1969 Chrysler 300 - Converting from auto to stick #2419831
12/17/17 01:27 PM
12/17/17 01:27 PM
Ontario
Mopar Boy Offline OP
Ontario
I am looking at converting my 1969 Chrysler 300 to a stick.
Being Chrysler was who they were, anyone have an idea if any pedals out of a B or E body would bolt into a 1969 C body?
Would a Kiesler 5 speed pedal kit be a better choice?
Thanks for your time.
Robert
1969 Chrysler 300 440/727
1980 W350 Crew Cab Dually with 1997 12V Cummins & many, many goodies
1990 W250 Cummins NV5600
Re: 1969 Chrysler 300 - Converting from auto to stick [Re: Mopar Boy] #2419855
12/17/17 02:18 PM
12/17/17 02:18 PM
GMP440 Offline
GMP440  Offline
Here is an ebay link for brake and clutch pedal assembly for a 65-68
c-body. Might work. Anyone know for sure.
https://www.ebay.com/itm/1965-68-Mopar-C-body-clutch-pedal-Plymouth-Fury-Dodge-Monaco-Polara-833-4speed/332440992560?hash=item4d6706fb30:g:SOYAAOSwvApaAd5v&vxp=mtr
Re: 1969 Chrysler 300 - Converting from auto to stick [Re: Mopar Boy] #2419867
12/17/17 02:34 PM
12/17/17 02:34 PM
Bowling Green KY / Nashville, ...
300by500 Offline
300by500  Offline
Chrysler produced some manual transmission Fuselage-bodied 4-speed cars, but they're really, really rare - so the conversion parts would also be really, really rare.
Your best bet may be to try the guys over at cbodydrydock.com . They're C-Body nuts and would know more specific info. Sounds like a fun project, I know I miss my '69 300 a LOT! It now resides somewhere in Finland... bawling
Good Luck! up
Re: 1969 Chrysler 300 - Converting from auto to stick [Re: Mopar Boy] #2419886
12/17/17 03:21 PM
12/17/17 03:21 PM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
There were 65-68 four speed C body's made, but no factory Fussy four speeds- just factory three speeds on the column.
1965-68 pedals will not work.
If you locate a set of 69-71 pedals, it is 99.999999% sure the brake pedal will be manual. You will have to convert it to power if you have them. You can get a floor hump from Domingo here on Moparts.
If you take the time to hunt around, you can find the pedals. Be sure to get everything: pedals, z bar and rod from pedal to z bar. These are the critical items: all else are normal B/E stuff (or B/E stuff is close enough). The pedal dress up trim is hard to find.
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: 1969 Chrysler 300 - Converting from auto to stick [Re: Mopar Boy] #2420064
12/17/17 10:59 PM
12/17/17 10:59 PM
Ontario
Ontario
GMP440 - Thanks for the link!
300by500 - Yeah, that looks awesome!! I can see why that would have been loved by a crazy Finn!
EWJ - Got it. Thank you. I will be sure to locate all those parts then.
Re: 1969 Chrysler 300 - Converting from auto to stick [Re: Mopar Boy] #2420124
12/18/17 01:10 AM
12/18/17 01:10 AM
IL
furious70 Offline
furious70  Offline
IL
FYI there have been a couple people on the drydock chronicle several year searches for these parts...and then give up. I once considered buying a $2000 70 Fury with the 3spd just for the set up. Then I regained sanity.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: 1969 Chrysler 300 - Converting from auto to stick [Re: Mopar Boy] #2420155
12/18/17 01:42 AM
12/18/17 01:42 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Robert
IMHO your better off going with the "Keisler", now SST (Silver Sport Transmissions) pedals, I wouldn't waste the time or money with a 833 4 spd, put a TKO 600 or T56 6 speed if your going to the trouble of outfitting a C body, you could go with SST's hydraulic throwout bearing, eliminating the linkage nightmare, and you could drill out the SST brake pedals to fit your linkage bellcrank for the power brakes I assume you have, I'd run a factory style B/C body floor console, I'd order the TKO/T56 with a 68-70 B body shift location so that I could use either the 69 B body 4 spd style handle, or if you like the 70 console pistol grip, SST has all the handles as well, you'd just have to source a console...if your car is bench seat, you could do the B body benchseat shifter 69 or 70 pistol grip style as well
Re: 1969 Chrysler 300 - Converting from auto to stick [Re: Mopar Boy] #2420168
12/18/17 01:58 AM
12/18/17 01:58 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
When I ran dirt track hobby cars, we cobbled up a 69 C body with an 833, pedals, linkage, and all out of a late 60s/early 70s B body car.
It wasn't pretty, but served our purpose, on the dirt track. I'm not so sure I would have wanted to put it on the street.
Guess what I'm saying here is I would not recommend using any Mopar factory stuff to put a street driven C body together. Gene
