Steering Wheel Vibrates Only Idle In D
#2415991
12/10/17 01:17 AM
12/10/17 01:17 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
70 Challenger: steering wheel has a mild vibration only at idle in D at a stop. Driving, all is smooth no matter the speed. If I have my hand on the wheel at a stop, I can feel the vibration. If I let go of the wheel at idle in D, the wheel vibrates. What should I look for? No knocks, no noises. Engine mounts, loose steering unit? Do I need a rubber insulator on the steering column?
Thanks!
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: Steering Wheel Vibrates Only Idle In D
[Re: DAYCLONA]
#2416031
12/10/17 02:22 AM
12/10/17 02:22 AM
YO7_A66
Indiana
They don't hit the steering linkage but the passenger side header is close to the torsion bar. I just put the car up on jack stands today for the winter which gives me some more room under the car to check the clearances. I will double check the steering linkage clearance. Thanks
[Re: YO7_A66]
#2416037
12/10/17 02:27 AM
12/10/17 02:27 AM
RapidRobert
a helper in the car with it idling in drive & brake on. You under the car & see what you see (vibration/touching)
[Re: RapidRobert]
#2416044
12/10/17 02:33 AM
12/10/17 02:33 AM
YO7_A66
Indiana
I have a fifteen year old son that would fit that description. π He is the only other person in my neighborhood who can start this carπ Outside of me. Thanks Robert
