Page 4 of 6 1 2 3 4 5 6
Re: The white car makes it's new best [Re: Thumperdart] #2416954
12/11/17 08:36 PM
12/11/17 08:36 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
Originally Posted By Thumperdart
Originally Posted By WHITEDART
Also running a very small pinch on The Collector to help accelerate the car sooner.. looking at the race pack stuff my fuel pressure is all the way down to one lb of pressure. In high gear that's why it's not charging down track.. I think I'm going to skip the 5:30 and go right for the five 20s.. I have to stay faster than my cylinder head guy. Because he has has too many gears
I was going to say your car sounded like it was struggling going down the track and a little blubbery at idle but didn't want to piss off your carb guy.......... biggrin What fuel system are you running..........
the fuel system starts off Outback with a 4-gallon cell a - 10 to the pump through a filter to a dash 8
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: The white car makes it's new best [Re: WHITEDART] #2416956
12/11/17 08:38 PM
12/11/17 08:38 PM
bean town ....Ca
W
W
bean town ....Ca
28 quick fuel 400 pump.. and then with approximately 10 or 12 ft of aluminum Hardline half inch to the to the regulator after that 2-6 lines to the carburetor.. basically the entire system is not up to standard for what I'm doing.. it will be getting upgraded shortly
Re: The white car makes it's new best [Re: WHITEDART] #2416961
12/11/17 08:41 PM
12/11/17 08:41 PM
bean town ....Ca
W
W
bean town ....Ca
As far as the carburetor is concerned.. it was built for c25... and set up for an engine that is completely different from mine.. then top it off I'm running oxygenated race fuel.. which just seems to piss the carburetor off...
Re: The white car makes it's new best [Re: WHITEDART] #2416971
12/11/17 08:53 PM
12/11/17 08:53 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That system should work........what micron pre filter and maybe the reg is acting up or something........... work Is that a BG 400..........If so, maybe time to step up cos those have created real issues for most everyone I know.......... thumbs
Re: The white car makes it's new best [Re: WHITEDART] #2416972
12/11/17 08:54 PM
12/11/17 08:54 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
with all that said, it still ain't a slouch.
Re: The white car makes it's new best [Re: CSK] #2416973
12/11/17 08:58 PM
12/11/17 08:58 PM
bean town ....Ca
W
W
bean town ....Ca
this is the run that went with that time slip
Re: The white car makes it's new best [Re: WHITEDART] #2416974
12/11/17 08:58 PM
12/11/17 08:58 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
"I have to stay faster than my cylinder head guy. Because he has has too many gears."
I think you're both cheaters, one shift or two shifts......not enough! LOL!
Can't wait to get my little ol' truck engine done.
Re: The white car makes it's new best [Re: WHITEDART] #2416977
12/11/17 09:04 PM
12/11/17 09:04 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
this is the run that went with that tanks that
I see 12.5 volts do u run an alternator............
Re: The white car makes it's new best [Re: Thumperdart] #2416980
12/11/17 09:06 PM
12/11/17 09:06 PM
bean town ....Ca
W
W
bean town ....Ca
Nope 3 lb lithium
Re: The white car makes it's new best [Re: WHITEDART] #2416986
12/11/17 09:19 PM
12/11/17 09:19 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
A customer recently dynoed a carb I did and at 6400 it started loosing fuel pressure and going lean due to the big pump needing more volts so he added an alt and haven't heard back.......If that 12.5 is the voltage at 7100 rpm's, then the battery isn't cuttin it imo............
Re: The white car makes it's new best [Re: WHITEDART] #2417022
12/11/17 10:28 PM
12/11/17 10:28 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
that would be interesting Shiloh concerning that new battery. Does the voltage stay there during the pass?
Re: The white car makes it's new best [Re: J_BODY] #2417026
12/11/17 10:34 PM
12/11/17 10:34 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I wouldn't be happy about that voltage either. 12.5 is about 50% charge, but it does seem to be working ok. You would see 13.8/14.2 w3ith a alt. Maybe time for two of those 3# bats just to insure enough reserve voltage.
But reguardless of that, Your car flys, your getting her Done!! up
Re: The white car makes it's new best [Re: Thumperdart] #2417027
12/11/17 10:35 PM
12/11/17 10:35 PM
Cab_Burge Online work
Cab_Burge  Online Work
The pump and the MSD race ignitions can suffer from low voltage shruggy
Maybe it is time for two 16 V batteries or a big amp alternator work
I saw a slight ET(.003 to .004) and MPH loss(.17 to.2 MPH) on my old M.W. stocker by turning off the alternator feed before the runs with a charged up battery on back to back runs three times shruggy
When your chasing every bit, a thousands can make a difference grin
Re: The white car makes it's new best [Re: J_BODY] #2417028
12/11/17 10:36 PM
12/11/17 10:36 PM
bean town ....Ca
W
W
bean town ....Ca
considering I have set the bypass and the regulator pressure at that voltage
It should be fine.. I have a lot of sharp bins in the fuel line. And possibly some restrictive fittings..
Re: The white car makes it's new best [Re: WHITEDART] #2417034
12/11/17 10:48 PM
12/11/17 10:48 PM
bean town ....Ca
W
W
bean town ....Ca
I will check with quick fuel in the morning to see if I'm meeting the voltage requirements.. but they're definitely will not be an alternator on this anytime soon
Re: The white car makes it's new best [Re: WHITEDART] #2417139
12/12/17 01:51 AM
12/12/17 01:51 AM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
I was reading the leaf spring thread from last year and you’ve definitely gotten things figured out seeing your 60’s in the sub 1.2x range. Congrats on the gains. What changes ultimately got you there? Thicker front and rear spring segments? Shocks?
Thanks again for sharing your progress!
Re: The white car makes it's new best [Re: WHITEDART] #2417143
12/12/17 01:58 AM
12/12/17 01:58 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Its not just the fuel pump/pumps you need to worry about but the ignition systems as well. At 12.5 volts funny things can start to happen. Your at the edge/cliff with that new batt, maybe that 12,5 volt reading was after several runs. shruggy
Re: The white car makes it's new best [Re: humpty] #2417147
12/12/17 02:04 AM
12/12/17 02:04 AM
bean town ....Ca
W
W
bean town ....Ca
we're still running the lowering blocks and the heavier rear segment.. nothing has really changed except for shock settings. And more power.. however I'm in the process of getting rid of the lowering blocks and maintaining the same height
Re: The white car makes it's new best [Re: Sport440] #2417148
12/12/17 02:07 AM
12/12/17 02:07 AM
bean town ....Ca
W
W
bean town ....Ca
the ignition system in this car will tell me if there's an issue regarding low voltage.. it seems to hold very well at 12.5 volts..
Re: The white car makes it's new best [Re: SCATPACK 1] #2417266
12/12/17 12:23 PM
12/12/17 12:23 PM
bean town ....Ca
W
W
bean town ....Ca
Originally Posted By SCATPACK 1
What size front and rear tires are you running?
Mickey Thompson's all the way around..26 fronts 29.5 10.5 S .. with tubes
