Ideas on sealing header bolt?
#2422126
12/22/17 12:35 AM
12/22/17 12:35 AM
Posts: 370 Suffolk County, New York
1mean340
Ever since I fired this new motor up with the w2 econo heads I've been having issues with the passenger rear header bolt leaking coolant. At first, it was trickling out a little bit when I used ARP thread sealant. I put it back in using copper RTV instead and I had no more wetness/dripping on the outside, but I was still getting occasional little puffs of white smoke out from around that primary almost as if it was leaking inside of primary. I pulled the header gasket out and it looks like it was wet all around the bolt and possibly caused the gasket to leak where the antifreeze softened it (which would explain the smoke trails).
Not really sure what to use at this point, anything thicker/more durable than RTV? Never had this issue before, and even the front header bolt which is also a wet hole never has any issues with just using the Arp sealant.. No cracks I can see around the port or bolt area, just seems like it's pushing out the threads. Could excessive pressure in the coolant system cause this? Compression test showed all cylinders within 5 psi of eachother but haven't done a leakdown yet.
Thanks!
Re: Ideas on sealing header bolt?
[Re: 1mean340]
#2422145
12/22/17 01:08 AM
12/22/17 01:08 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I use the silver solder,same results as the Bars Leak.No header gasket just high temp RTV.
[Re: humpty]
#2422146
12/22/17 01:09 AM
12/22/17 01:09 AM
Posts: 20,169 PA.
pittsburghracer
"Little"John
"Little"John
PA.
An old pipefiter taught me a trick. Use Teflon tape making sure you put the tape on right so it gets tighter as you screw it in but then he would wipe a light coat of Teflon pipe dope on the tape. Works for me but I also use a stud whenever possible which really seems to help. I just hope your W2 Head isn’t cracked like mine was
[Re: pittsburghracer]
#2422193
12/22/17 03:14 AM
12/22/17 03:14 AM
RapidRobert
I also use a stud whenever possible that is what I would do, is get a regular OE type fine/coarse double end shouldered stud. You can shorten the outer fine thread end so only enough remains so when the nut is torqued, it is flush with the end of the stud as any more is a waste & hampers header fitment over the stud. & use some viscous sealer on the threads that go into the head.
[Re: 1mean340]
#2422530
12/23/17 12:56 AM
12/23/17 12:56 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Indian head / aviation sealant on a stud.
[Re: MR_P_BODY]
#2422626
12/23/17 12:36 PM
12/23/17 12:36 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I use a can of Bars Leak in all my builds... it should stop it I use the bars with a copper flake. Also have had really good results with alumaseal powder...🤘
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: 1mean340]
#2422943
12/24/17 01:15 AM
12/24/17 01:15 AM
Posts: 7,506 Az
Crizila
Az
Stud it with good ole hardening permatex.
Fastest 300
