Re: Burning oil... where do I start?
[Re: superb70]
#242522
03/04/09 12:28 AM
03/04/09 12:28 AM
Posts: 3,445 N.Wilkesboro,NC
DusterKrazy
N.Wilkesboro,NC
Go get yourself a leakdown tester and test each cyl. Leakage should be 15 percent or less. Remove the oil cap and listen for blow by. The cyl. with the most leakage by the rings is your oil burner. If you can hear air out the tail pipe you have a bad exh. valve, If you hear air out of the carb you have a bad int. valve.
Not trying to high-jack the thread here but you mentioned that if you hear air out of the carb it's a bad intake valve. Latley my 600 edelbrock carb has been whistling and the heads are pretty well worn. Could a bad intake valve be the cause of this???
[Re: da50r]
#242524
03/04/09 12:40 AM
03/04/09 12:40 AM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Valve seals are not that hard to do on the car with the heads on. Just a little time consuming, maybe three - four hours. Easy enough to do, and not going to cost a arm and a leg.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: da50r]
#242526
03/04/09 01:01 AM
03/04/09 01:01 AM
RapidRobert
What healthservices said, borrow an on engine valve spring compressor & R&R the valve stem seals(they're cheap & several hours time). considering the alternative it'd be worth the effort.
[Re: RapidRobert]
#242527
03/04/09 01:35 AM
03/04/09 01:35 AM
IF that thing only has 60,000 on the clock and hasn't turned over, it's very possible that the valve stems are the problem. It's a pain in the a$$ to change them with the heads on, but if you're patient, and keep thinking to yourself how much more work it is to pull the heads, it isn't that bad. You need an air compressor to hold the valves up, a compression gauge fitting or other lashup to get air into the cylinder, and some means to break the keepers loose. Many guys stuff rope into the plug hole to "pad" the valves from the piston. There are a couple of different compressors you can use. Mine was the hand twist deal that KD used to sell, there are others. It would be worth a try before you tear it clear down.
#242528
03/04/09 01:48 AM
03/04/09 01:48 AM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
I agree with the rings sentiment.
It may be difficult to verify it 100%
I had a 360, that had no leakdown, and good comp on all the holes. The comp was so good, it only smoked a little under load (the oil was all burnt) Upon teardown, I found the oil rings were gummed up. The comp rings were still good, which is why the tests were useless.
In any case, if the motor is as low miles as stated, just buy a rering kit(rings, bearings gaskets, seals) and tear it down at home. You can likely do the whole thing for well under 1K if you do it yourself, and don't need to machine anything. Even if you get a head shop to do a basic rebuild on the heads, and you do a scratch hone to the cylinders so the new rings will seat.
I've done it many times myself with good results, BUT you always have to be prepared for the worst. Hopefully you don't tear it down, and find a basket case.
