Safety questions on stock braking systems
#2424412
12/27/17 03:22 PM
12/27/17 03:22 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
A Friend of mine on Facebook was looking for the oring that holds the stock brake rod into the master cylinder and it brought up a safety issues I remember hearing about. Didn’t a few guys have issues with the brake rod popping out and guys losing their brakes. Seems I remember some guys were putting a mechanical stop on the pedal to prevent this from happening. Does anyone have more info on this subject. Thanks
Re: Safety questions on stock braking systems
[Re: pittsburghracer]
#2424441
12/27/17 03:56 PM
12/27/17 03:56 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I put a stop on both of my cars.. I ended up using a 3/8 push rod cut to length.. I have to take the pedal off to get the rod out.. never had any issues
#2424442
12/27/17 03:57 PM
12/27/17 03:57 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
In stock configuration, the brake light switch is the up stop, once it's removed a mechanical stop is needed.
[Re: John_Kunkel]
#2424446
12/27/17 04:01 PM
12/27/17 04:01 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thanks guys. I thought my old brain remembered reading about an issue with this. I will check our cars out over the Winter
#2424448
12/27/17 04:03 PM
12/27/17 04:03 PM
Posts: 7,495 Minnesota
Hemi_Joel
Minnesota
I was at the Mopar Nats when a Dart had the pushrod drop out and the poor driver had zero brakes. He hit the gravel trap at high speed. It looked like the car was severely damaged, maybe totaled. From that moment on, I have considered a positive stop to limit the upward travel of the pedal 100% essential.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2424456
12/27/17 04:10 PM
12/27/17 04:10 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
It sounds like a good winter project for all of us to take a peek at. A diaper may be another wise investment to help keep the shinny paint shinny and the driver safe too. I know I won’t race without one now.
#2424467
12/27/17 04:21 PM
12/27/17 04:21 PM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
I did the same thing a few years ago with my car. My foot hit the brake pedal coming off of the gas and the rod popped right out. Talk about a tight butt moment. I was just driving around the block so I got it stopped but it sure scared the heck out of me. Made me a believer in a stop..
6.50 @105.26
[Re: Kindafast]
#2424481
12/27/17 04:40 PM
12/27/17 04:40 PM
Posts: 428 Mountain City, TN
JesseR
Mountain City, TN
This very thing happened to me 2 seasons ago. I hadn’t looked under my dash in years, I did my burnout and pre staged the truck, put it in neutral and cleaned the motor out. I was having an issue with my throttle springs not quite letting the carb back down to idle. I pulled the gas pedal up a touch with my foot and I believe I hooked the brake pedal moving my foot out from behind the gas pedal. I had no idea that the brake rod popped out until I went to the lights at 150, I was in no hurry to jump on the brakes because I shut the motor down to check the plugs. Bristol has an extremely long shut down. I hopped on the brake pedal and it went to the floor, I dumped the chute and got slowed to around 60mph Before I hit the safety net, terrible learning experience. My truck now has a Wilwood dual master cylinder set up on it. It was a very expensive lesson learned. The only thing that keeps the brake pedal coming up too far is a plastic bracket that held the light switch.
82' dodge pickup with a 499 low deck
[Re: Kindafast]
#2424485
12/27/17 04:46 PM
12/27/17 04:46 PM
RapidRobert
I compared the tailor made snip of black rubber or neoprene that came with a MC at the parts house & it was identical to a piece of common black rubber vacuum hose off of their hose reel except for a shallow groove along the length of it I'm assuming for air to excape so it can go all the way down into the bottom of the piston recess & lock in solid. I've went that route several times & it has always stayed locked in their super tight. It does require that the rear piston tapered "thimble" recess has the circular shallow groove about halfway down the barrel for this piece to lock into. Power brakes can use a MC with a recess or no recess (of the right bore of course) but manual brakes require it if useing the snip of rubber or use some other method of retaining the pushrod as mentioned. Ehrenberg even used some RTV to lock the pushrod down in there on a piston without the circular groove. I have yet to try that!
[Re: JesseR]
#2424495
12/27/17 05:12 PM
12/27/17 05:12 PM
Posts: 43,233 Bend,OR USA
Cab_Burge
All the stock Mopar M.C. from the early 1960s came with the rubber retainer on the tip of the rod so it will not come out of the piston without a lot of effort, they don't just fall out That being said I replace the original master cylinder in my old 1070 Bracket Duster and didn't replace the rubber retainer on the rod with a new one, I had tore the old one up pretty badly prying the rod out of the piston so I discarded it through ignorance That car still had the stock brake light switch and bracket on the pedal assembly, I had worked on the cars sixty foot times enough to finally make the swinging pedal weight bend the brake light bracket back far enough for it to slide the rod out and hang straight down off of the stock bolt resulting in no brakes Luckily I was at LACR which has a big uphill long shut down area so by down shifting and swerving the car around to scrub speed (it would run right at 130 MPH in the 1/4 mile back then) off I made the last turn off safely Be safe, make sure you can stop safely all the time Happy New Year to All
#2424523
12/27/17 06:27 PM
12/27/17 06:27 PM
Posts: 11,621 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I have seen so many cars wrecked and torn up because of this, I've lost count. Nice cars, not hacked together junk. Seems like at least one every year and I've been doing this since the 70s. Not just Mopars. All kinds and flavors of race cars into the net or the wall. I always use multiple redundant methods to prevent this on anything I'm involved with. The OE O-ring is OK, but is often lost, ruined or just not used or there is an aftermarket pushrod used that is not cut for the ring. Brake light switches are often plastic, flimsy or missing. At a minimum, I use a positive mechanical stop on the pedal to limit movement coming back up to a point where there is just some freeplay at the MC. In addition to that, I use a mechanical retainer on the pushrod itself or a kit made just for this. This one is sold by various chassis supply places. I've also done something as simple as fabing up a cup or strap, which is captured between the MC and firewall or mount, to cover the MC bore with a small hole in it for the pushrod. Then weld a washer on the pushrod or cut a groove and use an e-clip to capture the pushrod under the retainer. There just has to be something on there to keep the brake pedal/MC linkage from falling apart.
[Re: RapidRobert]
#2424638
12/27/17 10:08 PM
12/27/17 10:08 PM
Posts: 9,860 MI, usa
dvw
MI, usa
I compared the tailor made snip of black rubber or neoprene that came with a MC at the parts house & it was identical to a piece of common black rubber vacuum hose off of their hose reel except for a shallow groove along the length of it I'm assuming for air to excape so it can go all the way down into the bottom of the piston recess & lock in solid. I've went that route several times & it has always stayed locked in their super tight. It does require that the rear piston tapered "thimble" recess has the circular shallow groove about halfway down the barrel for this piece to lock into. Power brakes can use a MC with a recess or no recess (of the right bore of course) but manual brakes require it if useing the snip of rubber or use some other method of retaining the pushrod as mentioned. Ehrenberg even used some RTV to lock the pushrod down in there on a piston without the circular groove. I have yet to try that! I have used a piece of vacuum line as well, works fine. I'm here to tell you the stop lamp switch isn't good enough. Seen it first hand, not good. Mine also has a positive stop. And while we're on the subject a screw style hose clamp below the steering column U mount (it only has a small sheet metal tab). This will stop the column from sliding up out of the fire wall grommet. Yank on the wheel hard enough and you can pull the stock steering coupler apart. I watched it happen on a friends car, not good. Doug
#2424740
12/28/17 01:46 AM
12/28/17 01:46 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
If you need the little rubber bushing, Doctor Diff has them.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#2424742
12/28/17 01:51 AM
12/28/17 01:51 AM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If you need the little rubber bushing, Doctor Diff has them. That's how this started off today. A friend on Facebook was needing one and I recommended Mancini Racing or possibly even Ace Hardware but then I told him about this safety issues. It sounds like a good time for all of us to take a peek at our set-ups.
#2424798
12/28/17 10:07 AM
12/28/17 10:07 AM
JesseR
Mountain City, TN
Yes, it is a good time to check those brake pedals out. I’ve learned a valuable lesson on this subject, if it can fall out, it will fall out. Don’t assume, since it’s never been an issue, that it’s ok, like I did
