Re: SBM victor set up
[Re: 420duster]
#2416614
12/11/17 02:19 AM
12/11/17 02:19 AM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
Nice pass Jason. Whats your car weigh? What tranny?
[Re: WHITEDART]
#2416861
12/11/17 05:42 PM
12/11/17 05:42 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
I agree! I believe the China wall will be a far better place to bring the oil in from what I've seen on our cast iron block...assuming yours is the same. Where are you bringing in oil on yours Shiloh?
Brian Hafliger
[Re: Brian Hafliger]
#2416879
12/11/17 06:16 PM
12/11/17 06:16 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I agree! I believe the China wall will be a far better place to bring the oil in from what I've seen on our cast iron block...assuming yours is the same. Where are you bringing in oil on yours Shiloh? bringing it in the China wall.. Brian you can always call me anytime if you would like to compare notes...
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#2418127
12/13/17 08:04 PM
12/13/17 08:04 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
I agree! I believe the China wall will be a far better place to bring the oil in from what I've seen on our cast iron block...assuming yours is the same. Where are you bringing in oil on yours Shiloh? bringing it in the China wall.. Brian you can always call me anytime if you would like to compare notes... I will do that when I start working on it again....prolly Feb. Thank you!
Brian Hafliger
[Re: WHITEDART]
#2418139
12/13/17 08:44 PM
12/13/17 08:44 PM
Posts: 9,868 MI, usa
dvw
MI, usa
the issue with mine was 100% the blocks fault.. finally was able to get it squared away.. have approximately 24 passes in all or oil filters are beautiful.. before I was replacing bearings at 10 to 12 runs.. and never found a good oil filter.. there's another guy running around here with a Ritter block that is killing bearings to.. i So what was the block issue? How did you fix your bearing problem? Doug
[Re: dvw]
#2418157
12/13/17 09:21 PM
12/13/17 09:21 PM
WHITEDART
bean town ....Ca
This image is looking at the front of the block
[Re: WHITEDART]
#2418159
12/13/17 09:22 PM
12/13/17 09:22 PM
WHITEDART
bean town ....Ca
The top plug is the lifter galley.. the bottom plug is the main feed.. don't pay any attention to the one that has the milk running out of it that's the cam tunnel drain
[Re: WHITEDART]
#2418160
12/13/17 09:24 PM
12/13/17 09:24 PM
WHITEDART
bean town ....Ca
This picture is taken with the main feed plug out looking up towards the lifter galley... the one with the light coming through it was down size to 5/16.. just before it got to the main feed which was clearly not enough oil to feed all the rods and mains
[Re: WHITEDART]
#2418164
12/13/17 09:29 PM
12/13/17 09:29 PM
WHITEDART
bean town ....Ca
This picture was taken looking down from the top of the China wall it was drilled short approximately 1in of hitting the main feed... I upsized the drill bit one at a time until until I was happy with the size.. and yes in the top photo there was water in the oil because of porosity in the Block in the cam tunnel area just in case you were wondering what that white stuff was... essentially cutting our Dyno day short
[Re: Jason B]
#2418259
12/14/17 12:42 AM
12/14/17 12:42 AM
B3422W5
Portage,michigan
Scott trust me he knows that I've talked to him a few times he's a one man show I believe he's doing what he can he has fought several issues with the foundries making the blocks. Last I spoke to him he was going to a new foundry with high hopes not sure if he's had any luck. But as I said before at least he's trying Your a good and patient man. Kent should be skinned alive for taking money for such junk
[Re: 420duster]
#2418425
12/14/17 12:40 PM
12/14/17 12:40 PM
Posts: 103 Kansas, Topeka
69 lawndart
Kansas, Topeka
At this point in time the aluminum Ritter block in mine has been great, no problems. WhiteDart are you feeding the oil into the motor on the front China wall? I drilled and taped the hole between the upper and lower oil gallies and put a restricter in to slow the oil down going to the top end. I am feeding mine through the back of the block.
