Anyone identify this crankshaft balancer?
#2423277
12/24/17 08:45 PM
12/24/17 08:45 PM
Posts: 4,283 Florida
blewbyu
Trying to figure out if this is a six pack balancer or a cast crank balancer what do you think?
Re: Anyone identify this crankshaft balancer?
[Re: blewbyu]
#2423278
12/24/17 08:47 PM
12/24/17 08:47 PM
Posts: 6,416 Abilene, Texas
fastmark
Abilene, Texas
Looks to be a lot thicker on the offset than a heavy rod 70-71 motor.
[Re: NachoRT74]
#2423534
12/25/17 01:18 PM
12/25/17 01:18 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Those guys in that thread can't manage to figure out if the rear end is an 8 3/4, an 8 1/4 or a 7 1/4, I would not trust them to know if water was wet.
[Re: blewbyu]
#2424577
12/27/17 07:57 PM
12/27/17 07:57 PM
Posts: 1,142 Tucson, AZ
cruzin
Tucson, AZ
There should be a part number stamped on it. They are difficult to see / find. BTW, 440Source has an excellent damper-balancer info page ( www.440source.com/dampers.htm) with part numbers ...
[Re: blewbyu]
#2424650
12/27/17 10:42 PM
12/27/17 10:42 PM
RapidRobert
I can go check one of my 360 LA balancers tomorrow but at first thought the counterweight does not look like what I am remembering.
[Re: blewbyu]
#2425265
12/29/17 09:55 AM
12/29/17 09:55 AM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
Defiantly not a 6pak balancer
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
