Re: Cold air in a WO23 scoop
[Re: Hemi ragtop]
#2424703
12/28/17 12:19 AM
12/28/17 12:19 AM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
Awesome! Keep those pics coming!
[Re: Hemi ragtop]
#2424980
12/28/17 05:20 PM
12/28/17 05:20 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Ok, why did you trim the lip by where it meets the carb flange? I need to do this mod on mine but I have been hesitant to just cut on a $600 air cleaner base..
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Hemi ragtop]
#2425414
12/29/17 04:42 PM
12/29/17 04:42 PM
astjp2
Utah and Alaska
Well I have shrinkers/stretchers for 2 different models, that hand one is a lot harder to use than one with a foot pedal. The foot pedal one allows for 2 hands, and if you are on a stool, you don't loose too much balance.
It looks like you are really getting a handle on it.
Do your carbs have vacuum secondaries or are they double pumpers? Keep up the good work. Tim
[Re: Hemi ragtop]
#2425546
12/29/17 10:03 PM
12/29/17 10:03 PM
Posts: 1,111 Usa
A39Coronet
Usa
I also need to always have a project to work on, especially during this time of year. So, just thought you guys might be interested. I hear you on that...plus no excuse to rush making things during the winter and you can take your time to make it right. Looking forward to the finished product.
[Re: Hemi ragtop]
#2425596
12/30/17 01:24 AM
12/30/17 01:24 AM
astjp2
Utah and Alaska
Leave an edge on the base that is 1/4-3/8, then roll it up, you will get a good lap weld. Even if you only leave the straight sides, it gives you some sort of edge to weld to. Tim
[Re: Hemi ragtop]
#2426149
12/31/17 01:27 AM
12/31/17 01:27 AM
Posts: 984 Tennessee
Hemi ragtop
Tennessee
Well, with the front done, all that remains is to match the radius's in the rear, and hit the overall length. A cardboard template does the trick!
[Re: Hemi ragtop]
#2426158
12/31/17 01:50 AM
12/31/17 01:50 AM
astjp2
Utah and Alaska
It looks awesome, if you are good with a torch, you may want to try silver brazing. Its low heat and is 60k psi tensile strength. I am not a fan of mig for real precise work. What are you going to use for a seal to the hood? I have some rubber product that is 3" wide and come is a roll that you could fasten...or look for a P seal http://www.brownaircraft.com/product-p/t-6400.htmTim
