Re: arp intake bolts for aluminum intake what lenght
[Re: moparpro]
#2417383
12/12/17 03:29 PM
12/12/17 03:29 PM
Posts: 1,552 Michigan
Kiddart
check the depth of the intake thread on head, check them all, do the average add in the thickness of the manifold and there you have it. I didn't do this on my SB Indy heads and ended up having to cut most of them down. had different depths on the taps.
Thanks Indy!!
Thank you Kiddart
[Re: moparpro]
#2417387
12/12/17 03:33 PM
12/12/17 03:33 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Factory Intake Bolts For 1970/1971 383 Magnum
3/8" 16
1 11/16" Length
I am running the Weiand Intake on my 383 Magnum with Edelbrock Heads
Using ARP Black Intake Bolts 6 Head Hex - Part # 144-2001
Can measure exact length when i get home if needed as they give you 12 bolts when only 8 are needed
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: moparpro]
#2417394
12/12/17 03:42 PM
12/12/17 03:42 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Oh for christ sake, if you cannot figure out what length intake bolt you need you should A. take "pro" out of your moniker and B. start playing with legos.
[Re: moparpro]
#2417574
12/12/17 08:51 PM
12/12/17 08:51 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
Do you have a way to measure(dial calipers maybe) the thickness of the bolt boss on that intake ? If so add 1/2 to 5/8 onto that under the head of the bolt length if your not using washers under the bolt heads If your going to use flat washers, my recommendation is to use them always, especially on aluminum intakes add the thickness of the washers to that length All the stock cast iron wedge heads I've seen are open on the engine side of the head intake mounting flanges so you can use a longer bolt than is needed with out worrying about it bottoming out I've use some intake bolts on wedge race motors with worn threads in the heads 1/2 to 1.0 inch longer(1/2 inch or more sticking out of the boss towards the heads ) than needed to get as much thread engagement I could get so they would torque down properly (35 Ft.Lbs.) without adding a Helicoil repair insert
[Re: moparpro]
#2417581
12/12/17 09:00 PM
12/12/17 09:00 PM
Kiddart
Moparpro,
take comments like that with a grain of salt. some guys feel better making fun of others that may just want the answer to make them feel they are on the right track.
You keep asking questions, I know I still do!!!!!!
Thank you Kiddart
[Re: moparpro]
#2417591
12/12/17 09:19 PM
12/12/17 09:19 PM
bee1971
Sobieski Wi
ARP 1 3/4" - Total Length from starting tip to bottom of head
Then they supply a 1/8" thick washer for each bolt
[Re: bee1971]
#2417907
12/13/17 01:35 PM
12/13/17 01:35 PM
Posts: 514 georgia
moparpro
georgia
thank you bee71 for your time and effort.
[Re: moparpro]
#2417996
12/13/17 04:11 PM
12/13/17 04:11 PM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
Just find a good harware store get some stailess bolts and washers.Use antisieze and install.God its not a part that gets lots of torque like a rod flywheel etc.I did my heads aluminum and M1 intake like 14 years ago.Never had to touch them since.Rocky
Chrysler Firepower
