New Shocks recommendation #2405457
11/18/17 02:58 PM
11/18/17 02:58 PM
Central Florida
larrymopar360 Offline OP
Stud Muffin
Stud Muffin
Central Florida
Need a set of new Shocks for my '79 Power Wagon 150. It's not really going to see any off-roading, but I'd still like what's consider kind of a HD Shock, but not anything crazy for off-roading. Factory lift, but 33x12.50 tires right now. Might go with slightly less tire in future but nothing drastically smaller. I don't like the red and other colorful stuff that shows either. Just a good HD long lasting shock.
Thanks.
Facts are stubborn things.
Re: New Shocks recommendation [Re: larrymopar360] #2405485
11/18/17 03:48 PM
11/18/17 03:48 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
What do you think of these specs on these Monroes for the rear?
The Monroe® Gas-Magnum® truck shock absorber is designed for mid to full size, hard working pick-up trucks and vans. These units provide firm control without a harsh ride. With up to twice the fluid capacity of standard 1 inch bore shocks, Monroe® Gas-Magnum® truck shocks work more efficiently with less effort.
Features
1-3/8 inch Bore: Lower operating pressure than standard 1 inch bore units
2 inch Reserve Tube: More fluid for more consistent performance.
5/8 inch Piston Rod: Heavy-duty nitrocarburized rod for long service life. On non-dust shield units only
All Weather Fluid: Contains special modifiers to reduce friction and ensure smooth rod reaction.
Full Displaced Valving: Better valving range on both the compression and extension cycles of the unit for a smooth comfortable ride.
Nitrogen Gas Charged: For improved ride and handling, helps maintain tire to road contact by reducing aeration - on most applications
Sintered Iron Piston: Stronger than traditional metals, enhances durability for longer service life.
Special Seal: 'Self-lubricating' fluid seal designed to retain gas without excessive wear or friction.
Re: New Shocks recommendation [Re: larrymopar360] #2405501
11/18/17 04:30 PM
11/18/17 04:30 PM
IN
ahy Offline
ahy  Offline
IN
I run the Monroe gas shocks on a brand F PU. They work and have held up fine.
Re: New Shocks recommendation [Re: larrymopar360] #2405545
11/18/17 05:49 PM
11/18/17 05:49 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
Let us know how you like the ones you choose. My W150 is due for a set as soon as I get it back from paint. popcorn
Re: New Shocks recommendation [Re: T2R9] #2405557
11/18/17 06:26 PM
11/18/17 06:26 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Will do. I read reviews of this Monroe shock on Amazon and all were really good. Still waiting on answer back from vendor to confirm they will fit W150.
Re: New Shocks recommendation [Re: larrymopar360] #2405569
11/18/17 06:50 PM
11/18/17 06:50 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Ok, I know I didn't wait long for responses, but my shocks are really shot. I just purchased the Monroe's for front and rear, front #34853, rear #34854, specs listed above. Four were $135 free shipping. Hope to install them soon, and I'll check back in with feedback. Like I wrote, mine are pretty old and bad, so anything new is going to feel better.
Re: New Shocks recommendation [Re: larrymopar360] #2405822
11/19/17 05:25 AM
11/19/17 05:25 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Bilstein 5100 series, one of the best shocks for the money! Those were the best thing I did to my wife's tj jeep, wish I had them on my Wrangler to tame the buck board leafs. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: New Shocks recommendation [Re: astjp2] #2406170
11/20/17 01:08 AM
11/20/17 01:08 AM
Mid Michigan
Mr. Smurf Offline
Mr. Smurf  Offline
Mid Michigan
I've ran the Monroes since the 80's on Dodges & Chebbies....best bang for the buck, imo.
FYI, NAPA premimums are Monroe gas mags.
Ed
Re: New Shocks recommendation [Re: larrymopar360] #2417590
12/12/17 09:19 PM
12/12/17 09:19 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
The Monroes are installed (part numbers above), and I love them. BIG difference in ride. Much more controlled but not harsh. As Mr. Smurf said, great bang for the buck. Very beefy shock. Glad I made this choice. up
Re: New Shocks recommendation [Re: larrymopar360] #2420241
12/18/17 10:51 AM
12/18/17 10:51 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Funny how much shocks are overlooked. Having worked on cars for 25+ years you'd think I'd have an opinion of them, but I didn't. About six months ago I put a set of KYB Monomax shocks on my 01 2500. Could tell as soon as I backed out of the driveway that I'd REALLY overlooked something as simple as a shock.
Re: New Shocks recommendation [Re: larrymopar360] #2420703
12/19/17 12:09 AM
12/19/17 12:09 AM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
Shocks are one of those items that unless the fail altogether, we basically ignore them. Until they allow the vehicle to bounce uncontrollably, most people give them very little thought.
I really don't remember the last time I put new shocks on anything! One front strut was replaced on our PT when it was in a wreck and the strut got bent, That would have been around 2008 or 2009. The other strut, as well as both rear shocks are still original to the 2004 PT. The car has 120K miles on it.
How sad is it that I don't bat an eye changing a set of $500-$600 tires every 40 K miles, but haven't changed a set of $150 shocks and struts? Gene
Re: New Shocks recommendation [Re: larrymopar360] #2420733
12/19/17 01:01 AM
12/19/17 01:01 AM
Ontario
Mopar Boy Offline
Mopar Boy  Offline
Ontario
I will also pipe in here. I have extensive background in building gen 1 Rams with the intent of towing trailers. If you want a REALLY good shock for making the truck ride like it is on rails, consider a Bilstein 5100.
I have run Monroe, Napa, Mopar, etc and for ensuring the truck handles with very little body lean, I have found good results with these shocks. Normally about $120 per, for sure more expensive. But, it depends what demands you need your truck to do. As poorboy said, you pay $600 for tires.... ever consider what a really good shock can do?
Again, changes if you never have a load in it or behind it.... but if you actually work a truck (My 1990 W250 has peaked weight at 29,000 gross truck and trailer), then you may need a step up.
My 10c. laugh
1969 Chrysler 300 440/727
1980 W350 Crew Cab Dually with 1997 12V Cummins & many, many goodies
1990 W250 Cummins NV5600
Re: New Shocks recommendation [Re: larrymopar360] #2422696
12/23/17 04:06 PM
12/23/17 04:06 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Mopar Boy, I have never heard a bad word about Bilstein Shocks in any application, so I bet they make a great truck shock too. My recent '79 Power Wagon purchase has needed so much right away, having been neglected for so long, and because I have no real off roading, towing, or work (other than an occasional moving some furniture) planned for it, and the ones that were on the truck were so bad, I just needed to do something immediately. I had to keep the cost somewhat low without buying junk. Down the road, I can see myself going for the Bilstein's for my second set though. up
Re: New Shocks recommendation [Re: larrymopar360] #2422998
12/24/17 03:45 AM
12/24/17 03:45 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
I had 66k miles on my 02 2500 cummins, last spring and decided it was time to change out the shocks, before towing the trailer for summertime. I went round and round on what to buy - went with the Monroe Gas Shocks. I am sure they are correct for my truck (8800lb GVWR) . . . but, wow, they are not as good as the old originals I took off my truck - just way bouncier and not what I thought they would be. Thinking that I will have to move up to the Bilstein . . .
Re: New Shocks recommendation [Re: larrymopar360] #2423171
12/24/17 05:27 PM
12/24/17 05:27 PM
Ontario
Mopar Boy Offline
Mopar Boy  Offline
Ontario
Makes sense! Regardless of what you get, make sure that truck gets back on the road! smile
Re: New Shocks recommendation [Re: Mopar Boy] #2423233
12/24/17 07:48 PM
12/24/17 07:48 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
It is now and I'm so happy! Lots more to do for sure, but it's safe to drive now, the engine is reliable and sealed up, sounds good, and puts a smile on my face! beer
