:56 PM
Wisconsin
Wisconsin
Just wondering if there is a book with these numbers. Or if nothing else can someone tell me what the pictured spring is out of?
Re: Leaf spring identification [Re: 71duster414] #2425401
12/29/17 04:07 PM
12/29/17 04:07 PM
Do both springs have the same amount of leafs on both sides or are there different numbers leafs on both sides? If more leafs on one side than the other the left side(drivers side of the car) gets the most leafs on Hi Po Mopar OEM and the after market Hi Po replacement springs from Mopar up
As far as finding that spring number and its original car that it came on it is a early car by looking at the early stamp number(28------) on that leaf, probably pre 1968 confused
Re: Leaf spring identification [Re: 71duster414] #2425403
12/29/17 04:14 PM
12/29/17 04:14 PM
Andrewh Offline
Andrewh  Offline
the only reference I am aware of goes by lengths and spring count.
Tells you what cars it could be from.
someone might have the part numbers, but I have only seen the spread sheet by length and count.
Re: Leaf spring identification [Re: 71duster414] #2425404
12/29/17 04:17 PM
12/29/17 04:17 PM
A727Tflite Online content
A727Tflite  Online Content
The spring with the most leaves on the front segment always goes on the passenger side on Mopars. That's called bias control.
I'm doing a 67 Satellite right now and it has equal leave on both sides with the same part number stamped in to them. My part number is 2462005 on them - 318 automatic.
Re: Leaf spring identification [Re: 71duster414] #2425410
12/29/17 04:34 PM
12/29/17 04:34 PM
http://www.101part.net/suspension/leaf_springs/plymouth.htm
Part number for a butt load of springs, yours is in here but I don't see e MY application called out.
Re: Leaf spring identification [Re: A727Tflite] #2425429
12/29/17 05:24 PM
12/29/17 05:24 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
truck/van? shruggy how long are they?
