stuck wrist pins #2420593
12/18/17 08:49 PM
12/18/17 08:49 PM
RapidRobert Offline OP
Sealed Power h405 new pistons. eBay purchase. pins are stuck & I soaked one of em in the solvent tank for a day or so & still stuck. should I tap it with something or soak it in something else? thank you for your time.
Re: stuck wrist pins [Re: RapidRobert] #2420601
12/18/17 08:58 PM
12/18/17 08:58 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Try heating them in the oven.
Re: stuck wrist pins [Re: stumpy] #2420604
12/18/17 09:07 PM
12/18/17 09:07 PM
Will do. EDIT how hot? MORE EDIT Stump you're the man! it took the oven several minutes to get up to 300 & I took it out to check it after several minutes as I dont want to damage it & to my surprise it came out, so I stuck the rest of em (ex for the one still in the solvent tank) in there. EVEN MORE EDIT Done! (7 of em) alum sure must expand way faster (or a greater amt) than steel. That was WAY too easy.
Re: stuck wrist pins [Re: RapidRobert] #2420777
12/19/17 02:22 AM
12/19/17 02:22 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Used that trick before and it makes removing and installing pins easy.
Re: stuck wrist pins [Re: RapidRobert] #2420778
12/19/17 02:24 AM
12/19/17 02:24 AM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Actually both. :-)
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: stuck wrist pins [Re: stumpy] #2420804
12/19/17 03:24 AM
12/19/17 03:24 AM
Marilla, New York
RalleyA12 Offline
RalleyA12  Offline
Marilla, New York
Just make sure with light oil on them that they are free in the pistons, they might need a light honing.
Re: stuck wrist pins [Re: RapidRobert] #2420806
12/19/17 03:31 AM
12/19/17 03:31 AM
Most aluminum alloys expand 8 times more than steel at the same temps. shruggy
Re: stuck wrist pins [Re: Cab_Burge] #2420812
12/19/17 03:44 AM
12/19/17 03:44 AM
Rallye I will do. Cab yes it was no time at all in there (I was worried that 300 was to hot) so I pulled the one out fairly quick & it was free.
Re: stuck wrist pins [Re: RapidRobert] #2420862
12/19/17 11:13 AM
12/19/17 11:13 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
You can actually expand a piston by holding it in your hands too much and warming it up! I found that out about 40 years ago working on snowmobile engines. You can also " compress" a piston with your hands when measuring if you squeeze it hard.If you put a 4" mic on a piston skirt, squeeze it with your hand, the mic will fall right off...
RIP Monte Smith
Re: stuck wrist pins [Re: CompWedgeEngines] #2420865
12/19/17 11:34 AM
12/19/17 11:34 AM
Alright let me do this, I will clean the remaining piston that is resting in the solvent tank & warm it up with my hands & see what transpires. The ladies' say my hands are magic so lets see if that works across the board
Re: stuck wrist pins [Re: RapidRobert] #2420881
12/19/17 12:13 PM
12/19/17 12:13 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Oh jeez.....
Re: stuck wrist pins [Re: RapidRobert] #2420898
12/19/17 12:52 PM
12/19/17 12:52 PM
moparx Offline
moparx  Offline
double R, "be vewy, vewy caful !" [in my best "fudd" voice biggrin] you might be setting yourself up to be the next big news report on tv with several "ladies" on the accusing end for you doing "naughty things" ! apimp eek stirthepot devil laugh2
beer
Re: stuck wrist pins [Re: moparx] #2420923
12/19/17 01:59 PM
12/19/17 01:59 PM
Understood, I'm always on my best behavior.
Re: stuck wrist pins [Re: moparx] #2420965
12/19/17 03:29 PM
12/19/17 03:29 PM
I was told by all the ladies I handled that they love every part of my body, hands and all whistling devil
It is absolutely amazing what the ladies will do for you if you treat them right and take care of their needs first, like all gentleman are taught to do work grin boogie
Merry Christmas and a happy and prosperous New Year to all on here up
Re: stuck wrist pins [Re: RapidRobert] #2420968
12/19/17 03:36 PM
12/19/17 03:36 PM
P
Porter67 Offline
Porter67  Offline
P
This is funny.
Re: stuck wrist pins [Re: Porter67] #2421054
12/19/17 05:58 PM
12/19/17 05:58 PM
dogdays Offline
dogdays  Offline
Mr. Cab, I have figured out where your instructor messed up. He was using the values for VOLUMETRIC thermal expansion. But unless you are trying to figure out whether the aluminum will float, it has little value to know that. What we're trying to determine is how much the Linear coefficient of thermal expansion differs between steel and aluminum.
Aluminum coefficient of linear thermal expansion is 21 - 24 relative units.
Steel coefficient of linear thermal expansion is 11 - 12.5 relative units.
So the correct rule-of-thumb multiplier is 2.
Aluminum expands in length at about 2 times the rate of steel for a given temperature increase.
I have noticed on new stock replacement, pressed pin type pistons, quite a few pins need a little rap on the pin to get it to come out. I am inclined to believe that millions of such pistons have been installed without any additional pin fitting.
I haven't ever heard of needing 300 degrees F to get the pin to slide out. Usually, hot water from the tap is all that's necessary.
R.
Re: stuck wrist pins [Re: dogdays] #2421114
12/19/17 08:51 PM
12/19/17 08:51 PM
R.
Yes I was worried that I set it too high & luckily I went back in the oven pretty quick. Dog what I am gonna do is put my healing hands on it & see if that does the trick (it usually does!) then if not then hot water then the oven again at maybe 150.
Re: stuck wrist pins [Re: RapidRobert] #2421382
12/20/17 12:04 PM
12/20/17 12:04 PM
I just put my healing hands on it & in short order it came right out (I couldn't believe it). thanks guys!
