A couple of suspension questions #2421177
12/19/17 10:34 PM
12/19/17 10:34 PM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
Guys,
I am looking at redoing the front suspension on my 71 Charger and have two questions:
I have two new (actually they are about 20 years old, but unused) tie rod ends from Just Suspension. How do I tell if they are inner or outer?
I also have a 20 year old part number 5-7101 from Just Suspension. What the heck is this for? It looks like four bushings and two shafts.
Thanks in advance.
Greg
Re: A couple of suspension questions [Re: GregY] #2421194
12/19/17 11:16 PM
12/19/17 11:16 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
inner will have a different thread than outers, I forget if it's the inners that are LHT or the outers.
4 bushings and two shafts are probably the end links, a pic would help.
Don't be the exception.
Re: A couple of suspension questions [Re: GregY] #2421207
12/19/17 11:31 PM
12/19/17 11:31 PM
I too don't remember how Ma did it & obviously you need a leftie and a rightie in their respective ends of the sleeve(s) cuz as you know the ends are threaded differently but you can screw em in the sleeve then install/flip the sleeve assy either way. The left hand threads have an unmistakeable angled twist to the threads that you cant mistake when you see it whereas righties look straight (no angle). alignment techs are used to seeing em either way & they'll grasp which way to turn the sleeve in a heartbeat (if you are haveing it done at a shop). iirc the lefties on the assy line went on the left side of each sleeve but I cant swear to it.
Re: A couple of suspension questions [Re: RapidRobert] #2421210
12/19/17 11:34 PM
12/19/17 11:34 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Outers are usually the right hand threads.
Re: A couple of suspension questions [Re: GregY] #2421219
12/19/17 11:43 PM
12/19/17 11:43 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The differences between the inner and the outer tie rod ends are the threads that go into the adjusting sleeves, one will have right hand threads, and the other will have left hand threads. I sure can't remember which was right or left though. Once the tie rods are put together with the sleeve an assembly, it will fit either direction, though there is probably a "proper" orientation. Gene
Re: A couple of suspension questions [Re: poorboy] #2421556
12/20/17 07:52 PM
12/20/17 07:52 PM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
Thanks everyone, good call on the tie rod threads going in different directions, I probably wouldn't have thought of that.
Re: A couple of suspension questions [Re: buildanother] #2421600
12/20/17 09:27 PM
12/20/17 09:27 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
This^^^^^^
Re: A couple of suspension questions [Re: GregY] #2421618
12/20/17 09:59 PM
12/20/17 09:59 PM
cbusters Offline
cbusters  Offline
Right out! The opposite of what we said in the 70's.
