Re: Cold air in a WO23 scoop
[Re: Hemi ragtop]
#2423712
12/25/17 08:21 PM
12/25/17 08:21 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I need to do something like that for my Hemi, I was going to use the metal aircleaner base to make a fiberglass one then use it to modify for my Holley carbs. Another project on the list of TODO's
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: A727Tflite]
#2423761
12/25/17 10:42 PM
12/25/17 10:42 PM
Posts: 2,463 Sydney,Australia
tex013
Sydney,Australia
Please explain - "the only factory system with a seal to the air cleaner".
Not getting it either . Didnt the race/scoop setups use a cross ram with velocity stacks sealed to underside of bonnet cut oyt holes ? Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2423789
12/26/17 12:15 AM
12/26/17 12:15 AM
Posts: 984 Tennessee
Hemi ragtop
Tennessee
Not getting it either . Didnt the race/scoop setups use a cross ram with velocity stacks sealed to underside of bonnet cut oyt holes ? Tex The factory WO/RO 23 system used an aluminum plate the required cutting essentially all of the hood bracing out, indeed, it didn't have any provision for an air cleaner, race only, no good for a street car.
[Re: Hemi ragtop]
#2423826
12/26/17 02:25 AM
12/26/17 02:25 AM
Posts: 1,505 TN
SCATPACK 1
TN
I like the finished product. Pretty neat.
Old Geezer Racing
[Re: Hemi ragtop]
#2423956
12/26/17 05:08 PM
12/26/17 05:08 PM
astjp2
Utah and Alaska
I would like to see the modifications to fit the carbs with the base. I have to do something similar with my Hemi with the stageV intake and Holleys. Tim
[Re: astjp2]
#2424104
12/26/17 09:42 PM
12/26/17 09:42 PM
Posts: 1,505 TN
SCATPACK 1
TN
I would like to see the modifications to fit the carbs with the base. I have to do something similar with my Hemi with the stageV intake and Holleys. Tim Tim Look at the first post at the top of the page. The second shot clearly shows his mod to the carb plate to get it to work with the Holleys.
Old Geezer Racing
[Re: Hemi ragtop]
#2424105
12/26/17 09:44 PM
12/26/17 09:44 PM
Posts: 1,505 TN
SCATPACK 1
TN
I have one more day off and am spending it wisely. Here I am building a mock up of the "A12 wall". This will be recreated in 18 gauge steel and welded in place. The rubber seal goes on the top lip. I need to give credit to Tommy theChryco. He had the best deal on the parts and made sure I had them before my Christmas break. I assume you are making the "wall" out of some sort of high density foam to seal to the hood and allow some flex for engine movement and still stay sealed up.
Old Geezer Racing
