Chassis guys. Main hoop question. #2420233
12/18/17 10:10 AM
12/18/17 10:10 AM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
Putting a roll cage in a 63 Dodge 2dr hardtop. I wanted to keep the main hoop hidden by the quarter window trim. Problem is the angle on the quarter window is 13 degrees. I seem to remember seeing a max angle the hoop can be laid back. Looked in the general NHRA rules on line and it says it can be laid back but no mention of max angle. Anyone else remember seeing a max angle?
Re: Chassis guys. Main hoop question. [Re: fbs63] #2420234
12/18/17 10:34 AM
12/18/17 10:34 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
They told me no max angle however it has to be 6" within your head. Mine is close but you can see it. But depending on the angle of sight you'll se it anyway. It has certified to 8.50 twice now. Both times by the NHRA Division 3 Tech Director.
Doug
Re: Chassis guys. Main hoop question. [Re: dvw] #2420240
12/18/17 10:50 AM
12/18/17 10:50 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Not a chassis guy but 20deg is max lay-back angle for 25.5...plenty of margin for you to hide your main hoop! The rear intersecting bars need to be a MINIMUM of 30 degrees.
Re: Chassis guys. Main hoop question. [Re: HardcoreB] #2420245
12/18/17 10:58 AM
12/18/17 10:58 AM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
Ok. Thanks guys!
Re: Chassis guys. Main hoop question. [Re: fbs63] #2420355
12/18/17 03:14 PM
12/18/17 03:14 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
All of mine get laid back to match the B pillar. Matches the seat back angle better as well.
