need advice on priming problem #241818
03/03/09 11:15 AM
03/03/09 11:15 AM
Denver Co.
BadBelvedere Offline OP
Denver Co.
Need more help! I posted yesterday on a psi Question. now I have a little problem. I have a external line on my oil pump to the pan, I did put a loop in the line. I have a duel remote oil filter system. I had primed it yesterday with a little help from some vaseline in the pump. It worked good. i checked it all day and everything was good. This morning I turned over the Engine and no oil PSI. What do I do?
Thanks!
Re: need advice on priming problem [Re: BadBelvedere] #241819
03/03/09 11:31 AM
03/03/09 11:31 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What pick up system.... sounds like its sucking air
Re: need advice on priming problem [Re: MR_P_BODY] #241820
03/03/09 11:44 AM
03/03/09 11:44 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Re: need advice on priming problem [Re: MR_P_BODY] #241821
03/03/09 12:00 PM
03/03/09 12:00 PM
Denver Co.
Denver Co.
It's a mildon dragster style pan with a swinging pick up. It has two inlets one is pluged the other is hooked up. Wouldent it leak oil? Also I did plug the old pick up hole I did change the plug over the winter?? The system has been on the car for two years now. for some reason it's giving me problems. Maby pull the pan and have a look.??
Thanks again, John
Re: need advice on priming problem [Re: BadBelvedere] #241822
03/03/09 12:17 PM
03/03/09 12:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The swinging pick ups seem to give people problems,
I think its the O-ring joint
