Aluminum fuel cell cleaning #2420519
12/18/17 07:01 PM
12/18/17 07:01 PM
gulfport, ms, west mi
rowin4 Offline OP
rowin4  Offline OP
I bought a used aluminum fuel cell. I removed the foam from the inside to check out the condition of the foam I looks good with no apparent deterioration. The cell itself must of had gas setting in it for a long time as the inside is scaly about half way up the sides. Need ideas on how to remove the scale. Chemical or blasting?
Re: Aluminum fuel cell cleaning [Re: rowin4] #2420545
12/18/17 07:28 PM
12/18/17 07:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Use some 400 grit sand paper
wave
Re: Aluminum fuel cell cleaning [Re: rowin4] #2420578
12/18/17 08:28 PM
12/18/17 08:28 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Get some aluma bright from a truck stop or ebag.
Re: Aluminum fuel cell cleaning [Re: rickraw] #2420902
12/19/17 01:08 PM
12/19/17 01:08 PM
moparx Offline
moparx  Offline
how would that work if you can't get your hand inside to polish it ? or is this an etch type liquid ? sorry to sound so dum.....
beer
Re: Aluminum fuel cell cleaning [Re: moparx] #2421124
12/19/17 08:59 PM
12/19/17 08:59 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
It's a mild cleaning acid. It won't eat the aluminum.
Re: Aluminum fuel cell cleaning [Re: rickraw] #2421391
12/20/17 12:20 PM
12/20/17 12:20 PM
moparx Offline
moparx  Offline
up thanks ! you just learned an old dog something new. [now if i can just remember it....]
beer
Re: Aluminum fuel cell cleaning [Re: rowin4] #2422483
12/22/17 10:37 PM
12/22/17 10:37 PM
rowin4 Offline OP
rowin4  Offline OP
I sent off a e-mail and asked if their aluma brite would remove the scale build up inside the tank cause by old gas. Their reply was to use Sta-Bil . Little to late for that.
Re: Aluminum fuel cell cleaning [Re: rowin4] #2422495
12/22/17 11:22 PM
12/22/17 11:22 PM
Chief aircraft and Aircraft Spruce both sell a liquid aluminum corrosion remover, maybe the name is Aladyne confused Maybe not it's been way to long since I've bought and use it on my old airplane shruggy It works very well doing that corrosion scale removing up
Call them to get some twocents
I have also used Eagle Cast Aluminum wheel cleaner on intakes to clean them up so they look good work shruggy
Re: Aluminum fuel cell cleaning [Re: Cab_Burge] #2422566
12/23/17 03:12 AM
12/23/17 03:12 AM
South Bend
John Brown Online content
John Brown  Online Content
South Bend
Sold by the brand name Alodine.
Link -> Alodine
Also available on Amazon.
Re: Aluminum fuel cell cleaning [Re: John Brown] #2422577
12/23/17 03:51 AM
12/23/17 03:51 AM
That isn't the product I'm thinking of, I believe that is a sealer and corrosion preventer, not the corrosion remover I'm thinking of blush
Re: Aluminum fuel cell cleaning [Re: rowin4] #2422660
12/23/17 02:24 PM
12/23/17 02:24 PM
rowin4 Offline OP
rowin4  Offline OP
Must be that Aircraft and Mopar are synonyms . I could buy a new fuel cell for what their products cost. Still didn't find anything that will work for removing dried gas build up.
Re: Aluminum fuel cell cleaning [Re: rowin4] #2422666
12/23/17 02:42 PM
12/23/17 02:42 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Try some easyoff oven cleaner. It takes burnt oil off coated headers if u let it soak for a while. Give it a shot.
Re: Aluminum fuel cell cleaning [Re: rickraw] #2422703
12/23/17 04:33 PM
12/23/17 04:33 PM
No way in the world would I use Easy Off, or any oven cleaner,on aluminum, unless I wanted it to disappear twocents work tsk
Re: Aluminum fuel cell cleaning [Re: rowin4] #2422706
12/23/17 04:45 PM
12/23/17 04:45 PM
Stinnett, Tx
rumblebee4232 Offline
Stinnett, Tx
Originally Posted By rowin4
Ml. Still didn't find anything that will work for removing dried gas build up.
Try some carb cleaner.. I like chemtool's B12..
Re: Aluminum fuel cell cleaning [Re: rowin4] #2422707
12/23/17 04:48 PM
12/23/17 04:48 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Metal Prep by Amchem has an aluminum formula. I cleaned an intake, but I also could scrub. I don't know if it works by dwelling or not.
Re: Aluminum fuel cell cleaning [Re: Cab_Burge] #2422734
12/23/17 06:16 PM
12/23/17 06:16 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
It doesn't harm aluminum, I tried it.
Re: Aluminum fuel cell cleaning [Re: rickraw] #2422839
12/23/17 10:05 PM
12/23/17 10:05 PM
That really surprises me, I would have sworn I remember some one screwing up a AFB by spraying it with Easy Off to clean it confused
