Re: What's a good mid-line base/clear paint system?
[Re: YYZ]
#242089
03/03/09 08:21 PM
03/03/09 08:21 PM
omni is great- I used 4 coats of base and 4 coats of clear-just keep in mind that bodywork and prep are 90% of end results-when you are ready for paint,do another 40 hrs. of priming and sanding and wiping down-I hope you have a dust free environment before spraying and keep floor wet
#242090
03/03/09 09:18 PM
03/03/09 09:18 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I've used omni with good results, only complaint the paint is thin and needs more coats than a good paint. I have switch to dupont nason, because the ppg supplier locally closed... but I find the coverage is better and I use the nason clear which is the old regular line of dupont clear. I like the nason clear better also, it seems to lay smoother.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: FY1TA]
#242092
03/03/09 11:58 PM
03/03/09 11:58 PM
Posts: 1,489 west kentucky
gomangoRTSE
west kentucky
I have been using alot of Omni . PPG's lower line . It works excellent .
I have two seperate shops I know that swear by the Omni. I think they may call it Shopline now.
