Efi fuel system setup question #2419610
12/16/17 09:25 PM
12/16/17 09:25 PM
southern Idaho
moparcyco Offline OP
southern Idaho
In this first pic my question is does it matter how the rails are plumbed? Due to how I am going to have to route the fuel lines I was thinking about following the frame rail like factory and mounting the regulator on a bracket off the boss on the front of the cylinder head. And have the inlet to the rails start right behind the alternator and have the crossover line towards the firewall and plug the end by the A/C compressor.
In this second pic you can see how close the rail is to the A/C compressor I don't think anything but a plug in the rail here will work. There is only one inch clearance.
Here is the regulator I am using. The way I understand it if you are using a regulator before the rails this should work? First custom efi setup would like to not mess it up. Thanks
Re: Efi fuel system setup question [Re: moparcyco] #2419623
12/16/17 10:13 PM
12/16/17 10:13 PM
AndyF Offline
AndyF  Offline
Yes that should work. Is there a return line that hooks to that regulator? On my Duster I'm putting the regulator in the back of the car by the fuel tank so the return line is super short. Then I just run the high pressure line up to the front and dead head the rails like you are planning to do.
You'll probably want to put your fuel pressure sensor at the end of the last rail up by the compressor. That way you'll know what the fuel pressure is at the end of the system.
Re: Efi fuel system setup question [Re: AndyF] #2419632
12/16/17 10:34 PM
12/16/17 10:34 PM
IN
ahy Offline
ahy  Offline
IN
On '70 I ran the fuel lines as original (mostly) and mounted the regulator on the right fender well. My system was originally a "loop" system. Pump to one rail, crossover, exit second rail and regulator. My regulator is vacuum referenced like yours and I run a return line.
On freshen, my engine builder convinced me I needed to feed both rails equally so the last injector does not get lower pressure. I now feed both rails through a fuel block, "T" the return and then to regulator. The fuel block is under the manifold and feeds the front of the rails with return on the rear. Still a "loop" system with better balance between rails.
I do like the loop style for bleeding the system... after service or after sitting. In a few seconds, all the air is out.
Re: Efi fuel system setup question [Re: AndyF] #2419704
12/17/17 01:34 AM
12/17/17 01:34 AM
southern Idaho
southern Idaho
Yes it has a return its on the bottom on the regulator. Not sure about fuel pressure sensor? Do you mean a pressure gauge? the regulator has a port for one but I can't decide where to put it. The engine bay is tight I thought about putting it in the back like you are that might be my best bet. Should I drill and tap the end of the rail for a gauge? Thanks
Re: Efi fuel system setup question [Re: moparcyco] #2420091
12/17/17 11:46 PM
12/17/17 11:46 PM
Kingman, Az
Scojodak Offline
Scojodak  Offline
Kingman, Az
There's "tight 90°" an/o-ring elbows out there for the end of that rail.
Dakota for life!
Re: Efi fuel system setup question [Re: moparcyco] #2420122
12/18/17 01:07 AM
12/18/17 01:07 AM
IL
furious70 Offline
furious70  Offline
IL
I have my regular on the back of the pass side rail, cross over in the front, and my pressure isolator for my interior gauge on the back of the driver's side rail. Never had any issues.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Efi fuel system setup question [Re: moparcyco] #2420879
12/19/17 12:11 PM
12/19/17 12:11 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I did my efi conversion like a lot of newer vehicles with the regulator back by the tank. My first though was the fuel needs to flow through the whole system but so many modern vehicles do it so it can't work that bad.
Re: Efi fuel system setup question [Re: DaytonaTurbo] #2420904
12/19/17 01:15 PM
12/19/17 01:15 PM
IL
furious70 Offline
furious70  Offline
IL
I used the factory vapor line as the return but when/if I EFI my Coronet I'll likely do the same, no reason to run all the extra line and run the fuel back and forth
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Efi fuel system setup question [Re: moparcyco] #2420928
12/19/17 02:06 PM
12/19/17 02:06 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Here is my engine bay is setup from a year ago. Its the same now minus the wiper motor.
My first EFI system as well and has worked flawlessly on several track days, thousands of miles, and even in crawling traffic on hot days. I run Aeromotive but do not recommend their stuff since finding out a bunch of current products are Made in China.
I studied their diagrams and built my full return system off that. A benefit is that it keeps the fuel system cooler when road racing.
https://www.aeromotiveinc.com/fuel-cell-diagrams/
I run an ATL fuel cell with an internal 255 Walbro pump to a 10 micron then 100 micron filters. I use XRP stainless braid underneath the car along the factory fuel line path to a one way valve to my Y block. From there it splits to the two fuel rails. There is a bracket that supports the regulator. I run XRP Race Crimp stuff as its easy to measure and install, PTFE lined to use with all fuels.
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Efi fuel system setup question [Re: RylisPro] #2420963
12/19/17 03:22 PM
12/19/17 03:22 PM
Cab_Burge Online work
Cab_Burge  Online Work
I was told by Rich at Fastman EFI to not dead end fuel to either fuel rail, it needs to circulate back to the tank through both rails so one side of the motor doesn't see different fuel pressure than the other work shruggy
I'm plumbing a hemi motor for dyno testing now and will rearrange the fuel system and wiring after this once the motor is in the car.
I'm routing the fuel feed from the pump through one side fuel rail and then looping it on the back side to the other side and then back through the regulator and then return it to the cell wrench
Lots of fun joining this generation of fuel controls whistling grin
Better now than later boogie
Re: Efi fuel system setup question [Re: moparcyco] #2421076
12/19/17 07:05 PM
12/19/17 07:05 PM
IL
furious70 Offline
furious70  Offline
IL
Don't know anymore than my own experience but mine has run fine and with a eddy rpm perf intake I've managed to have 8 spark plugs that are virtually identical over 8 years of street driving.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Efi fuel system setup question [Re: moparcyco] #2421117
12/19/17 08:53 PM
12/19/17 08:53 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Mine deadheads at the rail, the filter/regulator is back near the tank. Seems to work okay thus far, but I do get a few psi drop when i really nail the throttle [logged near the rail]. As long as it's consistent, that's all that really matters..
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Efi fuel system setup question [Re: moparcyco] #2421628
12/20/17 10:23 PM
12/20/17 10:23 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
You want to minimize any "dead heading" if possible. With a dead headed fuel system an air bubble (from cavitation or a low fuel tank level) needs to flushed out through the injector which can cause a rough spot. Also, full flow plumbing keeps all the fuel at the same temperature. It's just a better way to go.
Re: Efi fuel system setup question [Re: Mopar_Rich] #2421632
12/20/17 10:36 PM
12/20/17 10:36 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
...works for every factory Hemi since 2003. (and many other OEMs) shruggy
Their pumps may be pwm to help with temperature, but that won't help the bubble problem.
2020 RAM 1500
