Re: converting master cylinder
[Re: DoctorDiff]
#241576
03/05/09 07:48 PM
03/05/09 07:48 PM
Posts: 52,972 Romeo MI
MR_P_BODY
OEM 2-bolt aluminum master cylinders with plastic reservoir:
'95 Lebaron 7/8" bore**
'89 Dakota 15/16" bore**
'85 Diplomat (F-body) 1 1/32" bore*
'85 D-150 1 1/8" bore*
**Back of piston must be bored to accept manual brake push rod and retainer.
* Back of piston will accept manual brake push rod and retainer.
Rule of thumb:
1. Master cylinder piston size is relative to caliper piston size. Large caliper pistons require large MC piston.
2. All things equal, smaller bore master = higher line pressure and longer, softer pedal stroke.
Thanks, I didnt know what size the different body lines used
[Re: 8secDart]
#241578
03/05/09 08:23 PM
03/05/09 08:23 PM
MR_P_BODY
That is why I use the big bore.If you use a lot of braided line the pedal will fill like a soft grapefruit.
I use the braided for the whole set up and it has a little softness but not much... not worth my changing it
[Re: MR_P_BODY]
#241580
03/05/09 10:43 PM
03/05/09 10:43 PM
Posts: 1,771 St.Clair Shores MI.
tilt
St.Clair Shores MI.
Just to clarify: The 85 diplomat is a "M" body no??
68 CORONET R/T BEST MACHINE BUILT EFI'd TWIN TURBO(UP and RUNNING !!)
03 Mach1
[Re: tilt]
#241581
03/05/09 11:56 PM
03/05/09 11:56 PM
MR_P_BODY
yes
[Re: MR_P_BODY]
#241582
03/06/09 12:05 AM
03/06/09 12:05 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
yes
