Re: Small Block experts - help needed
[Re: rtandy]
#2420228
12/18/17 09:32 AM
12/18/17 09:32 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Do NOT run this motor again till You find and fix. You can't NOT be in a position to pull the motor if you find any metal in the filter. Check that first. Then check converter to flex plate bolts. At a minimum I would cut the filter open first, rock the motor back and forth and watch for slop in the timing chain by watching the rotor,then pull the valve covers and check for loose parts, broken springs, broken bolts, etc. Next pull the pan. If you haven'found the problem by the time you get to the pan then it is most likely in there. Gets expensive then.
[Re: rtandy]
#2420232
12/18/17 10:09 AM
12/18/17 10:09 AM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
Except for the idle it sounds an awful like like a worn down rod bearing to me. The camshaft could push forward if the thrust plate came loose, but I don't think it would cause an oil pressure drop until the cam was almost half the thickness of a cam journal out of place exposing the oil feed holes in the cam tunnel. And at that point you would probably hear the cam gear grinding into the timing cover and the oil pump lever. But there would be no way for it to slide back into place on its own when it cools down. Sorry to say there is no way I would run that engine again until its sorted out.
I've completely stripped a 360 in my challenger down to the crank without pulling the block from the bay. Wasn't easy, but when you don't have a shop or an engine hoist you do what you have to.
Start from the outside and work in until you find the issue. Could be as simple as a broken or backed off rocker allowing a tappet to travel up out of its bore, exposing an oil passage.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: rtandy]
#2420301
12/18/17 01:19 PM
12/18/17 01:19 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Step one...... Cut open the oil filter see what's inside.
[Re: rtandy]
#2420353
12/18/17 03:10 PM
12/18/17 03:10 PM
Posts: 11,621 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
7500? Oil system not "fixed"? Spun a rod bearing. #6 or 7. Lucky you didn't break the rod. Cut the oil filter open.
[Re: CMcAllister]
#2420365
12/18/17 03:29 PM
12/18/17 03:29 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I will never understand why guys insist on reving these engines up to 7500 rpm with JUNK heads. How fast is this car.
