What to pack for Dragweek???bucket list
#2417059
12/11/17 11:20 PM
12/11/17 11:20 PM
Posts: 1,505 TN
SCATPACK 1
TN
Really would like to attend Dragweek this year and get it off my bucket list. Especially since it is in my back door. Some questions; #1, What class would a 440 4 speed Challenger run in. No nitrous #2, What emergency items are most needed to take along for any road side or track emergencies. #3, I understand you cannot use outside help for car repairs, but can you go to a repair shop with a lift (assuming u can get there under your own power)? #4, do they allow camping , the night before? I assume it will fill up the first few minutes this yer when announced. But hoping to be able to get in on a stand by basis if I can not make the onsite registration in time. Thanks
Old Geezer Racing
Re: What to pack for Dragweek???bucket list
[Re: SCATPACK 1]
#2417071
12/11/17 11:53 PM
12/11/17 11:53 PM
Posts: 12,386 Taxes & Virus's R-US, NY
Dragula
If I had to guess.....
1-case engine oil, 2-filters 1-set front wheel bearings 1-case trans oil and filters (auto only) 1-spare fuel pump 1-starter & relay -gaskets! jack & stands spare wiring & connectors, electrical tape test light & volt meter, fuses, bulbs! 2- sets spark plugs Carb parts & gaskets cap, rotor, wires brake pads
If its well road tested, maybe less
[Re: Dragula]
#2417080
12/12/17 12:11 AM
12/12/17 12:11 AM
Posts: 52,972 Romeo MI
MR_P_BODY
You forgot the most important thing.. beer and cooler.. I have a list I put together when I was gonna go.. its out in the shop.. I'll see if I can find it tomorrow EDIT 100 MPH tape and tie wraps EDIT1 How quick is the car.. if under 10.0 you need a cert.. if 11.49 to 10.0 you need a roll bar
[Re: MR_P_BODY]
#2417110
12/12/17 01:09 AM
12/12/17 01:09 AM
Posts: 1,505 TN
SCATPACK 1
TN
P Body I am not sure how fast, yet. Putting a new motor together this winter. Expect 10.80 or so, based on what my cousin ran with his coronet with similar weight and motor and suspension.
Old Geezer Racing
[Re: SCATPACK 1]
#2417111
12/12/17 01:11 AM
12/12/17 01:11 AM
Posts: 7,489 Minnesota
Hemi_Joel
Minnesota
Really would like to attend Dragweek this year and get it off my bucket list. Especially since it is in my back door. You will love it, go for it! Some questions; #1, What class would a 440 4 speed Challenger run in. No nitrous Probably Street Machine Eliminator, or Street Race, big block naturally aspirated #2, What emergency items are most needed to take along for any road side or track emergencies. A jumper pack with a built in air compressor, tire plug kit, fan belt, fire extinguisher, fuel pump, some wire, fuses and bulbs, a pint of Old Harper, jack and jack stand(s), any spare parts you have laying around like voltage regulator, ballast resistor, points and condenser, gas can, etc. #3, I understand you cannot use outside help for car repairs, but can you go to a repair shop with a lift (assuming u can get there under your own power)? Correct #4, do they allow camping , the night before? It depends on the track, you would need to contact them. Sometimes, enuff people ask that the info gets posted online at bangshift or facebook. I assume it will fill up the first few minutes this yer when announced. But hoping to be able to get in on a stand by basis if I can not make the onsite registration in time. That has always worked so far, but there is a risk. Good luck! Thanks
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: SCATPACK 1]
#2417117
12/12/17 01:17 AM
12/12/17 01:17 AM
Posts: 8,022 Tulsa OK
Bad340fish
Tulsa OK
Bring anything you cannot get on the road, for example an electric water pump if you have one. Some valve train pieces are always good ideas for spares. It never hurts to carry some ignition pieces as well.
68 Barracuda Formula S 340
[Re: MR_P_BODY]
#2417136
12/12/17 01:48 AM
12/12/17 01:48 AM
moparpollack
Lil Herman
Lil Herman
85086
You forgot the most important thing.. beer and cooler.. I have a list I put together when I was gonna go.. its out in the shop.. I'll see if I can find it tomorrow EDIT 100 MPH tape and tie wraps EDIT1 How quick is the car.. if under 10.0 you need a cert.. if 11.49 to 10.0 you need a roll bar Beer? More like water and 5 hour energy unless you are Austrailian. Pillow and a blanket as you never know where your next nap will be. Zip ties of all sizes (we used a set on a set of coil overs at Gateway) A tarp for shade or roadside emergencies. Screw drivers that can be used as a pry bar. Will a four speed I would bring an extra yoke and u joints linkage bushings, etc. All sealants available to man, jugs and funnels for water or gas. Whatever you do something will be left behind.
[Re: moparpollack]
#2417145
12/12/17 02:03 AM
12/12/17 02:03 AM
MR_P_BODY
If you do run 10.80 you will need a roll bar and a helmet.. if you test the car well before the date and its running good you wont need a ton of stuff
[Re: SCATPACK 1]
#2417385
12/12/17 03:30 PM
12/12/17 03:30 PM
Posts: 200 AB
Efidart
AB
In addition to stuff above..
If you run a generic oil, bring a quart or 2 for the road and pick it up along the way. Spare oil filter as you want to do a change on Wednesday morning at least. If you run something like Brad Penn 20W50.. unless they say the fuel guys stock it, be sure you bring some!
Mechanics wire is always a good one I've seemed to use every year.
Spare pushrods, rocker adjusters (almost every year someone asks me for one), spare rocker if you have one and lifters if you are running decent spring PSI.
Spare fuel line is not a bad idea either, and a spare pump with fittings.
Dremel with an assortment of bits..
Gasket material that will cover for intake, thermostat housing etc..
Axle bearings aren't a bad idea if you haven't done them for a while..
Spare lug nuts and a stud or 2 if you are going to swap tires doesn't hurt.
Gas can!
Fuses
Spare coil and misc ignition stuff as stated above.
Last but not least-> Credit card with a bunch of room on it!
TT Predator headed 572 7 Second Street Car. Fastest Mopar Drag Week 2015 Fastest Mopar & Dodge Drag Week 2017 Pro Street Power Adder Champion Drag Week 2017
[Re: Efidart]
#2417403
12/12/17 03:55 PM
12/12/17 03:55 PM
MR_P_BODY
Will you be hauling a trailer.. it is nice.. load all your stuff in there plus being that your new to the game you can get on the move quicker.. I built a small enclosed one for it.. but my car is small and NO SPACE being a little PU with no bed
[Re: SCATPACK 1]
#2417411
12/12/17 04:04 PM
12/12/17 04:04 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I brought a extra $15 ebay electric fan. Tool box. Aluminum jack
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#2417563
12/12/17 08:38 PM
12/12/17 08:38 PM
Posts: 1,505 TN
SCATPACK 1
TN
All good suggestions. Thinking a small trailer might be the way to go. Not sure how I am going to mount a trailer hitch on my 70 Challenger just yet. I am starting to get excited about this and really looking forward to it. Already had my son and his bro in law volunteer for trunk monkey. Being my first long trip (or group of trips) I may soften the cam a little bit ... or I may not and just deal with it. IF a group of 2 or 3 cars go together, i assume it is OK to pack extra stuff into one trailer. Or is that a no no.
Old Geezer Racing
[Re: MR_P_BODY]
#2417565
12/12/17 08:41 PM
12/12/17 08:41 PM
Posts: 1,505 TN
SCATPACK 1
TN
If you do run 10.80 you will need a roll bar and a helmet.. if you test the car well before the date and its running good you wont need a ton of stuff Raff, IF I decide to detune a little and I am only running say 11.50, do I need certified belts and a helmet?
Old Geezer Racing
[Re: SCATPACK 1]
#2417566
12/12/17 08:43 PM
12/12/17 08:43 PM
Posts: 1,505 TN
SCATPACK 1
TN
IF I were to pack a pint of Old Harper, I would not remember the trip... unless I was using it as rubbing alcohol for my old joints. hahah
Old Geezer Racing
[Re: SCATPACK 1]
#2417579
12/12/17 08:57 PM
12/12/17 08:57 PM
MR_P_BODY
If you do run 10.80 you will need a roll bar and a helmet.. if you test the car well before the date and its running good you wont need a ton of stuff Raff, IF I decide to detune a little and I am only running say 11.50, do I need certified belts and a helmet? Not sure about the helmet.. I dont think you need the certed belts
[Re: SCATPACK 1]
#2417596
12/12/17 09:32 PM
12/12/17 09:32 PM
Posts: 200 AB
Efidart
AB
Mr_P_Body have you made it to a drag week yet? I know you've always been talking about it but haven't seen you at one yet?
[Re: Efidart]
#2417606
12/12/17 09:48 PM
12/12/17 09:48 PM
MR_P_BODY
Mr_P_Body have you made it to a drag week yet? I know you've always been talking about it but haven't seen you at one yet? I've been 3 times..its no big deal any more.. I will probably do a 3 day that we have in MICH this year
[Re: SCATPACK 1]
#2417707
12/13/17 12:39 AM
12/13/17 12:39 AM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
If you’re from Canada bring your own smokes, beer and weed.... all three of the American stuff is to weak...
A new iron curtain drawn across the 49th parallel
