Trick flow lo deck intake #2416656
12/11/17 05:15 AM
12/11/17 05:15 AM
Mt Morris Michigan
mopar dave Online content OP
mopar dave  Online Content OP
Mt Morris Michigan
Does Trick Flow offer a lo deck intake for the MW Victor head?
Re: Trick flow lo deck intake [Re: mopar dave] #2416666
12/11/17 06:21 AM
12/11/17 06:21 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
No
Re: Trick flow lo deck intake [Re: CSK] #2416668
12/11/17 06:37 AM
12/11/17 06:37 AM
Mt Morris Michigan
Mt Morris Michigan
Not much to pick from for lo deck. Guess the indy 400-3 is the best i can do with MW Victors.
Re: Trick flow lo deck intake [Re: mopar dave] #2416803
12/11/17 04:01 PM
12/11/17 04:01 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
Yeah. Low decks are the red headed step child when it comes to MW ports.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: Trick flow lo deck intake [Re: mopar dave] #2416806
12/11/17 04:14 PM
12/11/17 04:14 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I guess I look at it as...... How many different intakes do you need?
If you're running MW heads, I would just assume you're doing that because you're trying to make some power....... And the Indy intakes are fine for that.
If you're looking for a kinder gentler low deck stroker, run std port heads, and then there are more choices suitable for lower power level builds.
Re: Trick flow lo deck intake [Re: fast68plymouth] #2416817
12/11/17 04:28 PM
12/11/17 04:28 PM
Mt Morris Michigan
Mt Morris Michigan
I was mostly curious to any choices, but doesn't look like theres much. I will be happy with my current 400-3, open the plenum and add a 4 hole tapered and see if that clears up the distribution issue I have with it. Thanks guys
Re: Trick flow lo deck intake [Re: mopar dave] #2416851
12/11/17 05:31 PM
12/11/17 05:31 PM
So. Burlington, Vt.
So. Burlington, Vt.
Not specifically for a low deck, but it would be interesting to see how a manifold that was basically a TF single plane, but with the cross section of the runners scaled up to MW size, would work.
Re: Trick flow lo deck intake [Re: mopar dave] #2416866
12/11/17 05:51 PM
12/11/17 05:51 PM
AndyF Offline
AndyF  Offline
I've told TF a few times that since they have the 270 heads they should have a matching intake manifold. Based on the fact that they haven't released any MW intakes I'm guessing that they don't listen to me......
I also told them they should put EFI bosses on their intake manifolds. They didn't listen to that advice either.
Re: Trick flow lo deck intake [Re: mopar dave] #2417073
12/11/17 11:55 PM
12/11/17 11:55 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
I machined and blended the cloverleaf off my Manifold. Next year I will see if that was a mistake or not?
Will also have a 2” spacer as I have the room under the hood.
Re: Trick flow lo deck intake [Re: Wookie316] #2417102
12/12/17 12:56 AM
12/12/17 12:56 AM
Mt Morris Michigan
Mt Morris Michigan
I set my 4 hole tapered spacer on mine and some of the cloverleaf is right out in the air stream. I have to remove it or the spacer is useless. Was hoping TF had something for me than id just sell the 400-3.
Re: Trick flow lo deck intake [Re: mopar dave] #2417290
12/12/17 12:57 PM
12/12/17 12:57 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Has anyone run the 400-15 Tunnel ram intake?
Re: Trick flow lo deck intake [Re: 451Mopar] #2417470
12/12/17 05:52 PM
12/12/17 05:52 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Yes
Re: Trick flow lo deck intake [Re: mopar dave] #2417472
12/12/17 05:55 PM
12/12/17 05:55 PM
Carson City, Nevada
Carson City, Nevada
Pic
