68 a-body sway bar painted or bare #2419532
12/16/17 05:36 PM
12/16/17 05:36 PM
Clinton, NJ
N
njmopar Offline OP
njmopar  Offline OP
N
Clinton, NJ
Hello
Is the swaybar painted black or bare on a a-body? And same question for the brackets on the k-frame as well.
I thought I saw black paint on mine but the rust and grime was making it hard to tell. Been blasted for a few years now and finally getting to it.
Thanks.
Re: 68 a-body sway bar painted or bare [Re: njmopar] #2419787
12/17/17 12:16 PM
12/17/17 12:16 PM
New York
rarefish Offline
rarefish  Offline
New York
The one on my 69 Dart is painted. This is a pic of the underside taken 4 yrs ago when I first bought it. The car had been parked since 1974. A little nasty looking, but original.
Re: 68 a-body sway bar painted or bare [Re: njmopar] #2419870
12/17/17 02:43 PM
12/17/17 02:43 PM
Clinton, NJ
N
njmopar Offline OP
njmopar  Offline OP
N
Clinton, NJ
Looks better then mine did.
Thanks for confirming.
Re: 68 a-body sway bar painted or bare [Re: njmopar] #2419885
12/17/17 03:20 PM
12/17/17 03:20 PM
Northern BC
Canucklehead Offline
Northern BC
I have one that a guy took off of his brand new 68 Barracuda to go drag racing, definitely semi gloss black with a yellow paint daub.
Re: 68 a-body sway bar painted or bare [Re: njmopar] #2419976
12/17/17 07:52 PM
12/17/17 07:52 PM
Clinton, NJ
N
njmopar Offline OP
njmopar  Offline OP
N
Clinton, NJ
Almost forgot, the bracket is black as well?
Re: 68 a-body sway bar painted or bare [Re: njmopar] #2419996
12/17/17 08:31 PM
12/17/17 08:31 PM
Northern BC
Northern BC
Yes.
Re: 68 a-body sway bar painted or bare [Re: njmopar] #2420128
12/18/17 01:14 AM
12/18/17 01:14 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
I own a '69. I believe the bar and brackets were spray painted or dip painted black as a unit, since Mopar offered no replacement brackets or bushings - you had to buy the bar plus brackets plus bushings together as an assembly at the parts counter. All 5 items were a unit at assembly and must have been painted that way. Off course, the paint would have fallen off the bushings with age and use. The 4 bolts were added at assembly and were not painted.
BTW those are original stabilizer links in the photo above.
Photo below shows the yellow paint daub. It looks like spray paint to me.
Canucklehead, is the daub spray paint or brushed? Can you post a photo?
Re: 68 a-body sway bar painted or bare [Re: kentj340] #2420181
12/18/17 02:18 AM
12/18/17 02:18 AM
Northern BC
Northern BC
Sorry for the picture, it's buried in my shed.
Re: 68 a-body sway bar painted or bare [Re: Canucklehead] #2420183
12/18/17 02:20 AM
12/18/17 02:20 AM
Northern BC
Northern BC
I can pull it out tomorrow, but to me it looks brushed on.
Re: 68 a-body sway bar painted or bare [Re: njmopar] #2420276
12/18/17 12:30 PM
12/18/17 12:30 PM
Ohio
carteravs Offline
carteravs  Offline
Ohio
I wonder if the paint daub was a different color for different diameter sway bars,ie: 340 @ 7/8" vs.383 @ 15/16"?
Re: 68 a-body sway bar painted or bare [Re: carteravs] #2420283
12/18/17 12:49 PM
12/18/17 12:49 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Good point as they did the same paint code I.D. on the torsion bars or they would need to measure each one which is too slow of a method for production. A swaybar is another type of torsion bar IMO so it would fit the process for I.D.ing them.
Common I.D. method on all production type springs (coil, torsion, even leaf).
Re: 68 a-body sway bar painted or bare [Re: kentj340] #2420362
12/18/17 03:25 PM
12/18/17 03:25 PM
Clinton, NJ
N
njmopar Offline OP
njmopar  Offline OP
N
Clinton, NJ
This is good info about being all on when painted. Changes how I will do mine.
Thanks.
Re: 68 a-body sway bar painted or bare [Re: njmopar] #2420464
12/18/17 05:57 PM
12/18/17 05:57 PM
Northern BC
Northern BC
A couple of more pics, definitely brushed on.
Re: 68 a-body sway bar painted or bare [Re: Canucklehead] #2420472
12/18/17 06:01 PM
12/18/17 06:01 PM
Northern BC
Northern BC
Another
Re: 68 a-body sway bar painted or bare [Re: njmopar] #2421242
12/20/17 12:27 AM
12/20/17 12:27 AM
Ohio
carteravs Offline
carteravs  Offline
Ohio
Okay, are the bars pictured with the yellow paint daub, off of
340 cars or 383s!
Re: 68 a-body sway bar painted or bare [Re: njmopar] #2421270
12/20/17 01:32 AM
12/20/17 01:32 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
My photo is from a 340.
According to the 1969 Mopar Parts Catalog, there was only one "Sway Bar Shaft" for all A bodies regardless of engine. That's not to say 340 and 383 sway bars were the same factory installed, but it sure looks like it.
Thanks Canucklehead!
Re: 68 a-body sway bar painted or bare [Re: njmopar] #2421321
12/20/17 03:43 AM
12/20/17 03:43 AM
Northern BC
Northern BC
The fellow I bought it from told me it was from a 68 340 Barracuda.
Interesting, my 69 parts book lists 340 and 383 bars as the same but my 68 book lists a different part for 383. They are the Canadian versions and have some differences from the US version. My 68 book lists 2462838 as all a-body except 383, which is listed as 2535533. My 69 book lists all A-body as 2535534. I just assumed 67-72 A-bodies were the same.
Re: 68 a-body sway bar painted or bare [Re: njmopar] #2421360
12/20/17 10:48 AM
12/20/17 10:48 AM
Ohio
carteravs Offline
carteravs  Offline
Ohio
The parts book lists replacement parts, not necessarily what came
on the car from the factory. For instance, all, over the counter
lower control arms came with sway bar brackets, no matter if the
car they were going on had a sway bar or not. The dealer data book calls out .88 sway bars for small block cars and .94 for the 383s.I'm guessing, because of the low volume of big block cars built, and the small number of bars they sold, they just sold the smaller bars for everything.
Re: 68 a-body sway bar painted or bare [Re: carteravs] #2421429
12/20/17 01:46 PM
12/20/17 01:46 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Interesting and good info, thanks guys.
Question: What about the '69 M-Code 440 Dart and Cuda, did they use the 383 big block .94 sway bar too?
Re: 68 a-body sway bar painted or bare [Re: A12] #2421463
12/20/17 03:21 PM
12/20/17 03:21 PM
Ohio
carteravs Offline
carteravs  Offline
Ohio
Yes
