Re: Real world weight loss program and it` cost..........
[Re: Adobedude]
#2421174
12/19/17 10:33 PM
12/19/17 10:33 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
with all those holes cut in the door, Exactly how much weight did he remove?
Hell Hath No Fury Like Mine
[Re: Thumperdart]
#2421303
12/20/17 02:49 AM
12/20/17 02:49 AM
Posts: 200 Colorado
Bob J
Colorado
This is a modded power window mechanism. C body mechanism with a 68 B body arm. I took out 1 lbs and being a convertible I wanted power. And I took out 1.5 lbs from the back. Yes this added weight 2 lbs to each door and 1.5 lbs to each back window. I still think I can remove between 300 to 400 lbs off the car.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS 68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam 65 Chrysler 300 Convert. project 57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son 2003 Dodge Dakota R/T "DEAD"
[Re: fullmetaljacket]
#2421304
12/20/17 02:49 AM
12/20/17 02:49 AM
fullmetaljacket
Mirror, mirror on the wall, who's the best of them all? Wait a few days and then wet sand for compound/polish and then go swimming in the Black Lagoon.
[Re: Thumperdart]
#2421309
12/20/17 03:01 AM
12/20/17 03:01 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
There are many ounces of mentally challenged people in this thread with over 2 million views.
[Re: Thumperdart]
#2421723
12/21/17 02:20 AM
12/21/17 02:20 AM
hemi-itis
Well,,,,,,,,YOU started it!! ![pity pity](/ubbthreads/images/graemlins/custom/pity.gif) I'm over here with Jenny whispering in my ear ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) 200 lbs with more to go.
[Re: hemi-itis]
#2421767
12/21/17 09:09 AM
12/21/17 09:09 AM
fullmetaljacket
What's that TV show from the 60's-70's? "I dream of Jenny"
[Re: moparx]
#2421847
12/21/17 02:02 PM
12/21/17 02:02 PM
hemi-itis
"i dream of jeani" [sp] is it. not sure if you guys dressing in shear, see thru pants and shirts with a veil thrown in is saving weight in the right areas. but upon reflection, that might be the ultimate weight loss, as when the competition sees that, they will either go blind, or start laffing so hard your win will be inevitable ! Or a nice yougin in that garb as backer upper ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: Thumperdart]
#2427294
01/01/18 06:27 PM
01/01/18 06:27 PM
Posts: 1,467 Martinsville, IN
cdwmotorsports
Martinsville, IN
I know it isn't stock looking weight loss but at the point my car got fenderwell headers and the motor plated stroked big block the secrets were let out.
I have begun the Wilwood disc brake conversion, I have removed the old 9" drums and associated parts and as soon as it isn't double digit negative temps in Indiana (since I have no garage for my Demon) I will use the die grinder to remove the material from the spindles to clearance the bolt head and soon have lightweight disc brakes installed on the Demon for a hopeful spring return to the streets.
eBay-cdwmotorsports
[Re: cdwmotorsports]
#2431104
01/08/18 03:41 PM
01/08/18 03:41 PM
fullmetaljacket
Even the newbies with all that pork on board are getting in on the action. Simple delete buttons are pressed and there goes some pounds. Wish I had a Demon to play with so that I could really exorcise the pounds outta that Mother. https://www.youtube.com/watch?v=kKIouJsvaRI
#2431110
01/08/18 03:55 PM
01/08/18 03:55 PM
Thumperdart
State of confusion
The bad thing I see in the video is that most is removed from the center/rear which MAY affect traction...........
[Re: Thumperdart]
#2433217
01/12/18 03:07 AM
01/12/18 03:07 AM
cdwmotorsports
Martinsville, IN
Grinding of the spindles for the Wilwood kit is complete as is the mounting of the aluminum radiator and electric fan wiring is mostly completed.
Side bar question on the aluminum radiator, anyone painted theirs black to stealth it out? I’m considering it.
Also found out my steel front wheels entirely hide the Wilwood kit and the poverty caps fit too.
eBay-cdwmotorsports
