SB to BB .904 Roller Lifter interchangability question #2423173
12/24/17 05:35 PM
12/24/17 05:35 PM
Weddington, N.C.
Streetwize Offline OP
Weddington, N.C.
I'm thinking about switching to a solid roller from a HR in one of my BB motors.
I have a like new (maybe 10 passes) of the Morel Small block solid lifters I ran approx 7200RPM in my 414 and I think other than the small blocks having a V notch in the link bar they are the same lifter. I test fitted a couple pairs in an old 440 I have and they seem to clear fine even at the extreme of the link bar travel. I know you can't put the straight link bar BB style in a small block (since the valley has little nubs sticking up) but it seems there would be no problem at all going the other way from SB to BB. And AMC's I believe are the same as BB (straight link) as well except AMC's pressure feed the rockers through the pushrods and have a bleed hole in the lifter cup for that purpose.
The Morels have a long (HR style) body so when I ran it on the smallblock I had to use a much shorter pushrod, But on an RB the longer body might actually be an advantage.
Am I off base? I's there another difference I am not aware of?
I posted on Q&A but this is probably whereI'll get a quicker answer
WIZE
In Car:
Re: SB to BB .904 Roller Lifter interchangability question [Re: Streetwize] #2423292
12/24/17 09:35 PM
12/24/17 09:35 PM
If they fit and check okay I would run them up
Re: SB to BB .904 Roller Lifter interchangability question [Re: Streetwize] #2423324
12/24/17 10:35 PM
12/24/17 10:35 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
I don't know what the lifter center to center on a small block is: (BB=1.800)might want to check that......
Re: SB to BB .904 Roller Lifter interchangability question [Re: boatracer572] #2423372
12/25/17 12:55 AM
12/25/17 12:55 AM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
iagree
Don't assume the tie bars have enough spacing. I test fitted a set of SB rollers I have in a BB and it didn't look like they'd work because of it.
Re: SB to BB .904 Roller Lifter interchangability question [Re: @#$%&*!] #2423389
12/25/17 01:24 AM
12/25/17 01:24 AM
Weddington, N.C.
Weddington, N.C.
I set the small block set in a big block looks to me there's plenty of free movement.
WIZE
In Car:
