w2 dual plane intake confusion, question. #2419729
12/17/17 03:54 AM
12/17/17 03:54 AM
MO
cdp Offline OP
cdp  Offline OP
MO
I'm looking for a dual plane for a mile 340 W2-econo head motor.
I'm looking at these 2 MP intake manifolds. I can't quite figure out the difference between the 2. Anyone with MP and W2 knowledge know the difference?
Mine are old oval port econo's from 78.
http://www.jegs.com/i/Mopar-Performance/312/P5155426/10002/-1
http://www.jegs.com/i/Mopar-Performance/312/P5249572AB/10002/-1
Re: w2 dual plane intake confusion, question. [Re: cdp] #2419735
12/17/17 04:20 AM
12/17/17 04:20 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
That's the same intake, part #'s are the same.
Re: w2 dual plane intake confusion, question. [Re: cdp] #2419736
12/17/17 04:24 AM
12/17/17 04:24 AM
MO
cdp Offline OP
cdp  Offline OP
MO
This was the other one.
I think I see that the deck height is different. 9.60 stock, while this one is listed as 9.20.
Re: w2 dual plane intake confusion, question. [Re: cdp] #2419761
12/17/17 10:17 AM
12/17/17 10:17 AM
Guitar Jones Offline
Yep, the deck height is the difference.
Re: w2 dual plane intake confusion, question. [Re: Guitar Jones] #2419819
12/17/17 01:00 PM
12/17/17 01:00 PM
Frackster Offline
Frackster  Offline
How difficult would it be to adapt a performer rpm to w2 heads?
Re: w2 dual plane intake confusion, question. [Re: Frackster] #2419840
12/17/17 01:37 PM
12/17/17 01:37 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I have one of those W2 dual planes, it's a on an R3 48 degree race motor a bought a couple years ago, it's 9.2 but I think it was a 9.58" that was bridgeported down,
I think in certain circle track classes the W2 was allowed, provided you ran a dual plane intake with them.
WIZE
In Car:
Re: w2 dual plane intake confusion, question. [Re: Frackster] #2419860
12/17/17 02:25 PM
12/17/17 02:25 PM
Locomotion Offline
Locomotion  Offline
Frackster - There would be drilling to match some of the intake bolt holes as well as aluminum welding and porting to match the port shapes.
It might be easier to port out any mismatch on the head side if there is enough material there. But it would be kind of a tacky way of doing it. It's been a while since I had some. An Air-Gap might be better, especially since W-2's don't have a heat crossover anyway.
Doesn't Indy or someone else make an aluminum dual plane for W-2's as well as Mopar?
Chrysler and/or Mopar racers did that to a few LD340's in the infancy of the W-2 program before there were any manifolds for them.
Re: w2 dual plane intake confusion, question. [Re: Locomotion] #2419876
12/17/17 03:05 PM
12/17/17 03:05 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I had a modded Victor 340 on my W2 way back in the early 80's, went to a strip dominator later but they ran about the same
Holley made a Street and a strip dominator which are about identical except the strip was an air gap and the street has a water heated passway under the plenum, the runners look essentially the same. I have a Street Dominator on my 440 W2 smallblock..they are pretty rare.
I actually have one of the W2 Pro Dominator Tunnel Rams sitting on my workbench, It's definately one of the coolest-looking Manifolds ever made, it's more or less "Wall Art" for now, lol
WIZE
In Car:
Re: w2 dual plane intake confusion, question. [Re: Streetwize] #2419888
12/17/17 03:26 PM
12/17/17 03:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I had one of those pro dom tunnel rams.. pretty sure I sold it
and I never ran it
wave
Re: w2 dual plane intake confusion, question. [Re: Frackster] #2422056
12/21/17 10:16 PM
12/21/17 10:16 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
I run the first gen W-2s on my Challenger T/A. Ryan at Shady Dell modified the heads to accept the stock intake bolt pattern and then oval ported the intake. He has done a few. Oh, by the way, My T/A won 1st place at Garlits in E-Body stock class. the judges never caught it. It also has run 11 second ETs at 116 MPH at over 3500lbs.
I also have a Holley Pro Dominator intake. I threw it on for giggles with the 770 cross ram carbs off my Hemi and it was a rocket. It all fit under the stock T/A hood also. never took that combo to the track.
Re: w2 dual plane intake confusion, question. [Re: mercman1] #2422277
12/22/17 01:12 PM
12/22/17 01:12 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I love the W2's, I remember my 69 Dart W2 4 speed with 4.30 gears was nearly unbeatable on the street way back when.
I also remember a local street racer with a green 67 Charger 4 speed pulled his 440 out to replace it with a W2 340!!
I've got a 10:1 440" (360 based) W2 motor with a small 251/259@.050 Bullet roller I built as a tribute to my old racing days.
WIZE
In Car:
