BB oil pump mounting bolts, locks or not? #242253
03/03/09 07:22 PM
03/03/09 07:22 PM
California
70SportSatellite Offline OP
super street
super street
California
Should the 4 oil pump mounting bolts have lock washers or not? thanks.
Re: BB oil pump mounting bolts, locks or not? [Re: 70SportSatellite] #242254
03/03/09 07:38 PM
03/03/09 07:38 PM
Carson City, NV
440sourcedotcom Offline
Carson City, NV
Yes, they came with split lock washers from the factory.
Re: BB oil pump mounting bolts, locks or not? [Re: 70SportSatellite] #242255
03/03/09 07:41 PM
03/03/09 07:41 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
If you look in the 69 Plymouth Sevice Manual under 426 Engines at the end of the engine section, there's a diagram that shows bolts and washers for all the oil pump bolts and cover bolts. They should be grade 8 lock washers as far as I know. It will be the same for all BB's.
Re: BB oil pump mounting bolts, locks or not? [Re: 70SportSatellite] #242256
03/04/09 10:57 AM
03/04/09 10:57 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Just an FYI if you are switching to a HI VOLUME PUMP you need LONGER bolts ...
