Re: 470 - rod length
[Re: DusterKid]
#2425073
12/28/17 09:44 PM
12/28/17 09:44 PM
Posts: 4,209 New York
polyspheric
New York
Is there anything like a consensus as to "what is the minimum compression height that gives reasonable life expectancy?" We know that you can make a piston very small by tightening the ring-to-ring vertical distance, moving the entire stack up, reducing pin diameter and boss thickness, but when is this just a ticking bomb? Do extended tangs help stability with a short rod ratio, or just add weight?
Until we know the piston is safe, the rod length has to be a compromise. Above about 1.25" CD, I'd use the longest rod I could.
Boffin Emeritus
[Re: DusterKid]
#2425097
12/28/17 10:34 PM
12/28/17 10:34 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I would talk to my preferred piston maker and go from there. I am betting though that a compression height of 1.20 or more, maybe up to 1.32 will be just fine with out much difference in performance.
[Re: DusterKid]
#2425104
12/28/17 10:48 PM
12/28/17 10:48 PM
polyspheric
New York
Goes without saying: a turbo or nitrous piston has to be bigger, top ring farther down, bigger pin.
Boffin Emeritus
[Re: DusterKid]
#2425144
12/28/17 11:38 PM
12/28/17 11:38 PM
Posts: 43,233 Bend,OR USA
Cab_Burge
The longer the rod, within reason, the less side loading into the cylinder wall, especially on stroker motors My first low deck stroker motor (pump gas)I built back in the early 2000s, was a 400 block with a 4.25 stroke and a set of CAT brand BB Chevy type rod that was 6.800 long center to center on each end. I had a set of Ross dished ppistons made to get 9.25 to 1 compression ratio on a set of iron 906 heads with 84.00 CC chambers, that motor flat rocked with those parts Those pistons with out the wrist pin or rings weighed 456 grams each Some of the nay sayers on here said it couldn't be done, but I was stupid and didn't know that it couldn't be done so I did it any ways Go long as possible on the rod length The longer rods really helps on make the pistons really light weight which helps the acceleration and deacceleration The only down side I saw was that those pistons would come out of the bottom of the bores which you could see some slight scuffing on the pistons skirts when I took it apart to put in a 4.300 stroke crankshaft later to raise the compression ratio up to 10.29 to 1 after I swapped the heads to a set of aluminum Eddy RPM heads. I couldn't measure any wear on the skirts though so no damage, no foul I have built two bracket race 400 block strokers since then one with a 4.250 stroke with a 6.700 long H beam steel rod and the other one has a 4.300 stroke crankshaft in it with the same 6.700 rod length. I have bought some used 400 stroker motor parts that included a 4.250 stroke Winberg crank with a set of Crower billet steel 1000 HP H beam rods that are 6.535 long, which I will use in the next 400 stroker motor I build
[Re: DusterKid]
#2425285
12/29/17 12:06 PM
12/29/17 12:06 PM
Posts: 1,030 ohio
67mprfan
ohio
When using a longer rod doesn't the Pistons get shorter which requires having to use a ring support rail which causes problems,
I don't know if it true just stories, and what off the shelf piston would work using the longer rods 6.700 Only asking because next build will be 470 or 512
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: 67mprfan]
#2425322
12/29/17 01:11 PM
12/29/17 01:11 PM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
with a conventional BBC .990 pin the need for a support rail for the oil ring (which in itself is no big deal) usually comes into play around 1.32"-1.30" of Compression height when using a conventional set of Top, 2nd and 3 piece oil rings, but this requirement can vary widely simply by the design, width and center to center spacing between the ring packs.
Shorter rod ratios and higher pin placements tend to incurr more piston "rock" at TDC and BDC which puts more emphasis on block rigidity and skirt design to maintain good seal and longevity. On a street motor with moderate peak torque and HP RPM targets it's really not a deal breaker but on higher RPM race motors you can get to a point where you might consider sacrificing stroke to gain RPM depending on the combination. the 470" is a great race engine, it's 10% smaller displacement than a 511 but with the right combo you can trade off the cubes for a 10% higher rev cieling and make the same HP, but on the street with mid 3 gears and a street converter (designed to use and not side step the abundant low-mid range torque) the 511 is a great way to go.
Maybe some of us "over-think" it in practical terms, particularly when you consider bowtie guys routinely put 4.25" cranks with only 6.135" rods in standard 454 chevy blocks with only 9.80" deck blocks, some of them use "long" 6.20-6.3" 'Hybrid' BBC width/SBC rods with 2.100" journals and .927" SBC pins.
[Re: DusterKid]
#2425511
12/29/17 08:07 PM
12/29/17 08:07 PM
Thumperdart
State of confusion
When doing a 470 stroker in a 400 block I noticed a 6.70 or 6.535 rod can be used. Is there an advantage to using one over the other? FWIW, I run Chevy Eagle 6.385's in my heap.........
[Re: sr440]
#2426961
01/01/18 07:27 AM
01/01/18 07:27 AM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
If you haven't run both rods in both combos...... how can you make an informed comment? I’m going to tell you this, you won’t find 5hp difference between the two different rod lengths. Build the most common combo 6.385” rod and you won’t be disappointed.
[Re: Biginchmopar]
#2426968
01/01/18 08:18 AM
01/01/18 08:18 AM
Posts: 14 Sydney Australia
sr440
Sydney Australia
If you haven't run both rods in both combos...... how can you make an informed comment? I’m going to tell you this, you won’t find 5hp difference between the two different rod lengths. Build the most common combo 6.385” rod and you won’t be disappointed. Have you actually checked?..... If there is less than 5hp difference (disregarding wear & reliability issues) How can you promote one over the other?...
[Re: sr440]
#2427103
01/01/18 02:47 PM
01/01/18 02:47 PM
Posts: 31,050 Oregon
AndyF
If you haven't run both rods in both combos...... how can you make an informed comment? Lots and lots of people have run short rod vs. long rod tests over time. The general consensus is that it doesn't matter most of the time. The OP didn't tell us much about the engine he wanted to build but it is doubtful that he is a serious professional since if he was then he wouldn't need to ask that question on a web forum. About the only place I know of where people worry about rod ratio is some circle track engines. Even there, some drivers like short rod engines to get them out of the corner while other like long rod engines for the straights. So I'm not sure there is even a consensus about which to use. Personally I use a longer rod whenever I can just because I like to keep the piston away from the crankshaft. Other guys like short rods and they seem to do just fine. For the average guy the advice I gave earlier in the thread should cover it. That is, just pick the piston you want to use and then buy the rod that connects that piston to the crank. You don't need to put anymore time into it than that.
