What went wrong pushrod in int port? #2421533
12/20/17 06:33 PM
12/20/17 06:33 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I was reading in this about the FE engine having in port push rods in the D shape intake.I suggested this idea to Koffels for in there PSO head on their dragster.I did not read the full article but I think this really interesting.
http://www.hotrod.com/articles/unlimited-rat-motor-racing/
Re: What went wrong pushrod in int port? [Re: Clanton] #2421602
12/20/17 09:33 PM
12/20/17 09:33 PM
Cab_Burge Online work
Cab_Burge  Online Work
I know a SO CA SS drag racer that had one of the special lightweight 1966 R code(? confused) 410 HP 4 speed Fairlaines that he raced in SS/C and later in SS/B. He ended up swapping heads on that motor over the years several times going from the original medium riser single four barrel combination to the high rise heads with the factory dual inline 735 CFM Holley carbs and again to the tunnel port heads and intake, the car ran faster with the high riser heads than it did with the tunnel port heads and intake shock He worked for Valley Head Service at the time, he was the machine shop manager and found out that the pushrod casting in the tunnel ports heads restricted the head flow enough so the other heads flowed better, this was in the mid to late 1970s shruggy
Siamese intake and exhaust ports are not the best way to make power on any race engine tsk
Re: What went wrong pushrod in int port? [Re: Clanton] #2421677
12/21/17 12:01 AM
12/21/17 12:01 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I will have to search for some pics to see if the air went around it 360 or just 1 side[1/2] on the push rod tube in the intake port.
Re: What went wrong pushrod in int port? [Re: Clanton] #2421681
12/21/17 12:11 AM
12/21/17 12:11 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
The 427 Tunnel Port heads aren't that uncommon.
It's the 302 TP heads that are seldom seen, a pal of mine had a set.
Air flows 360* around the push rod "sleeve". IIRC, the "sleeve" went thru the 427's intake and thru the head on the 302.
Re: What went wrong pushrod in int port? [Re: Clanton] #2421683
12/21/17 12:21 AM
12/21/17 12:21 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I got this pic off FE....com
Re: What went wrong pushrod in int port? [Re: Clanton] #2421819
12/21/17 12:54 PM
12/21/17 12:54 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Same thing as a RAM Air 5 Pontiac head.
Re: What went wrong pushrod in int port? [Re: dizuster] #2421828
12/21/17 01:17 PM
12/21/17 01:17 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
"You want to spend a lot of money on an engine and be disappointed with the results? Build a Ford FE motor."
-unnamed engine builder
Re: What went wrong pushrod in int port? [Re: Jeremiah] #2421902
12/21/17 04:54 PM
12/21/17 04:54 PM
That quote may have been from the man himself, Bob Glidden work
Re: What went wrong pushrod in int port? [Re: dizuster] #2421923
12/21/17 05:19 PM
12/21/17 05:19 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
That must be what this is and an Fe intake pic
