Thermoquad question
#242347
03/03/09 08:39 PM
03/03/09 08:39 PM
hey guys, came over from the slantsix.org site. Upsizing my B Body to a '72 340 automatic.
there is a thermoquad 9203s available on ebay. manual says that model was for a 79-80 345 auto/IHC
will this carb work well on my 340?
thanks so much for your input
Keni
Re: Thermoquad question
#242348
03/03/09 08:51 PM
03/03/09 08:51 PM
RapidRobert
welcome here. I'd contact demonsizzler on this site
[Re: RapidRobert]
#242349
03/03/09 09:01 PM
03/03/09 09:01 PM
Posts: 565 IA
landon1
IA
i don't think you want that carb...you should try to get a 71 or 72 carb (pre-smog emissions) or try and hunt down a superquad (aftermarket TQ)- that's the route i was going to try, because of the electric choke feature, then you don't need the correct intake
'71 Satellite Sebring 440
[Re: landon1]
#242350
03/03/09 09:56 PM
03/03/09 09:56 PM
DaytonaTurbo
Manitoba, Canada
If you want to find one you can rebuild yourself and run, find one of the 6000 series, ie the first number is a 6, the other 3 are anything else. The 9000 series are the smogger carbs, which would need some rejetting and other mods before being good to use. The Vaanth Thermoquad Guide has all the numbers you need to see: http://members.shaw.ca/crussel/thermoquad/tqguide.html
#242351
03/03/09 11:11 PM
03/03/09 11:11 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
That carb is for the International Harvester 345 engine. I may actually have one of those. It won't work linkage wise on a Mopar. I'll be up early tomorrow. Give me a call. BTW you don't want a '71 model 340 carb.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: cdp]
#242356
03/04/09 10:35 PM
03/04/09 10:35 PM
Posts: 8,237 fredericksburg,va
cudaman1969
fredericksburg,va
71 carbs are not the way to go, hard to find, and backwards from 72 and up. 72 to 74 or 75 where the best because of the fuel inlet pos. and not all the add on emmision crap. the trap door is the secret to making these work right. there where to types, get the larger front barrels,440 cars, jury rig a choke and keep working with the rods and plunger springs, depends on the vacuum at idle,i.e. cam, good luck
[Re: cudaman1969]
#242357
03/05/09 01:57 AM
03/05/09 01:57 AM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
The TRAP DOOR ? ... now that is a NEW TERM that most have not heard of !! .... Would that be the secondary air valve ? ... well do I have the TOOL for you ! ..... and it is new and improved from the OEM piece.
That is a major consideration ... but there is a little more to be concerned with than just that.
[Re: CJK440]
#242359
03/05/09 10:24 AM
03/05/09 10:24 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Really??
The Comp series TQ's are not legal for F.A.S.T. and if I remember correctly has some pretty significant visual differences too.
Right, I haven't heard that one either.
But in thinking about it, I do see guys running different TQ part#'s other than what's production line correct for thier cars and nobody seems to give them any flack over it, I don't see why they couldn't use a Comp carb just as easily?
They do have some obvious differences, but most aren't visible with the air cleaner on, where do you draw the line when NEITHER carb is correct?
[Re: ScottSmith_Harms]
#242360
03/05/09 10:31 AM
03/05/09 10:31 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
The numbers don't matter in FAST. A 73 340 TQ can be put on a 72 340 car.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
#242362
03/05/09 11:09 AM
03/05/09 11:09 AM
CJK440
Ansonia, CT
I do agree there is some gray area with the way the FAST rules read. When we revised the rules for Supercars we opened up the carb rule to eliminate confusion. You can run any carb as long as it appears externally similar as the OE peice. To meet FAST rules I had to take an 800 TQ and machine it to accept 850 throttle plates. In Supercars I could just go find a similar appearing 850 and plop it on. The good news for Mopar guys is the cars that left the factory with a 625 with a little cosmetic work, can take advantage of Edelbrocks line of larger AFB's and AVS's and be competitive now in this series.
#242364
03/08/09 10:40 PM
03/08/09 10:40 PM
"If you want to find one you can rebuild yourself and run, find one of the 6000 series, ie the first number is a 6, the other 3 are anything else.... The Vaanth Thermoquad Guide has all the numbers you need to see:"
OK with TQ guide in hand here's what i have found that I think would work:
-6139S is for a '72 340 automatic (needs a rebuild). -6324 is for a 73 HP 440 automatic (newly rebuilt) -6090 for a 72 400 auto (newly rebuilt) **4968 Carter AVS for a 71 HP440 auto (newly rebuilt)
will any of these other carbs work well on my 340 ? Will a carb for a 440 HP be too much?
sure appreciate all your feedback. I could talk all day about slant sixs and super sixs. But this muscle world is all new to me!
Keni
