I hope this can be fixed but probably not: #2419519
12/16/17 05:09 PM
12/16/17 05:09 PM
USA
hudsonhornet7x Offline OP
USA
Got a cast iron block, new. It dropped the other day and broke a cylinder head mount hole. Is there any way this can be fixed or do I have a large paperweight now? The pic is not my block but I have circled the area that broke. I do have the piece that came off, broke right down the middle of where the cylinder head bolt would go.
Thanks for any advice.
Re: I hope this can be fixed but probably not: [Re: hudsonhornet7x] #2419545
12/16/17 06:02 PM
12/16/17 06:02 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
What's the build?
That spot that you have circled , only has coolant pressure to deal with .I my self am crazy enough to JB weld the broken piece re tap it and roll the dice.....If it were an engine I was building for someone else, I wouldn't take the chance.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: I hope this can be fixed but probably not: [Re: ric3xrt] #2419653
12/16/17 11:24 PM
12/16/17 11:24 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I have cast iron plates for my press. Someone was using my press and broke one!!! I mig welded it. Its been holding up fine but I think a machine shop can fix it
Re: I hope this can be fixed but probably not: [Re: hudsonhornet7x] #2419678
12/17/17 12:37 AM
12/17/17 12:37 AM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Have it brazed, no big deal. S/F...Ken M
Re: I hope this can be fixed but probably not: [Re: ric3xrt] #2419679
12/17/17 12:38 AM
12/17/17 12:38 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Originally Posted By ric3xrt
What's the build?
Agreed, I'd try to make something work there. Just make sure it's flat without messing up any other sealing surfaces. The M8[?] bolt torque there is fairly low.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: I hope this can be fixed but probably not: [Re: GoodysGotaCuda] #2420542
12/18/17 07:22 PM
12/18/17 07:22 PM
dogdays Offline
dogdays  Offline
It is a relatively meaningless bolt. It's not involved in locking cylinder pressure in, so I'm with the crowd that says "braze it". Get with a pro. I think it's really called furnace brazing, what I'm thinking of.
R.
Re: I hope this can be fixed but probably not: [Re: ric3xrt] #2420611
12/18/17 09:18 PM
12/18/17 09:18 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
What's the build?
That spot that you have circled , only has coolant pressure to deal with .I my self am crazy enough to JB weld the broken piece re tap it and roll the dice.....If it were an engine I was building for someone else, I wouldn't take the chance, I would have it brazed
I edited this because I thought I finished my thought,
Re: I hope this can be fixed but probably not: [Re: hudsonhornet7x] #2421963
12/21/17 06:40 PM
12/21/17 06:40 PM
Wisconsin
Medlock51 Offline
Medlock51  Offline
Wisconsin
Get it welded...
Re: I hope this can be fixed but probably not: [Re: hudsonhornet7x] #2422532
12/23/17 01:10 AM
12/23/17 01:10 AM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Welding cast iron often generates more problems than it fixes, unless you have competent professionals do it, and they charge for it. Call a diesel repair shop and get an estimate. Not some back alley hatchet shop either, a decent Cummins/Cat/Inland Diesel etc shop.
Like I said, get it brazed, generally a phosphor bronze process, it'll be plenty strong and won't have a bunch of hardness/induced stress issues like if someone hacked at arc welding it with nickel rod. S/F....Ken M
Re: I hope this can be fixed but probably not: [Re: hudsonhornet7x] #2422993
12/24/17 03:39 AM
12/24/17 03:39 AM
tri-cities Washington/Denver, ...
5280Dart Offline
5280Dart  Offline
Another possible solution
http://www.locknstitch.com/index.html
Re: I hope this can be fixed but probably not: [Re: hudsonhornet7x] #2423902
12/26/17 02:23 PM
12/26/17 02:23 PM
Wisconsin
Medlock51 Offline
Medlock51  Offline
Wisconsin
It can be spray welded... and there are special rods that can be used. Dirty casting are common with cast iron but thet Hemi shouldnt have that problem.
Re: I hope this can be fixed but probably not: [Re: hudsonhornet7x] #2423911
12/26/17 02:45 PM
12/26/17 02:45 PM
Wisconsin
Medlock51 Offline
Medlock51  Offline
Wisconsin
Re: I hope this can be fixed but probably not: [Re: hudsonhornet7x] #2423931
12/26/17 03:41 PM
12/26/17 03:41 PM
USA
USA
Thank you all for the replies and advice. Since the block is brand new I am excited at the prospect that it can be fixed. I will keep you all updated on the repair.
Re: I hope this can be fixed but probably not: [Re: hudsonhornet7x] #2429888
01/06/18 01:38 PM
01/06/18 01:38 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Talk to your welder about tig brazing with aluminum bronze filler rod.
Re: I hope this can be fixed but probably not: [Re: hudsonhornet7x] #2450784
02/12/18 06:14 PM
02/12/18 06:14 PM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
We have a Silicon Bronze mig welder in the body shop. I believe that would work after V-ing out the sides. may try that first at a local collision shop.
Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
Re: I hope this can be fixed but probably not: [Re: hudsonhornet7x] #2450989
02/12/18 11:29 PM
02/12/18 11:29 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
You are 3 hours from our shop here near Lockport NY and 2 hours or less away from Bob George Racing in Eighty Four Pa...Yes, it can be fixed, good as new. Don't loose the piece that broke off.
Re: I hope this can be fixed but probably not: [Re: Dragula] #2450993
02/12/18 11:35 PM
02/12/18 11:35 PM
USA
USA
I still have the piece. Any Idea of cost to fix? Curious is all.
Re: I hope this can be fixed but probably not: [Re: hudsonhornet7x] #2451040
02/13/18 12:52 AM
02/13/18 12:52 AM
Dragula Offline
Dragula  Offline
Maybe $200 or a little less...Its more labor to get the block up to temp...
