how wide are early A front frame rails? (inside to inside)
#2420205
12/18/17 04:41 AM
12/18/17 04:41 AM
RapidRobert
63-66 A body. I need to purchase the maximum width radiator that will fit (with alterations). thank you for your time.
Re: how wide are early A front frame rails? (inside to inside)
[Re: poorboy]
#2420796
12/19/17 03:10 AM
12/19/17 03:10 AM
RapidRobert
We're probably gonna use one of speedway motors' alum cheapies & they have a 22 24 26 28 31" total overall width
[Re: RapidRobert]
#2420801
12/19/17 03:20 AM
12/19/17 03:20 AM
Posts: 43,185 Bend,OR USA
Cab_Burge
I have three early A body Darts in the driveway, do you want the inside to inside frame rails above the K member or the width of the top of the frame rails between the inner fender wells at the bottom of the inner fender well lips?
[Re: Cab_Burge]
#2420815
12/19/17 03:49 AM
12/19/17 03:49 AM
RapidRobert
I ain't sure, I'm gonna set a radiator down in there (as wide as possible & I could cut the lip overhang) & I dont have the A body here & I am going to purchase one of those cheapies for my ramcharger in a few days then use it on the 63 dart that is coming my way in several months. I know the ram would take a wide one but I want the right width to be able reuse it on the 63 dart stock car.
[Re: Cab_Burge]
#2420996
12/19/17 04:15 PM
12/19/17 04:15 PM
RapidRobert
Thank you Cab & yes looseing weight is my game plan.
