Re: OEM to Accel Distributor
[Re: earlymopar]
#2425398
12/29/17 03:59 PM
12/29/17 03:59 PM
Posts: 43,240 Bend,OR USA
Cab_Burge
I would make up a male jumper wire so you can remove the stock ballast resistor with the jumper and not have to mess with changing any other wiring I do that al the time when replacing a stock ECU or adding a electronic ignition to a old Mopar that doesn't require the stock ballast resistor anymore You can splice and solder the two ends together at the resistor and use heat shrink to hide it also More than one choice
[Re: earlymopar]
#2425462
12/29/17 06:57 PM
12/29/17 06:57 PM
Posts: 529 SW CO
HemiSportFury
SW CO
What appears to be the easiest is to remove the section of ballast resistor wire and replace it with a section of 14ga wire. Doing this allows the stock coil + wire as the switched source for the distributor. Anyone done it this way? - EM Yep, that's the way I do it too. Easy and leaves the wiring harness untouched.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60 '57 Belvedere 2dr sedan, current project in process '19 Cherokee Trail Hawk Elite '03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
[Re: earlymopar]
#2425500
12/29/17 07:42 PM
12/29/17 07:42 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I think someone is thinking GM
