Re: Looking for advise on 413 head swap 65 crew cab Power wagon!
[Re: RUMBLON]
#2422565
12/23/17 03:05 AM
12/23/17 03:05 AM
Posts: 20,630 in a cattle trailer down by th...
Guitar Jones
I love it. The top end swap shouldn't be too bad. The power steering will certainly be something else though. Good luck with that.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: RUMBLON]
#2422716
12/23/17 05:31 PM
12/23/17 05:31 PM
Posts: 2,105 Byron, NY
W.I.N. Racing
Byron, NY
Looks like a "Truck/Industrial" motor (as in not passenger car/PU)Im not certain but I don't think its as easy as a upper end change over... Ramchargercentrail
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#2422886
12/23/17 11:27 PM
12/23/17 11:27 PM
Posts: 20 Canada
Chris Johnson
Canada
Looks like a "Truck/Industrial" motor (as in not passenger car/PU)Im not certain but I don't think its as easy as a upper end change over... Ramchargercentrail For sure it is a truck/industrial 413. I have one that I rebuilt .030" over and put it in a Dakota with the industrial heads and all. I too want to eventually swap over to 452 or 906 heads, but haven't had the time. The 413's are still just an RB block so "normal" heads and water pumps will mount to them. Just be aware that these are low compression motors with dish pistons so putting on 906 heads will lower your compression ratio, that way I wanted to go 452 closed chamber heads to help offset that. My 413:
[Re: RUMBLON]
#2423106
12/24/17 02:56 PM
12/24/17 02:56 PM
Posts: 8,481 Candler,NC / Myrtle Beach, SC
JDMopar
452 heads might work better for what you want. Same ports as 906's, but if I remember right....they have hardened valve seats. The PS might be the harder issue to remedy. I had a 70 model D200 2wd truck, that had PS. The steering box was about as big as your fist, and it had this thing that looked like a shock with 10 PS lines hood to the drag link. I don't know if 4wd trucks have the same setup or not? The PS was the only reason I sold that truck. It leaked like a sieve, and had about a half a round of slack....and I couldn't find any parts to fix it. Looks like a nice old more door truck to fix up....so good luck!
[Re: Chris Johnson]
#2423834
12/26/17 05:00 AM
12/26/17 05:00 AM
Posts: 43,126 Bend,OR USA
Cab_Burge
Not trying to hijack this thread but I'm putting a 440 motor together for customer who will install it in a 1972/76 era W200 4x4 that ended up with a rear sump truck or Class a motor home oil pan with the external dipstick tube and dipstick and I don't have any idea what the oil capacity is, can any of you help me on this Thanks in advance OP, that motor is NOT out of Imperial, it is a truck, motor home or industrial 413 motor I'm starting to put one of those motors using block and crankshaft only with the crankshaft offset ground down to 2.200 and increasing the stroke to 3.91 It's getting hot tanked and magnafluxed now and if it passes and has no cracks I will have it bored to 4.250 and make a pump gas motor with a set of 440 Source aluminum heads on it for my 1963 Plymouth Fury
[Re: Cab_Burge]
#2424327
12/27/17 12:23 PM
12/27/17 12:23 PM
Posts: 3,136 Palm Coast, FL (near Daytona B...
Blown_Hemi
Not trying to hijack this thread but I'm putting a 440 motor together for customer who will install it in a 1972/76 era W200 4x4 that ended up with a rear sump truck or Class a motor home oil pan with the external dipstick tube and dipstick and I don't have any idea what the oil capacity is, can any of you help me on this Thanks in advance OP, that motor is NOT out of Imperial, it is a truck, motor home or industrial 413 motor I'm starting to put one of those motors using block and crankshaft only with the crankshaft offset ground down to 2.200 and increasing the stroke to 3.91 It's getting hot tanked and magnafluxed now and if it passes and has no cracks I will have it bored to 4.250 and make a pump gas motor with a set of 440 Source aluminum heads on it for my 1963 Plymouth Fury Should be a 6 quart pan. Here is what I did when I needed to install the bung for the external dipstick on my Milodon 8 quart pan. Filled pan with 8 quarts of water and measured the water level from pan rail, marked dip stick tube at the full level and marked where bung needed to be welded in.
Ask me my opinion of Frank Mitchell....... A Mopar crook!
[Re: Blown_Hemi]
#2424462
12/27/17 04:18 PM
12/27/17 04:18 PM
Cab_Burge
I'm not sure if this pan is a 440 motor home pan or a 413 truck pan I called one of the local auto repair shops that has a on line subscription to either Mitchells or motor manual information, he found that the 440 motor home pan hold 6 quarts and the 413 motor homes and trucks hold 8 quarts Thanks for your help
