Re: A couple of suspension questions
[Re: GregY]
#2421194
12/19/17 11:16 PM
12/19/17 11:16 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
inner will have a different thread than outers, I forget if it's the inners that are LHT or the outers.
4 bushings and two shafts are probably the end links, a pic would help.
[Re: GregY]
#2421207
12/19/17 11:31 PM
12/19/17 11:31 PM
RapidRobert
I too don't remember how Ma did it & obviously you need a leftie and a rightie in their respective ends of the sleeve(s) cuz as you know the ends are threaded differently but you can screw em in the sleeve then install/flip the sleeve assy either way. The left hand threads have an unmistakeable angled twist to the threads that you cant mistake when you see it whereas righties look straight (no angle). alignment techs are used to seeing em either way & they'll grasp which way to turn the sleeve in a heartbeat (if you are haveing it done at a shop). iirc the lefties on the assy line went on the left side of each sleeve but I cant swear to it.
[Re: buildanother]
#2421600
12/20/17 09:27 PM
12/20/17 09:27 PM
Posts: 4,957 WI
Dcuda69
WI
Outers are usually the right hand threads. This^^^^^^
