converting master cylinder #241556
03/03/09 01:10 AM
03/03/09 01:10 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Can you guys give me the exact car/year to ask for when i go get a mc? Im after the 2 bolt aluminum version to replace my old school iron mc on the dart .
Or where all the factory 2 bolt ones iron ? I cant remember...
Re: converting master cylinder [Re: 493_DART] #241557
03/03/09 01:16 AM
03/03/09 01:16 AM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
Ask for 86 Dodge Ram.They will list aluminnm and iron.
Re: converting master cylinder [Re: 493_DART] #241558
03/03/09 03:57 AM
03/03/09 03:57 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
There is a member on here that sells the a conversion kit from the 4 bolt to the 2 bolt with master cylinder for $65 i believe. It's a very nice piece. I'll take a pic of the one on my car for ya.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: converting master cylinder [Re: DemonDust] #241559
03/03/09 04:42 AM
03/03/09 04:42 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
the 86 ram pieces online look like iron ? should it be a D150 1/2 ton or ?
R5P7Duster-- broke / budget racer here--ill have to do the $35 autozone piece and fab an adapter...
Re: converting master cylinder [Re: 493_DART] #241560
03/03/09 06:34 PM
03/03/09 06:34 PM
8secDart Offline
8secDart  Offline
My NAPA has a listing on both.I will look at the shop for part #.It will list the bore size at most parts stores.Get the 1 5/8 and your good to go.
Re: converting master cylinder [Re: 493_DART] #241561
03/03/09 07:25 PM
03/03/09 07:25 PM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
Don't forget the grommet from the brake rod.
Re: converting master cylinder [Re: 8secDart] #241562
03/04/09 02:02 AM
03/04/09 02:02 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
im only seeing 1 1/8 bore online --that would be great to get that part #
Re: converting master cylinder [Re: 493_DART] #241563
03/04/09 04:06 AM
03/04/09 04:06 AM
Bismarck, ND USA
cageman Offline
cageman  Offline
Bismarck, ND USA
I use 85 diplomat when I buy them, 15 bucks, and you will need a junkyard resevoir, they dont come with them.
Hmm, big bore hard pedal, no thanks. The diplomat one feels the best.
I make a 1/4 inch alum plate that these bolt too, real easy, the big hole in the center is off set a bit. I traced a four bolt master pattern, then centered the two holes in between the four holes, I tap the two holes and put short studs in there, and done.
The lines are backwards on the newer ones, The rear port is the front line on the alum ones.
Re: converting master cylinder [Re: 493_DART] #241564
03/04/09 09:14 AM
03/04/09 09:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What brakes are you running, disc/drum or disc/disc
The most you would need is a 1 1/8(never heard of a
1 5/8 on a car... must have been a typo). Did you
start with manual brakes or power. The pedal ratio
is different between the 2
Re: converting master cylinder [Re: MR_P_BODY] #241565
03/04/09 05:35 PM
03/04/09 05:35 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
non-power , 73 A body parts, disc front / drum rear
Re: converting master cylinder [Re: 493_DART] #241566
03/04/09 06:45 PM
03/04/09 06:45 PM
8secDart Offline
8secDart  Offline
Yes that was a typo,1 1/8.
Advance part # 10-1860.This is a Alum.
Could not find the NAPA # but call them and they should have it.Lenny
Re: converting master cylinder [Re: 8secDart] #241567
03/04/09 11:25 PM
03/04/09 11:25 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
thanks guys
ill have to walk the junkyard and find the reservoir i guess.
Will the rod that i have now work, even with adding the 1/4" plate ?
Re: converting master cylinder [Re: 493_DART] #241568
03/04/09 11:46 PM
03/04/09 11:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You should get a adjustable one or make a longer one
Re: converting master cylinder [Re: MR_P_BODY] #241569
03/05/09 02:18 AM
03/05/09 02:18 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Mr P - i can extend the stock one i guess and weld it. Do i just need it 1/4" longer then ?
Or is there a factory one i can use
Re: converting master cylinder [Re: 493_DART] #241570
03/05/09 08:19 AM
03/05/09 08:19 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Use the F-body aluminum master. The truck master has too large of a bore when used with stock, passenger car brakes.
The adapter thickness makes up for the difference in master cylinder design. You do not need to modify the original push rod.
Re: converting master cylinder [Re: DoctorDiff] #241571
03/05/09 09:02 AM
03/05/09 09:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Dr Diff, is the F-body a 15/16" bore(which I believe
should be fine) also hows the difference made up with
using the adapter plate, is the piston moved rearward?
thanks
Re: converting master cylinder [Re: MR_P_BODY] #241572
03/05/09 01:20 PM
03/05/09 01:20 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Does anyone know the part number for the f-body one?
Re: converting master cylinder [Re: B1MAXX] #241573
03/05/09 06:52 PM
03/05/09 06:52 PM
Woodstock , Georgia
Mopar_racer_99 Offline
Woodstock , Georgia
Please think about using one of these with modified master cylinders Pushrod kit with safety tab , I had one slip out on Ours in drive way, I had a friend who had one slip out on track, not a nice scene. John
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
Re: converting master cylinder [Re: Mopar_racer_99] #241574
03/05/09 07:06 PM
03/05/09 07:06 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
I got the master and the adapter from Magnum HP.
Then I made a bracket to restrict the pedal travel...after losing the prop rod and crashing in '07.
Re: converting master cylinder [Re: MR_P_BODY] #241575
03/05/09 07:43 PM
03/05/09 07:43 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
OEM 2-bolt aluminum master cylinders with plastic reservoir:
'95 Lebaron 7/8" bore**
'89 Dakota 15/16" bore**
'85 Diplomat (F-body) 1 1/32" bore*
'85 D-150 1 1/8" bore*
**Back of piston must be bored to accept manual brake push rod and retainer.
* Back of piston will accept manual brake push rod and retainer.
Rule of thumb:
1. Master cylinder piston size is relative to caliper piston size. Large caliper pistons require large MC piston.
2. All things equal, smaller bore master = higher line pressure and longer, softer pedal stroke.
