headlight bulb replacement 01 2500 #2421996
12/21/17 08:11 PM
12/21/17 08:11 PM
Calgary, Alberta Canada
a12rag Offline OP
a12rag  Offline OP
Anyone have any short cuts, tips to replace the low beam bulb on the 01 Ram 2500 or 3500 trucks ?? Seems like so much work to remove battery, battery tray, etc, to get to the lower beam bulb . . . tips/comments are welcome . . .
Thanks,
Mark
Re: headlight bulb replacement 01 2500 [Re: a12rag] #2422338
12/22/17 03:59 PM
12/22/17 03:59 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Youtube is your friend.
Re: headlight bulb replacement 01 2500 [Re: a12rag] #2422390
12/22/17 06:19 PM
12/22/17 06:19 PM
a12rag Offline OP
a12rag  Offline OP
Think it might be easier to just remove the whole headlight assembly . . .
Re: headlight bulb replacement 01 2500 [Re: a12rag] #2422803
12/23/17 09:11 PM
12/23/17 09:11 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I got my hand down in there but it was real tight. Pulling the whole light seemed like a pain.
Re: headlight bulb replacement 01 2500 [Re: a12rag] #2422995
12/24/17 03:40 AM
12/24/17 03:40 AM
a12rag Offline OP
a12rag  Offline OP
I got my hand down there too . . . maybe my mitts are too big ??? Just no way to get the bulb in properly, and then get the locking ring to lock . . . .
Re: headlight bulb replacement 01 2500 [Re: a12rag] #2423210
12/24/17 06:47 PM
12/24/17 06:47 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Have a friend with a small hand?
Re: headlight bulb replacement 01 2500 [Re: a12rag] #2431953
01/10/18 12:09 AM
01/10/18 12:09 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
small hands for that job... headlight assy removal requires the bumper to be tipped down (really hard on some rust belt trucks). I recently added some small led lights in the lower bumper and wired them in with the fog lamps. Made driving at night a whole new experience. Best $30 I've spent in awhile!
Re: headlight bulb replacement 01 2500 [Re: a12rag] #2433735
01/13/18 02:20 AM
01/13/18 02:20 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
On a 1500 series truck you can remove the entire headlight in less than 10 minutes; 3 or 4 screws. Seems much easier to me than removing the battery and battery tray. Is there a difference in the 2500 headlights? EDIT: A friend with a small hand (as suggested) would be even easier...
Re: headlight bulb replacement 01 2500 [Re: a12rag] #2434079
01/13/18 08:41 PM
01/13/18 08:41 PM
a12rag Offline OP
a12rag  Offline OP
Don't think there is difference between 1500 and 2500 . . . just the added battery, etc, on the 2500 cummins . . .
