B engine Holley S/D #2418537
12/14/17 04:41 PM
12/14/17 04:41 PM
ocean springs ms. usa
O
old915 Offline OP
old915  Offline OP
O
When porting this intake, should the small dams in the back of the plenum be removed? The RB Holley S/D doesnt have them.Is there a fuel distribution issue with the B intake?
Re: B engine Holley S/D [Re: old915] #2418904
12/15/17 10:25 AM
12/15/17 10:25 AM
I would leave them. I have no dyno/porting exp (ex for minor port matching/contouring) but I think the odds are greater that even with porting that their bennie would not be eliminated.
Re: B engine Holley S/D [Re: RapidRobert] #2419897
12/17/17 03:48 PM
12/17/17 03:48 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I agree, work the plenum to port roof transitions, particularly where the cylinders fire consecutively (2-1) and (5-7). Really a flat floor in the SD design, I never found any power there.
Talk to member GY3, he bought my RB manifold that he runs on his 500 stroker, everyone whose ever done my plenum/runner mods to a SD seems to pick up at least an easy tenth tenth and 1-2 MPH. Even more power available if you can run a carb spacer and jet up a tad.
WIZE
In Car:
Re: B engine Holley S/D [Re: old915] #2420158
12/18/17 01:49 AM
12/18/17 01:49 AM
Earth
Rob C Offline
Rob C  Offline
Earth
Leave the floor danms because Holley did the work to balance the intake where ma Mopar told you to add them in on there intakes
