#2419519 - 12/16/17 02:09 PM I hope this can be fixed but probably not:
hudsonhornet7x Offline
Loc: Plumer, Pa
Got a cast iron block, new. It dropped the other day and broke a cylinder head mount hole. Is there any way this can be fixed or do I have a large paperweight now? The pic is not my block but I have circled the area that broke. I do have the piece that came off, broke right down the middle of where the cylinder head bolt would go.
Thanks for any advice.
XP29H8B198192
#2419545 - 12/16/17 03:02 PM Re: I hope this can be fixed but probably not: [Re: hudsonhornet7x]
ric3xrt Offline
Loc: Trumbauersville PA
What's the build?
That spot that you have circled , only has coolant pressure to deal with .I my self am crazy enough to JB weld the broken piece re tap it and roll the dice.....If it were an engine I was building for someone else, I wouldn't take the chance.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
#2419653 - 12/16/17 08:24 PM Re: I hope this can be fixed but probably not: [Re: ric3xrt]
sixpackgut Offline
Drag Week Mod Champion
Loc: Charleston
I have cast iron plates for my press. Someone was using my press and broke one!!! I mig welded it. Its been holding up fine but I think a machine shop can fix it
#2419678 - 12/16/17 09:37 PM Re: I hope this can be fixed but probably not: [Re: hudsonhornet7x]
EchoSixMike Offline
Loc: IL
Have it brazed, no big deal. S/F...Ken M
#2419679 - 12/16/17 09:38 PM Re: I hope this can be fixed but probably not: [Re: ric3xrt]
GoodysGotaCuda Offline
5.7L Hemi, 6spd
Loc: Texas
Originally Posted By ric3xrt
What's the build?
Agreed, I'd try to make something work there. Just make sure it's flat without messing up any other sealing surfaces. The M8[?] bolt torque there is fairly low.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - Build page -> https://www.facebook.com/GoodysGotaHemi<-
1976 Dodge Warlock - "Her Truck" - 360/727 2wd
1969 Dodge Dart Custom Sedan - Grandma Edition - 318/904
2016 Subaru WRX - E30 Tune ~320whp
#2420542 - 12/18/17 04:22 PM Re: I hope this can be fixed but probably not: [Re: GoodysGotaCuda]
dogdays Offline
It is a relatively meaningless bolt. It's not involved in locking cylinder pressure in, so I'm with the crowd that says "braze it". Get with a pro. I think it's really called furnace brazing, what I'm thinking of.
R.
#2420611 - 12/18/17 06:18 PM Re: I hope this can be fixed but probably not: [Re: ric3xrt]
ric3xrt Offline
What's the build?
That spot that you have circled , only has coolant pressure to deal with .I my self am crazy enough to JB weld the broken piece re tap it and roll the dice.....If it were an engine I was building for someone else, I wouldn't take the chance, I would have it brazed
I edited this because I thought I finished my thought,
#2421963 - 12/21/17 03:40 PM Re: I hope this can be fixed but probably not: [Re: hudsonhornet7x]
Medlock51 Offline
Loc: Wisconsin
Get it welded...
#2422532 - 12/22/17 10:10 PM Re: I hope this can be fixed but probably not: [Re: hudsonhornet7x]
EchoSixMike Offline
Loc: IL
Welding cast iron often generates more problems than it fixes, unless you have competent professionals do it, and they charge for it. Call a diesel repair shop and get an estimate. Not some back alley hatchet shop either, a decent Cummins/Cat/Inland Diesel etc shop.
Like I said, get it brazed, generally a phosphor bronze process, it'll be plenty strong and won't have a bunch of hardness/induced stress issues like if someone hacked at arc welding it with nickel rod. S/F....Ken M
#2422993 - 12/24/17 12:39 AM Re: I hope this can be fixed but probably not: [Re: hudsonhornet7x]
5280Dart Offline
Loc: tri-cities Washington/Denver, ...
Another possible solution
http://www.locknstitch.com/index.html
#2423902 - 12/26/17 11:23 AM Re: I hope this can be fixed but probably not: [Re: hudsonhornet7x]
Medlock51 Offline
Loc: Wisconsin
It can be spray welded... and there are special rods that can be used. Dirty casting are common with cast iron but thet Hemi shouldnt have that problem.
#2423911 - 12/26/17 11:45 AM Re: I hope this can be fixed but probably not: [Re: hudsonhornet7x]
Medlock51 Offline
Loc: Wisconsin
#2423931 - 12/26/17 12:41 PM Re: I hope this can be fixed but probably not: [Re: hudsonhornet7x]
Loc: Plumer, Pa
Thank you all for the replies and advice. Since the block is brand new I am excited at the prospect that it can be fixed. I will keep you all updated on the repair.
XP29H8B198192
#2429888 - 01/06/18 10:38 AM Re: I hope this can be fixed but probably not: [Re: hudsonhornet7x]
justinp61 Offline
Loc: W. Kentucky
Talk to your welder about tig brazing with aluminum bronze filler rod.
#2450784 - 02/12/18 03:14 PM Re: I hope this can be fixed but probably not: [Re: hudsonhornet7x]
BradD Offline
Loc: Indiana, Just Off I-70
We have a Silicon Bronze mig welder in the body shop. I believe that would work after V-ing out the sides. may try that first at a local collision shop.
Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
#2450989 - 02/12/18 08:29 PM Re: I hope this can be fixed but probably not: [Re: hudsonhornet7x]
Dragula Offline
Loc: Taxes R-US, NY
You are 3 hours from our shop here near Lockport NY and 2 hours or less away from Bob George Racing in Eighty Four Pa...Yes, it can be fixed, good as new. Don't loose the piece that broke off.
'71 Duster Pump Gas 512LD 2013 Mod Gas Winner GRS
https://www.youtube.com/watch?v=Z_XTmRBuvWs (6.19)
https://www.youtube.com/watch?v=gQZGfDBPROM (9.70 at 138.5mph)
'70 Cuda, Plan C....605 Hemi
https://www.youtube.com/watch?v=WYw6RA-k5Bk (6.31)
#2450993 - 02/12/18 08:35 PM Re: I hope this can be fixed but probably not: [Re: Dragula]
Loc: Plumer, Pa
I still have the piece. Any Idea of cost to fix? Curious is all.
XP29H8B198192
#2451040 - 02/12/18 09:52 PM Re: I hope this can be fixed but probably not: [Re: hudsonhornet7x]
Dragula Offline
Loc: Taxes R-US, NY
Maybe $200 or a little less...Its more labor to get the block up to temp...
Edited by Dragula (02/12/18 09:53 PM)
25,485 Registered Members
192,919 Topics
Monster Musclecar Weekend @ Gateway
by 71yelladustr
09/18/18 10:58 PM
Single feed vs. dual feed carb.
by 440mopar
09/18/18 10:41 PM
Wear can you get A-Body Rear Shackle Hangers?
by Hoop
09/18/18 10:06 PM
Hallmark mystery movie Mopars
by stumpy
09/18/18 09:29 PM
