Re: Petronix on a dual point distributor
[Re: Moparnut426]
#2417560
12/12/17 08:36 PM
12/12/17 08:36 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
well today I google it and see a listing
sorry guys The kit will work but you will have to open the one mounting slots about .010 and you will also be one wire off on the cap.
[Re: 62maxwgn]
#2417835
12/13/17 11:25 AM
12/13/17 11:25 AM
Posts: 12,008 Finally a HUSKER again
Moparnut426
sorry guys The kit will work but you will have to open the one mounting slots about .010 and you will also be one wire off on the cap. So I just will have to move the wires 1 terminal closkwise or counter clockwise, and why would changing the guts make that difference? The distributor shaft and rotor aren't physically changed.
[Re: Moparnut426]
#2418316
12/14/17 02:05 AM
12/14/17 02:05 AM
62maxwgn
Blair County,PA
sorry guys The kit will work but you will have to open the one mounting slots about .010 and you will also be one wire off on the cap. So I just will have to move the wires 1 terminal closkwise or counter clockwise, and why would changing the guts make that difference? The distributor shaft and rotor aren't physically changed. Because after relocating the mounting hole it changes the position of the pick up coil enough that you have to change wires orientation.
[Re: Moparnut426]
#2418318
12/14/17 02:08 AM
12/14/17 02:08 AM
62maxwgn
Blair County,PA
sorry guys The kit will work but you will have to open the one mounting slots about .010 and you will also be one wire off on the cap. So I just will have to move the wires 1 terminal closkwise or counter clockwise, and why would changing the guts make that difference? The distributor shaft and rotor aren't physically changed. Because after relocating the mounting hole it changes the position of the pick up coil enough that you have to change wires orientation.I've done enough to know.
[Re: rarefish]
#2419821
12/17/17 01:02 PM
12/17/17 01:02 PM
RapidRobert
just me I'd redrill the hole(s) either in the dist plate or the P plate but with vac adv shifting the plate you'd sure wanna get things correct so the gap stays in a good range thruout the travel but understood that it should be a bolt in in the first place.
[Re: rarefish]
#2420370
12/18/17 03:35 PM
12/18/17 03:35 PM
62maxwgn
Blair County,PA
When I sent that photo to pertronix they told me to open up the mounting holes in the Ignitor mounting plate in order to mount it. I then said what about the gap. They then said "Oh yeah....you want it to be about .060". The one that they told me to buy for my 69 340 Prestolite dual point was the one that was listed for the Gen I Hemi. The gap is why you have to change the plug wire orientation,they probably didn't tell you that.
[Re: dragon slayer]
#2420912
12/19/17 01:41 PM
12/19/17 01:41 PM
Posts: 531 Charlotte, NC
Kowal
Charlotte, NC
Why do it to a dual point? You can get a Chrysler electronic one cheap enough. Or convert a single point prestolite if you want the cast distributor look. I will trade you one. :-) I bought a single point from Rock Auto, made sure to paint the housing black as it would have been, then did the Petronix conversion. Works great, looks great as well.
'69 Hemi Charger 500, ‘70 U code Challenger R/T (These and a bunch others at www.dkowal426.com) P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
