Clutch pedal spring removal with diaphragm clutches?
#2417735
12/13/17 01:32 AM
12/13/17 01:32 AM
Posts: 1,043 Motown, Mi
PAULS_340
Motown, Mi
i was told that you have to remove the large clutch pedal spring if you go with a diaphragm style (Centerforce) clutch. Apparently, over 5,000 rpm the pedal goes to the floor and won't come back???
Still looking for LM29H1B415501, '71 Demon 340
Re: Clutch pedal spring removal with diaphragm clutches?
[Re: PAULS_340]
#2417737
12/13/17 01:38 AM
12/13/17 01:38 AM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: PAULS_340]
#2417993
12/13/17 04:08 PM
12/13/17 04:08 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
I had mine on for a while and never a problem.Then I remived it and its been of for at least 15 years now.The CF clutch is that old also.Still like the day it went in and it gets beat on.Rocky
Chrysler Firepower
[Re: second 70]
#2421715
12/21/17 02:01 AM
12/21/17 02:01 AM
PAULS_340
Motown, Mi
second 70, thanks for the advise as to how to get the spring off; big help.
[Re: PAULS_340]
#2421773
12/21/17 09:52 AM
12/21/17 09:52 AM
therocks
Niles , Ohio
Easy way to remove is depress pedal.Install washers between the coils.Then let pedal up and it should come out pretty easy.My son did mine.Took him about 10 minutes total.Rocky
Chrysler Firepower
[Re: therocks]
#2421836
12/21/17 01:30 PM
12/21/17 01:30 PM
Posts: 2,252 New York
rarefish
New York
A few months back I had to make the decision whether to go with a diaphragm clutch and remove the spring or buy another B&B clutch and leave the spring in. I have read a lot of stories on how easy it is to remove the spring using the washer method and also about the battles some people had getting the spring out. I decided in the end not to try and remove the spring expecting a battle. So I went just bought another B&B clutch.
Look at the pictures below. At the time, they helped me make my decision to not mess with the spring.
The first one is with the pedal all the way up. The spring coils are slightly open.
The second picture is with the pedal all the way to the floor. The coils are hardly open.
I had expected that when I put the pedal all the way to the floor that the coils in the spring open up with decent gap for the washers, but that was not the case as you can see.
[Re: 71birdJ68]
#2421887
12/21/17 04:10 PM
12/21/17 04:10 PM
rarefish
New York
The reason for that is the spring kind of goes over center. I know the idea on the spring operation. I just thought the spring would have been stretch more with the pedal on the floor then with the pedal being all the way up. There is more pedal travel from the over center point with the pedal on the floor then there is with the pedal all the way to the top.
[Re: rarefish]
#2425168
12/29/17 12:05 AM
12/29/17 12:05 AM
Posts: 3,069 Michigan
A727Tflite
The reason for that is the spring kind of goes over center. I know the idea on the spring operation. I just thought the spring would have been stretch more with the pedal on the floor then with the pedal being all the way up. There is more pedal travel from the over center point with the pedal on the floor then there is with the pedal all the way to the top. When you have a chance take a look at the spring midway between all the way up and down. Or just watch the gap between the coils as you go from all the way up to all the way down.
[Re: A727Tflite]
#2425554
12/29/17 10:22 PM
12/29/17 10:22 PM
rarefish
New York
The reason for that is the spring kind of goes over center. I know the idea on the spring operation. I just thought the spring would have been stretch more with the pedal on the floor then with the pedal being all the way up. There is more pedal travel from the over center point with the pedal on the floor then there is with the pedal all the way to the top. When you have a chance take a look at the spring midway between all the way up and down. Or just watch the gap between the coils as you go from all the way up to all the way down. If it ever warms up a little, I will do that...
